Question about Epson Stylus Photo R300 InkJet Printer
My Epson R300 printer won't recognise the cartridges
I have been using compatible ink cartridges for a couple of years. I have just replaced a JetTec black with another one and the machine won't recognise the cartridge. I then replaced that with an Inkjet cartridge and now it won't recognise any of the 6 cartridges despite my using them only moments before.
Is there any way of getting round this problem that doesn't involve buying 6 new Epson cartridges?
  • 1 more comment
  • cjmeadows Nov 12, 2008
    In answer to your question the cartridges that I put in the machine were both the same size
    Chris Meadows
    I hope that futurelogin is answering my question, I'm unused to your system - but just in case this is the problem.
    I have an Epsom Stylus Photo R300 inkjet printer. I have successfully been using compatible ink cartridges for about 2 years. Yesterday the black ink ran out and I replaced a JetTec cartridge with another one. I then had a message on the screen that it could not recognise the cartridge. I tried pressing OK, that didn't work. I switched the machine off, that also failed to solve the problem.
    Then I tried another black cartridge of a different make but the same size and this time the message came up that the machine did not recognise any of the cartridges, though I had been printing with them only moments before.
    Chris Meadows
    Thank you for all the solutions I have had, but unfortunately none of them were successful. Immediately I put the power back on I get the same message saying it can't recognise the cartridges.
    Would it help to uninstall and reinstall?
    Chris Meadows
  • Epson Master
  • 1,879 Answers
Here's the real deal
It is already a hardware failure, even if you try a genuine cartridge it will still not recognize it.
R300 is probably out of the one-year warranty period from the manufacturer unless you purchased extended warranty for it from the place of purchase, I would suggest to get a new printer instead of having it repaired.
Not sure with other manufacturers, but epson gives you discount for new purchases if you previously own one of their product.
To get a new printer at a discounted price click here.
Posted on Nov 12, 2008
    Sergeant:
    Novelist:
  • 196 Answers
As u said that u changed the black cartridge first and the message came that black cartridge cannot be recognized and so u replaced it with another cartridge with of same size but this time the message came any of the cartridge cannot be recognized.actually what happens when you insert the cartrige in the printer a small amount of ink is pulled from the cartridge due to internal settings in the printer.as u installed the black cartridge several times.and the ink got pulled from all the cartridges everytime u remove and insert the cartridges.so first try to insert orignal black  cartridge and check out if all the cartridges get detected after that.if the remaining colour cartridges does not get detected it is quite necessary that u will have to replace the colour cartridges as well. this problem occus many times in all epson model printers the compitable cartridges get stops detected by the printer.so for that time u will have to use the orignal cartridges and for next time again u can continue using the compitable cartridges it will work.
feel free for further assistance. thanks.
    Master:
  • 763 Answers
Changing the cartridge that is not compatible with your printer is not advisable. you should use the same cartridge with the same product name. try uninstalling and reinstalling it again and see also the utility of your printer like calibration of color. i would suggest you to buy an original cartidge and compatible with your printer.
thank you for using fixya
CHARCOIS
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
try to clean up the nozzle may be the ink clog
or
your printer will not recognize the cartridge if it is different
so try to transfer the ink in to your old cartridge may be that help!!!
    Genius:
  • 1,550 Answers
LEAVE PRINTER ON THEN,
  • remove ALL ink cartridges and close all covers
  • unplug power cord from back of printer
  • wait 4 minutes
  • plug power cord back in and wait (took about 5 minutes)
  • when prompted install ink cartridges and wait a few minutes
  • click the setup button on the front of the printer scroll down to the tools menu and then run clean print head 3 times and last of all run align printer 1 time.
  • SAM ANDERSON Nov 12, 2008
    The contacts located just back of the cartridges inside the printer cavity
    are damp or smeared with ink.
    This often splashes up during a cartridge
    change.
    Use cotton buds and with a little alcohol to clean them and finish
    with a dry cotton bud.
    Equally clean the cartridge chip
    President:
  • 1,952 Answers
Change the cartridge holder
  • 3 more comments
  • mohammed marika thambi
    mohammed marika thambi Nov 12, 2008
    If you have just installed a new cartridge and you still see an ink
    related error message, the cartridge may be incorrectly installed. To
    reinstall it, follow the ink cartridge replacement procedure but simply
    remove and reinsert the cartridge instead of replacing it.
    How to replace your ink cartridge(s)
    No. The printer will not operate if any cartridge is expended or removed. It’s best to always have extra cartridges on hand.
    To keep the print head clear and ready to print, the printer uses a
    small amount of ink from all the cartridges whenever it prints. Even if
    you select Black ink Only, some color ink is still being used.
    This message indicates that there is something wrong with the driver or the way it was installed, and you will need to remove
    and reinstall the driver (scroll to the Macintosh instructions).
    setViewedFAQCookie(26322, 34547);
    Brigadier General:
  • 3,614 Answers
Unplug your unit for an hour to reset the printer.
and try to check if there was a damage on the ink carrier, it better to clean the contact on this area.
  • micromaster
    micromaster Nov 12, 2008
    2nd try to;
    remove all connection form the printer to the computer
    uninstall the printer driver
    restart the pc, and put back all connections and install again the driver on your pc.
  • micromaster
    2nd try to;
  • 734 Answers
Was the new cartridge that u changed was of a different size than the original one or the same?
Keeps coming up cannot recognise all cartridges ,
just remove the catridges and clean it and reinstall if still you facing problem replace the catridges.
Jan 11, 2010 | Epson Stylus Photo R300 InkJet Printer
How do you change ink cartridgesfor the epson r300
Press Ink button;
Select Ink Cartridge Replacement
Press OK
changer cartridge
then press OK
And wait for initializing
Dec 18, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson DX7450 won't recognise compatible cartridges
This is a common problem and is caused by faulty or missing chips onthe compatible cartridges. You will need to get them replaced otherwise the printer will not operate. Contact the vendor where you bought them from and ask for repalcements or a refund.
Sep 30, 2009 | Office Equipment & Supplies
Epson R300 will not recognise cartridge
Check if there is tape on the cartridges if not try this
Take out the cartridges and then put them in fluid water which is not so cold and not so hot
then clean the golden patched with damp cloth
shake the cartridges and clean them again with damp cloth
put the cartridges back in and restart the pc
Sep 06, 2009 | Epson Office Equipment & Supplies
Epson sx600fw will not recognize a new ink cartridge (jettec)
use a q-tip with some rubbing alcohol to clean the electrial connections on the ink cartridge and more importantly the printer. after you clean them make sure to use a dry q-tip to wipe off the haze the alcohol will leave. if this does not work you can do a partial reset on the printer.
Jun 05, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Printer won't recognize cartridges
I am an IT tech in Education we only use compatibals I use a chip resetter from Ebay just type Chip Resetter for Espon and you are sorted for around a £10, this unit works on most epson 5&9 pin cartridge
regards
John
Jan 14, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Will not recognise all cartridges
some problems with compatible cartridges can be solved by taking all the ink out and powering the printer off then back on then put the ink back in, you might have to do this a few times also make sure no ink or dust has built up on the pins.
Sep 15, 2008 | Epson Stylus Photo R300 InkJet Printer
Ink carts not recognised
OK, i know this one ;-)
1 take out the cartridge thats not recognised ( 1 or all dont matter)
2 do a ink change with no ink in
3 put ink cartridge(s) back in.... wiggle the cartridge(s) to seat the "chip" right
4 do a ink change again, if not just follow the steps again.
I had to do this 5 times the other day before it picked it up.
It does work
Jan 31, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
296 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
