Question about GE (PSS26MSRSS) Side by Side Refrigerator
Can't get the refrigerator through the door ; how to remove handl
Would you please tell us how to remove the door handles to be able to get the fridge through the door? any other suggestions? Remove the doors??
  • Anonymous Feb 04, 2009
    can't get refrigerator through kitchen-I need to remove the doors
  • moderntech May 11, 2010
    How do you remove the doors and what tools do you need?
    Problem Solver:
  • 8 Answers
When I brought my side by side home,I had to remove both doors. I also had to remove the entry door AS WELL as the door center jamb!! Removing the refridgerator doors is really not a major task!
Posted on Nov 20, 2008
2 Suggested Answers
22yooper
  • 828 Answers
SOURCE: Kenmoore bottom freezer refrigerator door handles
this should be expired.
Posted on May 03, 2008
Handles loose on Frigidaire fridge doors
Jeff, If you can not see any visible screws, look for molded removable trim caps on the handle, remove and tighten screws. If no trim caps then your handle is probably mounted to fridge with screws in slotted slide, which get slid off by pulling straight up on handle, normally takes a lot of force to slide up and out. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to fix loose Refrigerator Handle
How To Fix Your GE Refrigerator Handle by removing the cap and tightening...
Refrigerator Door Handle How To Replace
Refrigerator Repair Replacing the Door Handle Frigidaire Part 218428101
Jul 10, 2016 | Frigidaire Refrigerators
Remove door handles
Search Results
    Refrigerator Door Handle - How To Replace - YouTube
    ? 2:54
    https://www.youtube.com/watch?v=O5q0WhxMfmQ
    Sep 17, 2012 - Uploaded by AppliancePartsPros
    Follow these simple step-by-step instructions to replace theRefrigerator Door Handle on Whirlpool, Maytag ...
    How to remove or take off Whirlpool fridge door handles ...
    ? 2:22
    https://www.youtube.com/watch?v=tmYz4FVqVnw
    Oct 3, 2014 - Uploaded by way22good1
    How to take off whirlpool refrigerator door handles. ... How To Fix Your GE Refrigerator Handle by removing ...
    Whirlpool Refridgerator Door Handle removal - You
Dec 20, 2015 | Refrigerators
I have a new door to replace the right side one on this refrigerator but for the life of me I can't get the door handle off the old one. New one didn't come w/ the handles/hinges, etc, obviously. The...
Are you sure...
To move refrigerator through a house door, it may be necessary to remove the refrigerator door handles.
NOTE: Handle appearance may vary from illustrations on this page.
1. Removing Refrigerator Handle
• Grasp the handle tightly with both hands and slide the handle up (1)(this may require some force).
• The keyhole slots (2) on the back of the handle allow the handle to separate from the mounting screws (3).
CAUTION: The handle could be damaged if you hit it with a hammer while removing or attaching.
CAUTION: When you assemble or disassemble handle, you must push or pull with reasonable force.
Jan 21, 2011 | Refrigerators
Mod# RFG297AA:Need to remove the freezer section or handle/latch
there are two screws on each side of the bottom freezer unit you need to remove. they can be removed after de-installing the front bin with the two plastic sleeves on the right and left. Then you can remove the bottom drawer door and the bins inside. next, open both top doors and angle the fridge with one door inside the door frame, then "walk" the fridge over the doorstoop, turning towards the inside door as you push. Follow thru with the rest of the unit, then re-attach the bottom drawer.
Apr 08, 2010 | Samsung RF265AA Bottom Freezer French Door...
The door handle on the freezer of my GE Profile Bottom Freezer Refrigerator came off.
Hi, Please get me the model # from the label inside the refrigerator and I will look this up for you. Most handles have a set screw that tightens down.
Vic
Jul 11, 2009 | General Electric Profile PFSS2MIXSS...
I want to remove my Amana Refrigerator handles
The handles are probably attached with screws from the back -- this will require removing some panel(s) to access them.
Apr 29, 2009 | Amana ARS266ZBS Side by Side Refrigerator
Door handle
If this is a side by side door refrigerator you can not move the doors or the handles.
Phil
Jan 13, 2009 | LG LRSC26920TT Side by Side Refrigerator
Fisher Paykel fridge door handle loose
Yes hello, I had the same problem - similar fridge model.  Mine was the fridge (not freezer) door handle ie. the upper door.  There are no small holes on the bottom of my fridge handle.  Working from the outer door edge, I gently prized loose the plastic trim located under the door.  I didn't take it completely off, just loosened about one quarter of the length, enough to flex the trim downward so that I could then access the phillips head screw that secures the fridge handle from the inside of the door.  The trim will prevent you from using a conventional screw driver to tighten the screw.  I used a screw driver bit which is only 25mm long.  It has an hexagonal end to which I applied a small spanner and voila - the handle is once more secure.  Good luck.
Nov 07, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
2,992 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
