Question about Passport 8500 Radar Detector
Error Message? I had my Passport 8500 (NOT X50) for about 4 months when I noticed sometimes it would not work when I turned it on. Then one day, it was ALL the time. When I plug it in/turn the wheel to turn it on, it goes through it's usual diagnostics where it checks the different bands and everything. After a few seconds, it freaks out and says "ERROR" on the front. Is there a way to fix this? I know if I hold down both buttons it is supposed to reconfigure itself but that doesn't work either. Help me!!
  • Chase Stern Nov 08, 2006
    I just plugged it in via my phone cordfor the first time in over a month and it now works fine. But, I know it will happen again eventually, so I still would like some help.
    Also, I tried the 2 button thing and managed to discover a cool programming feature which includes several different items. Anybody know what these all mean? Thanks!
  • 3 Answers
To reconfig the device you need to hold down all three buttons(not two)
Posted on Mar 20, 2008
SOURCE:
7,010.43:40975 error message for the Xerox Phaser 8500 printer.
The printhead is stuck in the tilted position. Did you have a power outage or turn it off by unpuging it? Not hard to fix but you have to tear it down and rehome everything. sometimes if you turn it off and turn it back on it will find home on itself. But rehomeing it works every time. If you dont know how to do this call a service center.
Apr 28, 2010 | Xerox Phaser 8500/DN Printer
Passport Radar service required
The internal diagnostics have detected a problem with the detector. You should contact Escort Customer Service directly for assistance, below:
http://www.escortradar.com/customer-service.php
Sep 27, 2009 | Passport 8500 Radar Detector
Taking apart escort passport 8500?
I thought that the 8500 used Phillips head screws. If its not Phillips head, then possibly you need an appropriate sized Torx screwdriver.
Apr 08, 2009 | Passport 8500 Radar Detector
Escort passport 8500 error 13
This is an error message which indicates a specific internal component failure. Escort will have to fix your 8500.
Dec 30, 2008 | Passport 8500 Radar Detector
No sound
The Piezoelectric speaker has gone bad. Escort can replace it.
Dec 28, 2008 | Passport 8500 Radar Detector
Escort 8500 Restarting Constanatly
most likely u have a bad connection with ur cigarette lighter or the fuze in the end of the wire that goes into the cigarette lighter the cap screws off and theres a fuze there or there is a small cut in the wire or kink in it that if shutting off the power to it,.or the tip in the plug that goes into the detector isnt fuly pushed in but i believe its a fuze hope this helps
Nov 20, 2008 | Passport 8500 Radar Detector
8500 Alerts for no aparent reason
Got to the bottom of my false alarming situation. I finally called Escort and discussed the behavior with the technician who immediately concluded the antenna was failling and needed a repair. $30 worth of shipping and about a week later I got my repaired unit back and it works perfectly. Not sure the root cause but I am going to treat it as gently as possible and hope it keeps working, I sure like it better than the V1.
Dec 05, 2007 | Passport 8500 Radar Detector
Continuous alert
About the only thing to try with the Escort 8500 and the x50 is to do a full reset. Hold all 3 buttons down while turning the detector on. I believe Escort will still work on it, there will just be a service charge with no warranty.
Sep 14, 2007 | Passport 8500 Radar Detector
Escort, passport 8500
Hold all three buttons down at the same time to reset the device. If this doesn't work it probably needs to be sent back for repair/reflash. Jack
Mar 23, 2007 | Passport 8500 Radar Detector
Passport 8500 Radar Detector Logo
211 people viewed this question
Top Escort Vehicle Parts & Accessories Experts
Jason
Steve Allison
Steve Allison
Marvin
Marvin
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
