Question about HP OfficeJet 5110 All-In-One InkJet Printer
Borders outside printable area
I keep getting a message that says the borders on the pages I am printing are outside the printable area. The printer regularly chops off one side of a border I put on any page. I have tried adjusting the distance from the edge of the page. I have tried adjusting the margins. Nothing I do seems to work.
  • Anonymous Mar 16, 2014
    how do you scale to A4 in bizhub20 or how do you fit to paper size when it tells you the margins are outside the printable area?
  • 432 Answers
Adjust the margins in the software you are using.
Posted on Jun 26, 2007
Printing 11x14 photos
First use a photo processing programme (like say Photoshop or PS Elements - or if you have not got that (can be expensive) get the free Faststone Image Viewer and size the image to twice the paper size you want, then use the crop tool to select half the image and save that as a file with a name where you can find it again. Do the same with the other half. You will now have two files, each half of the paper size. As they will have small borders, print and trim the borders, so you can then mount side by side to achieve what you want. I would advise to NOT try and print without borders - that can introduce other problems - just accept having to trim the small borders from normal printing.
Apr 09, 2014 | Epson Stylus NX230 Small-in-One USB...
Hp officejet 6500 wireless TOP OF PAGE CUTOFF
Have you checked to see if you are printing with borders or printing borderless (under Preferences/Advanced)? I had this problem when printing double sided, since it will only be able to print double sided with borders...
Jul 11, 2012 | HP Officejet 6500 Wireless All-in-One...
I can't get my computer to print because it keeps saying the margins of section 1 are set outside the printable area of the page. I have a meeting to go to and It's important that I get this paper off the...
I assume this error is occuring in Microsoft Word.
  1. To see the margin settings of your document, go to File > Page Setup (or Page Layout > Margins > Custom Margins for Word 2007).
  2. Click OK on the margins dialog, and Word will check the settings against your currently selected printer. If a margin is set outside the printable area (usually the bottom margin set to zero), you should see the warning message.
  3. Click the Fix button to have Word change the margins
    to match your printer. You should now see the Margins dialog with the new margin settings.
  4. Click OK.
May 12, 2010 | HP Officejet J5780 All-In-One Printer
I need to print some cards with my printer, is it possible to reduct margin to zero? I have created the document without margins, but the printer cuts part of te documents... thank you for your help!
This is normal. Practically all printers have a 'non-printable area' which forms a border at the top and bottom and left and right hand sides of the page. Whilst your software may allow you to work with a zero margin, your printer is physically incapable of printing in the non-printable area and will simply cut-off any text or images that overflow into this region.
The best solution is to reduce the number of cards on your page so that you can bring the text back within the printable area of the page. Then print with normal or wide margins and trim the excess from your cards.
Mar 19, 2010 | Canon PIXMA MP210 InkJet Printer
HP4000n (Not printing borders on Excel and Word)
this is because your document content is out of range for your printer settings
clik on file - page setup and adjust your document properties from there
Jul 24, 2009 | Office Equipment & Supplies
Problem with printing borders, and with cartridge.
Hmm, I got the same problem once in my university LABs.
What i do was the same you have done, but do try again because if "some side" of the border is not been printed, then its the "Border Setting".
Try using Ms Word 2007.(I guess you are already using it)
Goto Page Layout Tab > click Page Borders (Borders and Shading dialogue will appear) > Then insert a border, apply it.
Now again go there, and this time in the bottom right corner of the dialogue box, you will see Options button, click it.
Make the Margins Maximum (31pts) (Measure from : Edge of Page)
if this doen't work, then;
You can also change the margins but now (Measure from : Text)
But the first one works for me perfectly.
before doing this all also re-insert your blx/wht cartirdge.
  • If helpful, Kindly do Rate
Jul 18, 2009 | HP PSC 1410 All-In-One InkJet Printer
Kodak 5100 AiO When printing emails the borders
Read through some of the solutions on here and eventually removed print heads and cleaned them and printing of borders and words is now fine. Still have probs with photos being discoloured .
Apr 12, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Printing problem in Microsoft Word 2003
Does the bottom border show up in Print Preview? Some printers will not print the full page, to include the border if it is too close to the papers edge. If you adjust the border to be further away from the pages edge, it should print. Instead of applying a page border, you may have to draw a border using a rectangle shape and apply the desired line style.
You can also try to adjust the border margin to measure from "edge of page" instead of measure from "text". This setting is on the options button located on the page border tab under the Borders and Shading window. This may allow you to adjust the margin enough to be able to print the border.
Apr 09, 2009 | Microsoft Word 2003 for PC
Borders
plese close the selected border from your page setting
Apr 11, 2007 | Epson Stylus Photo 1270 InkJet Printer
I can't get rid of the margins when i print something
I'm guess you are printing from MS Word? Click File the "Page Setup" Click the layout tab the far right then go to the bottom and click borders and select the NONE option. You should have your borders removed!! =) That is if that is the type of border you are talking about.
Cheers!!
Feb 11, 2007 | Xerox Phaser 8500N Printer
HP OfficeJet 5110 All-In-One InkJet Printer Logo
834 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
