Question about Hotpoint Aquarius WMA42 Front Load Washer
Door won't open
My Hotpoint Aquarius 1000 wm62 door stays locked after the cycle has ended. How do i open the door?
  • Anonymous Mar 19, 2014
    All amber lights flashing and door won't open after drying cycle
  • 135 Answers
Usual reason for this is not emptied correctly. The filter on this model is in an awkward place so try lowering drain hose into a bowl to check if water still in.
Posted on Nov 11, 2008
Hotpoint Aquarius WM62 bearing noise how to change it
Hello,remove all the surround screws from around the door glass then gently lever the 2 halves apart,remove the old hinge,and re mount the new one along with the plastic bearings refit the screws,refit the door to the front cabinet.
May 23, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius 1000 WM62 leaks from the bottom at the front of the machine towards the end of the cycle. How do I fix this?
Carefully exmine the door seal for a hole or split, remove the clamp ring round front and pull seal of front of cabinet and check it carefully, if no sign of leak from seal, then it is going to be leaking from the plastic drum front of washer.
This will entail removing tye front panel.
Hope this helps.
Jan 17, 2010 | Washing Machines
WD420 hotpoint door will not open ?
In some cases switching off and back on again solves it. Otherwise try to run Rinse & Spin cycle again, and if after cycle door will stay locked you'll need to check the door lock itself, its wiring and/or main PWB
Please Update me how is it going on this
Mar 17, 2009 | Hotpoint Aquarius WD63 Front Load...
Door Locked. Cannot open. Washine inside.
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Mar 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius washing machine
where is the filter for hotpoint aquarius wma54 washing machine
May 31, 2008 | Washing Machines
Hi hotpoint wm62 door locked
Try "end of cycle" button & wait for 2 minutes before you try the door..........
Jan 12, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius model wm62
Sounds like a faulty door interlock (quite a common problem)
UNPLUG POWER first, remove lid, remove screws holding door lock in place and lift lock assembly up, replace door lock, ensuring cables are replaced in the correct order. Refit and test.
Good luck.
Nov 11, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
632 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
