Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
No flash, blerry pictures, very slow shutter speed
And sometimes shutter gets stuck dose not always take pictures
I took it back to the store and exchanged it I hope this one is better I like this camera and for a $500. camera it should not be acting like that thank you
Posted on Nov 13, 2008
My D60 only when I use the flash I get an error message job nr
Job NR is usually associated with the camera's processing time during very slow shutters. If you wait long enough it will show you the image you've taken but because the shutter is very slow, the image will be blurry and unrecognizable. On manual mode or Shutter speed priority change your shutter speed to at least .125 of a second. That should fix the problem.
Apr 16, 2013 | Nikon D60 Digital Camera
Shutter will not open every time i take a photo. The photo always comes out black on the view finder
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Aug 27, 2011 | Cameras
Outside picture are white
Make sure the ISO is set to the lowest number or even to "auto ISO". The best way to avoid these lighting problems is to adjust your aperture settings, your shutter speed and your film speed when shooting. Additional details about thus sibject could find in the Samsung_S500_Owners_Manual in section about Settings & Mode.
Its possible that you are interesnting to check other
information, so visit this two sites Fix-Overexposed and this other take-better-photos-in-5-easy-steps.
Finally, remote but possible, could be t
he symptoms of a stuck or "sticky" shutter, this are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Hope helps.
Apr 29, 2011 | Samsung Digimax S500 Digital Camera
The Screen always shows black and it takes all black pictures
Sep 07, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
The shutter speed seems really slow so the picture always comes out fuzzy. How can I change the shutter speed?
You can't change the shutter speed but you can set the ISO to a higher number thereby forcing the shutter to speed up.
Jun 26, 2010 | HP Photosmart E327 Digital Camera
Nikon D60 Digital SLR--Slow Shutter Speed
Your're probably using a flash with TTL disabled. So 1/200 is the highest sync possible with that kind of flash. Did you try removing the flash off the body and setting faster shutter speeds?
Apr 28, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Pictures are not sharp
On most camers that means you are going to get a blurry photo because of camera shake. Using the flash should take care of it. You may have the flash set to "flash off" mode accidently, and in insufficient light the shutter speed is too slow to stop blur.
Mar 17, 2009 | Cameras
Black strip across the top of the picture
I can tell you exactly what is happening. This is probably either happening when you are taking a photo with a flash? The maximum flash sync your camera has is 1/125 or 1/60 of a second. If you set your shutter speed faster than that, you shutter closes too slow and creates that black strip. Put the shutter speed to 1/60 or slower and see if that happens. If you have a long lens on the camera, you have to have the shutter speed either equal or less than the focal length to shutter. 50mm lens=1/50 a second without a flash. Otherwise you could have a bent or broken shutter curtain blade. Maybe someone stuck their finger in there.
http://www.cameradr.com/
He can fix it if you blades are broken.
Jan 02, 2009 | Nikon N75 35mm SLR Camera
Blurred images
This is mainly due to the slow shutter speed selected by your CAM. in low light situations the cam chooses a slow shutter speed to expose the image adequately. Any shakes that may have caused during the shutter operation will cause the funny images.
use tripod or other kind of support to your camera while shootiing in low light (indoors) without flash.
Oct 11, 2008 | Olympus Stylus 760 Digital Camera
Flash vs No Flash
Probably what's happening is that the shutter speed is automatically adjusted to a faster speed with flash. With no flash the shutter speed slows down to compensate for the lack of light, therefore leaving it open longer. So while you are holding the camera during a longer exposure you are promoting camera shake, thus blurry pictures. The LED may tell you information you need to know like shutter speed, apture, flash on/off, etc.
Sep 12, 2005 | Olympus Camedia C-750 Ultra Zoom Digital...
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
56 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
