Question about GE Profile JTP56 Electric Double Oven
Heating elements will not work
A month ago we had a tech come out to fix our f7 problem and he "cleaned" the cable and it worked fine. Since we haven't had any problems until we used the self clean option. That seemed to work fine, but now it won't heat up. Top or bottom. F7 fix did not work for this, i tried. Any ideas?
  • 3 Answers
Might be the hest sensor
Posted on Nov 17, 2008
While cleaning oven I lifted bottom element heard a pop. Now neither the stove or oven will not come on. The indicator lights do not light up either.
The "pop" was the sound of the heating element shorting to ground so naturally nothing works now.
Jan 18, 2017 | Ovens
I recently ran the self-clean option on my GE Profile JK955B0F5BB. Now when I set the touch pad to 350 degrees or more, the oven heats up to beyond 500.
That is not a valid model number, the issue is most likely the thermostat has failed. The part is about 12 dollars.
Jan 07, 2017 | GE Ovens
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Oven elements just stopped working
If I understand your use correctly, you were using the oven to heat the space? Or for baking?
Regardless, it sounds as though the elements have failed. If you used the oven for heating the space (with the door open) the broiler element comes on during preheat of the oven to get the oven to temperature more quickly. The elements are NOT designed to heat a space, and will quickly burn out if used in this manner.
Jan 23, 2009 | Ovens
Nothing works but the clock and shows F7
I had this on my stove for months and it also didn't work. Finally, Sears changed the computer board and no trouble since then -- five years ago@
Sharon in Covington, La
Oct 15, 2008 | Kenmore 30169 Electric Single Oven
F0 error code on GE wall oven
I had the same FO error. It turned out that the ribbon cable from the front panel was not making good contact where it mated with the circuit board. Remove ribbon cable and clean contacts on ribbon cable. Replace cable and problem should resolve.
Oct 13, 2008 | Ovens
F7 error message on GE oven
Send an e-mail to Charlie at for a fix-it that you can try. He explains a possible solution fully with his 'The Dreaded "F7" Error' solution. I actually found his information on another website when I did a web search for "GE Profile Oven F7 Issue". I sent an e-mail to him and he replied with free fix-it information. I am not a repair person myself, but, his instructions are very clear and simple to follow. I did the fix-it at no cost in approximately 10 minutes and it has solved my problem so far.
My oven is also a JT950 and the builder installed it in our home back in 2000. Our F7 issue started about 2 years ago. For a few months, "clearing" the panel and/or shutting the oven off at the breaker panel would temporarily solve the problem. About 1 1/2 year ago, however, the F7 would come on and continually beep. A repairman looked at the oven and replaced the control panel at a cost of $600 (ugh...). That solved the problem until a month ago when the F7 continuous beeping began again. There was no way I was going to pay another $600. for "temporary" repair and I was thinking of replacing the oven. Luckily, I came across the above-mentioned fix-it information and took a chance by following the simple instructions provided.
Jul 02, 2008 | GE Profile JT952 Electric Double Oven
i would first check the lower units bake element , usually a visually inspection is enough to determine if its good or nor, usually a burn mark can be seen on the element itself, and if you can even see the element the bottom f the oven cavity will lift off for better inspection
Mar 25, 2008 | Maytag CWE5800A Electric Double Oven
GE JTP56 Double Oven
Hello there,
This may be related to the F7 problem even if you are not getting an error message. Go to my web site at the following link:
Please let me know if this works for you. I have sent my fix to over 1300 folks.
Good Luck,
Oct 20, 2007 | GE Profile JTP56 Electric Double Oven
GE Profile JTP56 Electric Double Oven Logo
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
