Question about NetGear WGR614 Wireless Router
Wrong IP address entered when installing NetGear WGR614v7
When I first tried to install the router it was asking for IP, Subset, and Gateway address. I installed a incorrect IP address, How can I delete or remove it and put in the correct IP address?
  • gjohorn Nov 14, 2008
    Sorry I delayed in rating the above solution. I do believe I was making it more complicated than need be. After receiving your solution I contacted by "Geck" and we have the wireless up and running.
    Gene
  • 108 Answers
If you are refering to the router, there is a small button you can use a pen to press and hold while the router is on, Hold for about 10 to 15 secs - You will see the lights change as its resetting. That will reset the router back to factory defaults. You can then follow the directions from your manual or goto Netgears website and look up the manual there which will be in PDF format.
Please give more details on what you are trying to do by setting an ip address. You maybe making things more complicated than need be.
G'luck
Posted on Nov 11, 2008
I have a MacIntosh computer and wanted to install NetGear WGPS606 54 Mbps Wireless Print Server w/4 Port Switch to serve a Canon Pixma MP830. The hangup is the IP address assigned to the printer. I had...
You can assign ip with 2 method 1 is manually and other is automatic .
If you set manualy ip you must need to set gateway as your printers and other computer's gateway.
Subnetmask is same in all system.
For example if your netgear lan ip is 192.168.1.1 then your printer ip 192.168.1.5 sunet mask as 255.255.255.0 and gateway is 192.168.1.1
Other computer's ip 192.168.1.6 subnet mask 255.255.255.0 gateway 192.168.1.1
Make sure the printer driver installed and it is in network.
IF you want ip from netgear then you need to enable dhcp in it.
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.1.1 or
http://192.168.0.1 or
http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Then click on dhcp then enable save settings and restart netgear.
Then in printer set ip get automatic from router.
Let me know if you need further assistance.
Thanks for using FixYa.
Jul 14, 2010 | Computers & Internet
I down load firmware for my netgear wgr614v7 router on to my compter and now i can open it what do i do ?
You need to install the firmware from your router. You need to open up Internet Explorer and type in the router IP address in the address bar. Usually, 192.168.1.1. Enter user name and password. Look for a firmware tab and follow the instructions.
Mar 28, 2009 | NetGear WGR614 Wireless Router
Can't connect my Netgear WGR614v7 to Time Warner Cable Internet
I have just bought a Netgear WGR14 v9 and I was wondering if anyone knows how to set it up with Time Warner. We just swithced from Bellsouth to Time Warner and I don't know how to set it up?
Jan 11, 2009 | NetGear WGR614 Router
Port forwording
Follow the steps in this simple tutorial:
http://portforward.com/english/routers/port_forwarding/Netgear/WGR614v7/Flatout_2.htm
Jan 08, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Cannot get past the IP entering details.
Hello.....If your ISP has given you a static IP address to use to connect to the internet, they should also have given you the Subnet Mask, and Gateway IP Address - these are the settings to use.
If you don't have these settings, you will have a dynamic (variable) IP address. If so, try logging in to the router again, go to Basic Settings, and configure 'Internet IP Address' to 'Get Dynamically from ISP'.
Similarly, if your ISP has given you one or two DNS addresses, enter these up - but otherwise set as 'Get automatically from ISP'.
You might need to reboot one or more times for the settings to take effect. Hope this helps, but please come back to Fixya if it doesn't ...
Dec 30, 2008 | NetGear WGT624 Wireless Router
Driver Downloads
to configure your router you dont need install driver. you can use browser and type predefined gateway IP (192.168.1.1)
If you need other downloads and technical info you can proceed to the link below
http://kbserver.netgear.com/products/wgr614v7.asp
Good Luck
Jun 17, 2008 | NetGear WGR614 Wireless Router
Netgear router DG834GT
To do this you do not need the installation disk.
1. Click Start, Run, CMD, enter. Type 'ipconfig /all' and write down or remember the ip address for your default gateway.
2. open your browser and type http://192.168.1.1 (or whatever the ip address is for your default gateway.) hit enter.
3. In the username and password login screen type admin for both. If this doesn't work, try using admin for just the password, if no luck try again for just the username, until you are logged in.
4. Go to wireless settings, security, and find the part where you can set your wireless password. It is also a good idea to use wpa personal instead of wep, because it is a stronger encryption method.
Apr 15, 2008 | NetGear WGR614 Wireless Router
Wireless connection
JRSavage - The solution you supllied is to assign the IP address to the client. It appears Guest is asking how to log into the Router.
Guest - If the router is a wireless router then you should not have to know it's IP to connect to it, simply looks for it's SSID in WIndows Zero Config wireless util (or the util that came with your wireless adapter)
If you're connected and looking how to log into the router itself you'll want to enter the router's IP address into the address bar of your internet browser.
If you're looking for where you enter the router's IP for NIC configuration, you would enter the Router's IP as the Gateway address.
Feb 23, 2008 | NetGear WGR614 Wireless Router
Cannot Connect Gaming Console or Remote Computer to the Internet
1. Make sure the gaming or remote computer has a correct IP address with the same IP subset address as the wireless router or access point. 2. Turn the bridge off. 3. Turn the bridge on. 4. Recheck the IP address for the gaming computer or remote computer. 5. Turn off all network devices. 6. Power on the wireless router or access point. 7. Wait 30 seconds. 8. Power on the bridge. 9. Check to ensure the bridge connects to the wireless router or access point. 10. Power on the gaming console or remote computer.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
NetGear WGR614 Wireless Router Logo
115 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
