Question about Dell Wireless Keyboard Optical Mouse w0147
Mouse dropped on floor - does not work.
The mouse lights up with the batteries, but it does not work.  Keep getting message, "device connected to Channel 1".  What does this mean?
    Genius:
  • 1,605 Answers
It means the mouse is connected to channel 1 on the wireless.
there ae several channel of frequencies that the wireless use. it select the best fit at the time when you install it.
you need to reset all the wireless device in order for the mouse and the keyboard to connect.
refer to your users manual how to reset the device.
Posted on Nov 11, 2008
Mouse quit working. Changed batteries. nothing
keep your mouse near wireless device and there is a button named connect keep pressing that button for 3-4 minuts and then try to use the mouse, that will work
Mar 30, 2010 | Logitech Cordless Mouse
I have Model 1058 Mouse bought 12/09. Computer crashed (motherboard) and had to get new one. Can't find installation disk for mouse. Can you help?
change the mouse battery and there is a button named connect on mouse keep pressing the connect button for 3-4 minuts and keep mouse near wireless device which is connected to the computer in USB port then restart your computer and mouse will work fine.
Mar 30, 2010 | Microsoft Wireless Laser Desktop 4000...
I just dropped my mouse by accident and it doesn't work now. How do I fix this?
open up the door to make sure the batteries are okay, reseat the batteries into the slots to make sure the batteries are making proper contact.
If that doesn't work, then try new batteries just to be sure the batteries aren't the issue.
If it still doesn't work then leave the new batteries in and the usb adapter that comes with that mouse, hook it back up to the usb slot on the laptop and see if windows recognizes the mouse. If no messages come up then go into the device manager and see if the mouse shows up in there.
It will show up as either the type of mouse you have or a yellow question mark which would mean you need to reinstall the software for the mouse.
if nothing shows up in the device manager for the mouse then that means the mouse is bad and would need to be replaced.
Dec 01, 2009 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Wireless Notebook Optical Mouse Not Connecting
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Jan 30, 2009 | Microsoft Wireless Optical Notebook Mouse...
Keyboard not working
To connect the keyboard or mouse to the computer, you must connect the wireless device through the USB port and get it to hold a good connection. You do not have to install any devices to use these products, they automatically work when you plug them in. When it says that the device is recognized, you are ready to use it! If you have a desktop, you can also plug the wireless device to the mouse port. The keyboard and mouse work properly up to 5' away from the connected wireless device. If you can get the wireless device to work properly, you should have no troubles with the product.
Dec 29, 2008 | Innovations kb985w RF Wireless Keyboard
LX7 cordless optical mouse with dongle
Had the same problem. But before filling the logitech RMA from to get a replacement, I put new batteries into the mouse and the mouse worked again.
I am using rechargeable batteries, and I seems to me even if the green light on the bottom of the mouse is on, the driver warning for low battery does not come on. May be the volage drops to fast with a older set of batteries.
Try out new batteries. Hope this helps.
I am using the LX7 mouse for more than 2 years with lost of abuse (>10x drops from shoulder hight to hard office floor, sitting dongle in my pocket and dropping my backpack onto the floor with the dongle on the botton in the backpack).
Regards.
Oct 03, 2008 | Logitech LX7 Cordless Optical Mouse
Unable to connect to the synaptics pointing device driver
I am assuming that the mouse has batteries installed in it and the CD was used to install the software program for the mouse.
Did you try Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
Sep 08, 2008 | Microsoft Wireless IntelliMouse Explorer
MS Wireless notebook mouse 4000
I have already broken two of them. It seems that the receiver is very sensitive to hits. Probably a PCB issue. I disassembled the receiver and discovered that if I bend it a little it starts working but if I leave it stops.
Jan 16, 2008 | Microsoft Wireless Optical Notebook Mouse...
Keyboard wont respond
Often this is simply because the radio link between the receiver and the mouse/keyboard has been broken. Some possible reasons for this are: flat batteries, insertion of new batteries, connector to the computer removed, etc.
In the first instance, you should restore the Logitech devices to a defined status (reset). To reset the device:
Remove the batteries from the mouse/keyboard for approximately ½ hour.
Press and hold the "Connect" button on the receiver for 15-20 seconds. Make sure that the receiver is connected, the PC is switched on and that there are no batteries in the devices. After resetting, insert new batteries and restore the connection as follows:
  1. Press and hold the "Connect" button on the receiver for 1-2 seconds.
  2. Then immediately press the "Connect" button on the bottom of the mouse (locate this button before you start, all cordless mice have a "Connect" button)
  3. Move the mouse around to check that the connection is working correctly
  4. Press and hold the "Connect" button on the receiver again for 1-2 seconds.
  5. Then immediately press the "Connect" button on the bottom of the keyboard (locate this button before you start, all cordless keyboards have a "Connect" button)
  6. Use the keyboard to check that the connection is working correctly
  7. Both devices should now be working correctly
If one or both of these devices is still not working, try them on another compatible PC system to ensure that the fault does not lie with your PC system.
Nov 09, 2007 | Logitech Cordless Desktop MX 3000...
Dell Wireless Keyboard Optical Mouse w0147 Logo
131 people viewed this question
Alun Cox
