Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Philips 55pw9363/17f no pictures, with sound.
I bought this TV used and got about 4 months use out of it. First I noticed that the picture would drop out intermittently when watching cable. I switched to using the VCR to input the cable and that kept us up and running about another week. Sometimes when turned on it would take for ever to warm up and show picture. Sound was never a problem. One day, no more picture, didn't matter from where. There was a popping noise that would occasionally occur before the picture went all the way out. Not like a string of pops but like 1 pop. I took the back cover off and noticed that somebody had been in there before I got the TV. Nothing looks burnt. The picture bulbs do not light up.
If you have any ideas about what needs replaced or adjusted, I am very handy and want to fix this myself.
  • cfinch Dec 01, 2008
    I have the exact same problem
  • 1153 Answers
SOURCE: No sound and no picture.
Look for the vertical output, it should be a 7 pin transistor located on the defection board, meaning the board with the highvoltage transformer on it. Should be on a heat shield standing up(black)
Posted on Aug 15, 2007
Slinteriors
  • 8617 Answers
SOURCE: Flyback making a poping noise
You can get the replacement Flyback at the following link, and they provide free instant messageing tech support to take you step by step with the replacemnet proceedure. You need phillips 32942 flyback, its listed in their flyback catagory.
http://servicemanuals.vstore.ca/
Posted on Jul 27, 2008
Ecollier2012
  • 3459 Answers
SOURCE: philips tv
Sounds like your convergence chips are shorted which would make the set shut down. Its also possible that the flyback has failed but because the first symptom was the 3d look I would start with the convergence repair.
Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
No audio or video - typicaly occurs after having the distorted color problems listed above.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Hope this helps,
Ed
Posted on Nov 28, 2008
SOURCE: philips tv model #55PW9363/17F digital ready?
unplug power supply. remove back panel and locate where the power wires attach to the board. there should be a fuse there. remove and replace. also check for other fuses they might be blown too
Posted on Feb 19, 2009
  • 162 Answers
SOURCE: 60'' Philips TV went out....
Try the site www.TvRepairKits.com. They helped me recently.
Posted on Aug 09, 2009
Tv is on with no picture or sound, only 4 months old!!
Hello
The power supply regulator board to your set has the fault. If you try to open the set, or try to repair it by yourself, the warranty will void. The set must have warranty as it is new. Why do you spend for it? Just contact the nearest authorised service center for Sceptre. the components in this set will be very hard to get from open electronic spare part market, and will costly too.
Mar 11, 2012 | Sceptre 32 X320BVHD 32 LCD TV
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
About a month ago my Phillips 55" widescreen projection TV started to have picture problems. On the left side of the picture it looked like the colors were spinning, then after a while the picture just...
I have a philips magnavox and had two problems that I recently fixed using kits from www.TvRepairKits.com. I can't say enough about their kits and help. Without them I would have never been able to fix my TV set myself.
The first problem I had was the TV was looking 3D. After doing some homework I found out that this is a convergence problem. I bought a kit, followed the instructions, and to my amazement fixed it myself.
After building my confidence with the 1st repair I decided to get their CRT fluid kit. This kit fixes the dull video,red video, or bright/halo looking video. If you have a magmavox set that is more than 5 years old your tv has this problem already. It happens on every set. As before I bought the kit, followed the instructions, and now my video looks factory new. Once again I wanted to say thanks to the team at Tv Repair Kits for putting together kits that the average joe can use.
ML
Jul 18, 2009 | Philips 55PW9363 55" Rear Projection...
After 2years and 9 months the picture went black,
Most likely, capacitors in the power supply are bulged. It is not an expensive repair.
Jul 01, 2009 | Philips Televison & Video
Philips tv model id: 19pfl5422d/27 terrible loud sound
The issue is 4 1000uF X 10V on the main board under the shield close to the connector that from the power board. you will see them because they will be FAT( exploded)
Feb 28, 2009 | Televison & Video
Tv is 4 months old we have sound but no picture. If we leave the tv off four a while it comes back for a little bit and goes again. Getting no response from the company we bought it from. Can you help us.
Sounds like the bulb has burned out in the TV. Sometimes the TV has surges or spikes in power and it can overload the picture bulb and fry the bulb without you even noticing anything. The main indicator of this is that there is no picture but there is sound. The bulbs can cost anywhere from 75 dollars to more than 300 dollars. If you can finally reach the company you bought it from and have them look at it they will tell you the same. There are sites to look up the prices of new bulbs but if you have a warranty through the company you bought it from then it would be free of charge to replace.
Oct 30, 2008 | Televison & Video
Resetting philips 42pf9730a/37 remote
There is a firmware that can be updated via usb from philips. This fw was used to correct the tv powering on with no picture randomly (they called it a maintence session) but it was a problem. The tv would power on on its own and do this..
But... This will not resolve your problem if the set doesnt work when normally powered on. I know this first hand as I dealt with philips under warranty on this exact same set not too long ago.
The problem is with the main control board and y sus board. If the set is not under warranty, good luck finding the parts as they are $$$$$.
They replaced mine as they couldnt find the boards needed, I waited a month and said enough was enough.
But there is no simple fix for this one. Combination of 2 problems.
Aug 07, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 37 flat screen
U better have it checked by a qaulified tech
Sep 09, 2007 | Initial HDTV-322 32 in. LCD Television
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
50 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
