Question about Dryers
How do i get to dryer fuses in a maytag mde2400a?
Dryer turns but no heat
    Problem Solver:
  • 8 Answers
Don't believe dryers have fuses, what probably happened the electric coil is burn't out, you'll have to take it apart to check
Posted on Nov 11, 2008
Why won't my dryer heat?
check the following:
Heater element and connections...With an ohm meter check for an open coil
Temperature select switch
Wiring
Jun 25, 2014 | Maytag MDE2400A Electric Dryer
Electric dryer with no heat sometimes.
Electic dryer, ne heat problems could be the result of several problems. The attached link discusses each probem and provides a solution.
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
Jan 23, 2011 | Maytag MDE2400A Electric Dryer
No heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 25, 2010 | Maytag MDE2400A Electric Dryer
Maytag Neptune dryer model # MDE2400AW, is running but has not heat. I need instructions on how to take it apart and fix it. Also where to find parts from. Thanks,
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 12, 2010 | Maytag MDE2400A Electric Dryer
Dryer not heating
There is a heating element or thermal coupler that go out on Electric dryers.
May 29, 2010 | Maytag MDE2400A Electric Dryer
Heat elements
Well it's this simple, IF, it is the SAME Wattage, and IF it has the same Electrical FITTINGS, then YES it can be interchanged. Otherwise NOT.
Apr 19, 2010 | Maytag MDE2400A Electric Dryer
My Maytag MDE9206AYW runs but won't heat
Had this problem right before Christmas on same dryer. Mine is 9 years old.
Lint had built up in the exhaust hose between the dryer and the wall. Vacuumed it out.
Runs like a champ now.
Jan 18, 2010 | Maytag MDE2400A Electric Dryer
I have a maytag legacy series that intermittently heats/.Do you know why?
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Aug 04, 2009 | Maytag MDE2400A Electric Dryer
Dryer has no heat
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 25, 2009 | Maytag MDE2400A Electric Dryer
Magtag Dryer MDE2400 Dryer won't turn off
On our Maytag dryer, the looping marquee lights mean that the dryer is in "wrinkle" mode. This means that the wrinkle mode has been selected. In this mode, the dryer continues to rotate on and off after the heat cycle has ended. It does this to keep the clothes from wrinkling -- and it displays the looping lights.
Jul 24, 2009 | Maytag MDE2400A Electric Dryer
Dryers Logo
80 people viewed this question
Top Dryers Experts
