Question about JVC Cybercam GR-D70 Mini DV Digital Camcorder
Camera Says ' Condastion Problem Remove Tape'
Alright. My Camera Will Only Now Run In Mermory Mode And Will Not Record Film. I Sent It Away To Get Fixed They Had To Replace The Whole Mini DV Drive Thing. Cost Me 300 Dollars. And Yet Again It Says The Same Thing Any Further Anwsers To My Probelm?
  • Mike Hicks Oct 03, 2007
    Where is the moisture sensor?
Clean the moisture sensor
Posted on Oct 03, 2007
In playback my camcorder stops and 31:11 flashes. Any ideas?
This most likely means the taps is jammed.
You can try and get the tape to eject. To do this, remove your battery from the back of the camera. Also if your camera has another small battery under the LCD (the size if a nickel) remove it too. Wait 2 minutes. Then, plug the camera in with the power cord. Try changing the camera from playback to record mode. The tape should eject at this point. If this doesn't work, try it again but this time start in record mode and change to playback after plugging it in.
I hope this helps.
Mar 31, 2011 | Cameras
Tape will not run
The "will not run problem" was solved by replacing the CR-2025 Lithium battery. The eject symbol continues to appear sometimes and I can remove it and continue operating the camera by turning the power supply "Off then On" again. Camera is now running a recorded cassette but quality of picture is low.
Jan 14, 2010 | Sony Handycam CCD-TRV68 Camcorder
How do you switch tape speeds to LP on a Sony Handy cam TRV 240
You can set tape speed SP or LP in record mode only and can not change it in playback mode.
To set tape speed, turn camcorder in camera mode and go to Menu and set SP or LP in record speed option.
Jan 03, 2010 | Sony Handycam DCR-TRV240 Digital Camcorder
Message saying "Protection!" on the screen of the video camera.
try to RESET the camera. try to find it on the camera. good luck
Sep 27, 2009 | Samsung VP-D103i Mini DV Digital Camcorder
Dont know how to use the harddrive with camera
Make sure you turn your other settings in the menu while in camera mode to ext, both or chain. Ext. mode, means pushing record on the camera makes the hard drive record, but not to tape, Both means that both tape and hard drive will record, Chain means when you run out of recording onto tape, the hard drive will automatically start recording as the tape runs out.
Mar 25, 2009 | Panasonic AG-HVX200 Mini DV Digital...
Won't record to tape
Sounds like the tape isn't getting contact with the video head.  It could just need an adjustment.
Sep 16, 2008 | Panasonic AG-DVC30 Mini DV Digital...
'Remove the Tape' message
if you havent found a solution already, basically it means your camera is screwed up and has dirt or something inside it. so you have to take it to a service centre. :)
Apr 14, 2007 | Canon MV800i Mini DV Digital Camcorder
Record button doesn't function
You may want to check the record lockout safety switch located on the tape. This button can get moved by accident and the camera will refuse to record on that tape. Also, be sure the camera is in "video" mode, not "photo" mode. Some of Canons camcorders have a digital still camera mode which stops the camcorder from functioning because the photos are being recorded to a memory card and not your tape, please check this swithc as well. Good luck. Joe Weibel customelectronics.org
Feb 26, 2007 | Canon Elura 65 Mini DV Digital Camcorder
JVC Cybercam GR-D70 Mini DV Digital Camcorder Logo
93 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
