Question about Maytag MAV4755A Top Load Washer
Machine vibrates excessively during spin cycle
Washing machine vibrates excessively on the spin cycles. The machine is level. I jut moved the machine from my old house to a new house and it has been vibrating ever since. How can I fix this? It worked fine before.
  • 4 more comments
  • Anonymous Aug 02, 2008
    Washer vibrates excessively in spin cycle
  • Anonymous Mar 15, 2014
    The tub seems to shift while rotating
  • Anonymous Mar 16, 2014
    After moving to a new house, the washing machine vibrates excessively likes it's out of balance, though it's not out of balance. The floor is level and the washing machine is level yet it still vibrates when it spins. Perhaps something broke or came loose during the move?
    vibrates so badly the machine moves, can't spin in fast cycle
  • Anonymous Mar 20, 2014
    when the machine is in spin cycle it vibrates very badly may be unbalanced
  • Anonymous Mar 27, 2014
    machine is level laundry iswet after spin cycle
  • 641 Answers
Open washer's cover and look for a released or a malfunction shock absorber. Good luck!
Posted on Sep 04, 2007
Spin vibrations
Make sure the legs on all four corners are down tight and even level the machine with this 4 pads. If the machine is level it will vibrate less, and then not all machines are completely quiet when working, especially on spin cycle..
Jan 22, 2014 | Kenmore Washing Machines
Washer moves during spin cycle
If this is a newly installed washing machine have you taken out the four big bolts on the back of the machine? It holds the drum to prevent it from moving during transportation when it was delivered. if machine runs during fast spin it will make the machine vibrate heavily causing it to move
May 27, 2012 | Westinghouse WWS833ES Super Capacity Top...
Excessive vibration during spin cycle
Plz check for the ground level is equal.weather its normal means u have to check the shock obsorber
Jun 06, 2010 | Maytag PAV2300 Top Load Washer
Maytag Washing Machine Out of Balance Even When Empty
the machine is not level... put a level across front back sides to check adjust legs leveling bolts as needed.... also is the machine installed on a carpet floor??? if yes put a sheet of plywood under machine so it wont "bounce" on floor.
May 15, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Chck to see that all (6) suspension springs are still attached. Check the plastic snubber ring below the mechanism and above the base plate for cracks or contamination.
Mar 07, 2009 | Maytag Performa PAV2200
Washer moves during the spin cycle
Due to strong vibration during spinning definitely the machine will stop. All you have to do is to check your load if equally distributed from the tub. To eliminate the vibration and the movement of your washer you need to align the four legs of your washer using level tools. Just put the level on the top of the four sides (front side, left side, right side and backside) then make necessary adjustment if needed on the 4 leg of the washer. Also check the water level of the balancer and the mounting position from the top of the tub.
Jan 31, 2009 | Whirlpool LSR5132PQ Top Load Washer
Vibration during spin cycle
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 13, 2008 | LG WM2688HWM TROMM SteamWasher
Roper RAX7244EQ1 Vibrates during spin cycle
Dear customer
Please perform the following checks
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Please rate this,Thank u
Nov 21, 2008 | Roper RAS8445KQ Top Load Washer
sure..start by re leveling the unit, with a standard carpenters level.
Mar 02, 2008 | Maytag Atlantis MAV5000
Maytag MAV4755A Top Load Washer Logo
940 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
