I installed a new ink cartridge,but it doesn't print anything i don't know why thanks .. Maria..
    Scholar:
  • 126 Answers
Maria,
Sorry, I have to ask, did you remove the proctector plastic off of the new cartridge? This is a small thing that is often overlooked.
Posted on Nov 11, 2008
The printer wont let me do anything because it says I have an alignment problem and to take the tape off of ink cartridge but there is no tape! Its not a new cartridge I don't know what its talking...
May be dry the ink or refill ink cartridge so , it could't properly ink out the nozzle. If possible u can batter manually clean the print head. Then try to it. Otherwise need to change the ink cartridge.
Jun 13, 2013 | Office Equipment & Supplies
My 8 yr old hp LaserJet 3030 printer cartridge is printing extremely light. Just got a new cartridge and it is not much better! I can barely see the ink on the paper. Any ideas how to fix?
Forget buying a new toner cartridge and don't bother re-installing anything - This is a power supply problem - The electrolytic capacitors fade away after a few years of power on and the high voltage to the printing engine drops too low.I tried a new toner cartridge - no help - re-installed drivers - no help.If you can handle a soldering iron or know a friend who can, replace the following capacitors on the power supply board on the LHS (power cord side). Make sure you use low impedance 105 degree power supply types. Warning - high voltage !!! power cord out and wait 30 minutes before touching anything.
C374 341 503 529 (47uF/35V), C526 (1uf/50V), C506 (0.47uF/35V), C515 (100uf/50V). All the others tested fine in mine. Also make sure you install them the correct way around!
Now I have "black as black can be" prints just like new and I can set print density back to 2 not 5.
Apr 24, 2012 | HP LaserJet 3030 All-In-One Printer
I put new ink cartridges in and now it doesn't print anything.
This may sound silly, but I have done this as well. New ink cartridges are shipped with "covers" that should be removed prior to installation. Please verify that these plastic covers have been removed. This is the most common cause of this problem. The covers look like transparent tape.
Update this with the results of your examination.
Thanks,
Dan
May 29, 2011 | Epson Stylus C86 InkJet Printer
240c series rinter words are faded when it prints
Try cleaning the print head using the front panel of the printer. If it doesn't work, remove the ink cartridge and clean it with lint free cloth or cotton swab using distilled water. Don't touch the gold part of the ink just press the cloth gently. Install the cartridge again and try to print.If still having faded pictures replace the printhead of the printer.
Apr 23, 2011 | Office Equipment & Supplies
Kodak ESP 3 doesn't print black ink!
Forgive me for asking this, but roughly speaking about 80 to 85% of problems involving ink or toner are resolved by the following:
Are you using a manufacturer’s factory new ink cartridge or toner? I
f you are using a refilled (worst possible choice) cartridge , toner or ink, or third party cartridge (2nd. worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Feb 27, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Canon Pixma ip1500, bought new ink, cleaned print heads with alcohol, still not printing
Did you buy factory new Canon cartridges or third party cartridges.
If you are using factory new Canon ink, call Canon about their defective ink.
If you are using anything else, want to bet there is no such thing as a warranty.
Don
Feb 27, 2010 | Canon PIXMA iP1500 InkJet Photo Printer
My black ink will not print. Do I have to have
The larger of the two black cartridges is used for text only printing.
The saller cartridge is used for black in graphic images or pictures.
This saves you color ink . It allows you to put the black ink on the image without making the color inks blend the black ink.
Don
Jan 31, 2010 | Canon PIXMA MP780 All-In-One InkJet...
I have installed new ink cartridges but when I print, no text appears on the page and the images are in pink/red and very faint. I have tried cleaning the head and checked the nozzle but no change. Anyone...
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
Don
Nov 30, 2009 | Epson Stylus C66 Inkjet Printer
Error message - no ink
Hi Maria,
Try removing all of the ink cartridges again. Open the cover and remove all of the inks. Close the cover and turn the printer off. Leave it off for about 30 to 45 secs. Turn it back on. Install again the ink cartridges. Check if it will charge after closing the cover.
If it still says that ink need replacement, check your lcd panel. Usually it will tell you what ink cartridge needs replacement. This might be a faulty ink cartridge.
Sep 09, 2008 | Epson Stylus Photo RX700 All-In-One InkJet...
Sanning problems for printer PIXMA MP 160
some printers can detect that the cartridges are refilled based ona barcode or scanning of the cartridges. Does this Cannon have ink tanks or ink cartridges. If it has intakes then the print head needs to be cleaned wth rubbing alcohol and a q-tip. If they are cartridges then it would be good just to buy the original cartidges. As far as the scanning goes this can be a direct connection to the printer going through maintenance. If it continues to not scan then you may need to uninstall the scanner. see if the scanner shows up in your scanners area. if not then it will need to be re-installed.
Feb 13, 2008 | Computers & Internet
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
