Question about Panasonic NV-FJ620 VHS/S-VHS playback VCR
Error F04 message displayed
A tape was inserted but wouldn't play, shortly after an 'Error F04' message was displayed and the unit won't eject the tape.
  • 1 more comment
  • panfool Nov 21, 2007
    tape was playing -tried to eject; VCR and TV screen went blank (TV screen blue) and tape wouldn't eject. Showing Error F04. Opened the top and tape is stuck in "play" mode with the flap on the video held "up" by small white plastic arm. Panasonic wants $50 just to look at it.
  • theelk0069 Jan 03, 2008
    Just returned from holidays, same problem, F04.
    HELP!!
  • shrex2000 Jun 01, 2008
    i turned on my video player, tape in it and it starts up the shuts down and shows f04, willnot stay powered up so i can eject the tape
Panasonic K deck F03 or F04 shows in display check loading motor coupling pt no VDP1434 or motor pt no VID12128 £11.95 CHS
Posted on Jan 20, 2007
SOURCE:
VCR won't eject tape
unplug VCR take the top off about 4 screws or more I would say you willmbe able to see that tape is wound round inside you should be able to remove it .
Mar 16, 2013 | Heating & Cooling
Err on display when insert tape, no functions work.
Two things. First there is some damage to the tape transport mechanism. Only a good look around will confirm this. Secondly a faulty mode switch.
Jan 14, 2013 | GE VG4250 VHS VCR
Canon zr700 won't play tape
That is the pinch roller. If it does not press the tape against the capstan, then the tape will not pass the read/write heads. Replace it.
Jun 25, 2017 | Canon ZR700 Mini DV Digital Camcorder
Panasonic VCR NV-HD642 - F04 Error
You sound like you have a K Deck Model. If this is the case F04 means that the mechanism locks during unloading.
The apparent cause of this is the Load Motor timing.
Aug 08, 2009 | Panasonic Televison & Video
Fault F04
F04 is "loading lock". most likely problem is that the timing of the gears in the tape loading mechanism is mis-timed.
Aug 01, 2009 | Panasonic Televison & Video
RCA DVD/VCR model DRC8320
Faulty power-supply symptoms:
The front panel display and buttons are completely nonfunctional and appear dead. The unit will do nothing more than display the following messages on the TV screen:
Interface error
(and or)
Interface error! Turn off the power
If a DVD or VHS tape was inserted prior to the error occurring, you won't be able to eject either from that point further. They'll remain stuck inside the unit until you've completed the repair detailed below.
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Jul 15, 2008 | RCA DRC8320 DVD Recorder/VCR
CAMCORDER GR-DVL167EK
YOUR TAPE MAY BE DAMAGED IF YOU TRY TO OPEN THE CAMCORDER - HOLD EJECT BUTTON DOWN BEFORE ! YOU REATTACH BATTERY THEN READ THE ERROR CODE ? IF IT STILL DOES NOT EJECT .
Sep 10, 2007 | Video Cameras
VCR Tape Stuck
my tape got stuck too, i opened the bottom, then located the mechanism that started the eject program. After turning some wheels the eject automatically started. Try that...
Aug 17, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic NV-FJ620 VHS/S-VHS playback VCR Logo
2,458 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
