Question about LG U8150
How do i resolve the error: use genuine battery. power off
I have a LG VX8100 purchased used, worked fine. Purchased charger two days later. Battery charged some but would not fully charge. After a few days the phone wouldnt charge and when I tried to turn it on I received this message "use genuine battery. power off" and it the phone counted down from 10 seconds and shut down. I took the charger back and questioned store salesman to see if it was battery or charger, he politely gave me new charger to see if that was the solution. Tried that charger for 24 hours and same thing happened. So I purchased new battery and put in new battery and I receive the same error message "use genuine battery. power off" The batteries are both genuine and both batteries were checked in another LG VX8100 phone. Is the phone faulty? Are the battery posts faulty? Did the first charger damage the phone? I purchased the phone used from electronic store, will Verizon fix or exchange for me? Heeelp....
  • 8 more comments
  • Anonymous Aug 02, 2008
    LG8300... no water damage, but suddenly went dead, did count down and now says "use genuine battery".... is there a fix?
  • Anonymous Aug 14, 2008
    i have LG vx8100 same problem with me when i turn on my phone on display phone turn of  10 seconds.PLZ any body tells me what is problem.i really thanks u.my email dikchani@yahoo.com
  • Anonymous Dec 23, 2008
    same thing happens to me its really upsetting when that message pops up
  • Anonymous Jan 16, 2009
    :/ some milk spilled on my phone, but it works enough to put this message up.... Please and thanks for any help!!!
  • Anonymous Jan 21, 2009
    Have the exact same problem. My phone is about 4 years old, but never had a problem before.
  • Anonymous Jan 28, 2009
    I tried the rubbing alcohol and it is still flashing use genuine battery!
  • Anonymous Feb 22, 2009
    hoosier
  • chargers24 Feb 25, 2009
    my Verizon LgVX8300 will not charger it comes up with the message Use Genuine Battery Power off then counts down 10 seconds then cut off after the seconds is up what do i have to do it was working when i got it from a friend
  • Anonymous May 26, 2009
    my lg white cho has the same problem and idk how to fix it
  • Chilombo George Dec 14, 2015
    my lg p880 is giving me the same genuine error message, i followed up the above trend of comments and tried all the tricks the alcohol, the nail polish, the freezer. i had no luck neither worked. could any one help me plesase is there any other altanative?
A temporary fix to the problem is to put the battery in the freezer for a minute and then put it back in the phone and it will turn on just fine! I had an LGVX8700 and it just randomly started happening one day and my fiance told me to try doing that so i did and sure enough it worked. I had to go to verizon at one point to get a new phone because the one i had got damaged and the tech there used the same battery in my phone for the new one and he thought i was crazy when i told him to put the battery in the freezer but he was in for a surprise when he did what i told him and my phone turned on. It's annoying because you have to do that everytime your phone shuts off but i always made sure i plugged it into the charger before it went completely dead.
Posted on Nov 20, 2009
  • carolkay1234 Oct 10, 2012
    Tried the nail polish trick on a water damaged phone and it didn't help, then put the battery in freezer for a minute or two, tried again and the LG flip powered on immediately! thanks for the tips!
I have an En-V 2, same thing happened.
What worked for me was dabbing a Q-tip in nail polish remove and just rubbing it along the 4 contacts on the battery as well as the 4 contacts inside the phone.
This is an old trick that use to work for the Nintendo game system cartridges when the game would **** out.
Give it a shot! I just saved $50 and a trip to the Verizon store!!!!!! (We know how that can be...hehehe)
GOOD LUCK!
MUZAQMAN
Posted on Oct 20, 2008
  • 1 more comment
  • riplz3 Feb 03, 2011
    ill try that because i got the same phone and mine just stopped on me too..it says its charging when i plug it in but as soon as i take it out it say it again
  • Deneva Marie Taylor
    Deneva Marie Taylor Dec 17, 2012
    well know my phone wont even turn on
    it still isent working
LG phones have problems with their connectors; wet or dirty won't work. Take out battery and blow on battery connectors and on charger connectors. Only use alcohol or nail polish on qtip and only if blowing doesn't remove debris or dirt
Posted on Nov 16, 2008
Just take out the batery and hold down the power button for 15 seconds this may work not to sure worked for me
Posted on Jul 13, 2009
  • jinna feea
    jinna feea Jun 20, 2014
    thanks this helped me.
So I am the most untech savvy person I know, and I got my cell to work. I have the LG Keybo, and after dropping my phone in water I got the same message. I must say that if you hold down the "on" button for 15 secs it should work. I tried that last after I tried putting the battery in the freezer, and cleaning it with alcohol - both did not work for me.
Don't be discouraged if it doesn't turn on - this has happened many times to me when usually holding it down for 15 secs works this last time for about a week and a half my phone didn't work. I tried the freezer and alochol again and I tried to get it to turn on for a week and a half and finally it did. So no need to get a new phone it will eventually work. I also have a back up old phone that i just switch when my new one stops working
Posted on Jan 08, 2010
Cleaning with nailpolish totally worked!!! Thank you sooo much! That just saved HOURS of trying to get help through customer service!! THANK YOU SO MUCH!!
Posted on Nov 12, 2009
THAT WORKED!!!! Used fingernail polish remover - couldn't find our rubbing alcohol - cleaned the contacts on battery and phone - and voila it comes on and starts going nuts with all the txt messages and phone messages I had missed! YEAH!!!!! THANK YOU THANK YOU!
Posted on Aug 27, 2009
  • Ron Asmar
    Ron Asmar Jul 03, 2014
    Fingernail polish remover on both the battery and phone contacts worked for me as well. thanks
At times I hate the Internet and times I love the Internet - this is a LOVE time. Thank you all for saving me time and aggrevation. The nail polish did not work the first time so I tried it again and POOF on it came. Bless you!!!!
Posted on Jul 15, 2010
My phone did the same thing, and i took it to verizon and pretty much told me to screw myself. I looked online and someone said alcohol bath. I took the battery out put the phone in a bowl of rubbing alcohol for an hour. THen i let it dry by the window for an hour overnight and boom it was fixed. No more problem
Posted on Nov 25, 2007
Didn't use alcohol, nail polish, or the freezer... When I tried to charge the battery I realized it was trying to power up before I got the "Use genuine battery..." error message. So, I tried the charger, and when the phone tried to power up I pulled the charger out... The phone powered up only to indicate that the battery was dead, and then it began to power down. The second it powered down I inserted the charger again, and it read "Battery Charging". Don't know if this will work for everyone, but it worked for me.
Posted on May 17, 2011
A Verizon rep told me to do the *228 monthly update on my cell to try to prevent this problem. I'm not sure it will work but cleaning the phone didn't work for me.
Posted on Feb 21, 2009
Vhh
Posted on Dec 31, 2011
Ok I just fixed mine, I took it apart and took out the flash and pow works fine
Posted on Apr 09, 2011
    New Friend:
It same problem for me lg lu 6200 it show use geniune battery power off
please help me
Posted on Jan 15, 2015
    New Friend:
My problem is not charging the battery.it shows a triangle with a exclamation mark with korean letters.i cant turn on my phone because it indicate zero battery percentage and shut down, can any one tell me the exact problem pls i covered 4th pin on the battery and turned on the phone.yes it turned on but it says use a genuine battery then shut down. so i am so frustrated thanks
Posted on Jun 13, 2014
  • Damith Wanninayaka Jun 13, 2014
    my problem is not charging the battery.it shows a triangle with a exclamation mark with korean letters.i cant turn on my phone because it indicate zero battery percentage and shut down, can any one tell me the exact problem pls i covered 4th pin on the battery and turned on the phone.yes it turned on but it says use a genuine battery then shut down. so i am so frustrated thanks
None of these solutions are working for me! I have a chocolate touch, and tried charging it with wires from a different charger because mine is lost and I need to use it right now. Now it has the message, and I tried both the nail polish and the freezer trick, neither worked!
Posted on Jul 25, 2011
My son dropped his Chocolate touch in a pool. Well, he dove in with it in the pocket of his trunks. It was in the pool for about 5 minutes. We let it dry out for a week! When we put the battery in it gave us the "use genuine battery" message and powered down. We put it in the freezer and cleaned the connections with nail polish remover and now it is working fine! Thanks!
Posted on Sep 05, 2010
This and other problems, like the phone being stuck in "Car Kit" mode, are due toa couple of shorted pins bottom pins where you connect the charger. Either liquid or dirt (or the pins are physically bent and touching) is causing the short, cleaning them somehow, and then letting the phone dry will usually fix the problem.
Posted on Jul 28, 2008
Are u sure alchohal will work?
Posted on Feb 23, 2008
Remove the battery and ensure the screws are all in place and tight.
Posted on Dec 21, 2007
2 Suggested Answers
SOURCE: lg vx8100 error message on screen: use genuine battery. power off 10 sec cuts off
I took out the battery on a lg verizon phone oops put it back in now black nothing ?? There must be some sort of way to replace the battery that reinitializes it any help
Posted on Jul 18, 2009
Xantrex XPower PowerPack 300 will not charge even after replacing both battery and adapter. What else can I try?
Either charger has an issue or new battery is boogus. Check charger output for specs. Subject battery to a few discharge/charge cycles. If charger is definitely good and battery will not charge fully after a few cycles then you have confirmed that new battery is bogus.
Sep 06, 2017 | AMP Computers & Internet
I have had my zeepad on the charger for a few days now and it is not fully charged. What do I need to do for it to recharge?
Probably, the ac charger unit isn't good anymore. Output charge voltage& current isn't sufficient to drive your battery charge beyond 80% threshold.
Change or replace this with a new one (same ac charger specs please) and charge your tab again.
Oct 09, 2017 | Tablets & eReaders
My trio stealth g2 7" tablet wont turn on
Check for a bad battery, charger in that order.
Each can be gotten inexpensively on ebay. eBayeBay
Sep 04, 2017 | Trio Stealth G2 7 inch Tablet with 8GB...
No flashing LEDs. Joystick and charger indicate full charge.
Time to replace battery - not taking a charge properly.
Aug 21, 2017 | Health & Beauty
Re: Battery Charger BC-45W I just purchased a Fuji JZ500 and the battery needed to be charged. When I plugged the charger into the power outlet, the indicator light (yellow) turned on but after a few...
Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
Dec 23, 2010 | FUJIFILM BC45W Rapid Travel Battery...
I have a 2001 Suzuki SV650. When I purchased it (about a month ago), a new battery was installed. The bike was running fine, but 4 days ago, the battery died. So I hooked it up to a trickle charger, and...
sounds like a charging system. same thing happens with cars when the alternator goes kaput. so i would say check your charging system weather it be an alternator or generator.
Jul 15, 2009 | 2001 Suzuki SV 650 S
Charging lg kg 220 phone
Almost certainly liquid damage to the lower part of the phone!
Depending on your skills, removing the back cover (the bottom lifts after removing the four screws and then you need to twist and tug the top to get the back off) and clean the bottom 1/4 of the phone using a toothbrush soaked in isopropyl alcohol. Then dry completely with hot air, a hair dryer will suffice.
10 out 10 non-charging KG-220 seem here in the last six months were all fixed using this method!
The classic indication is when plugging the charger into the switch on phone, the handset turns off.
Dec 11, 2007 | LG KG220 Cellular Phone
LG vx8300 phone will not turn on
dunno. try to have it on the charger, and at the same time try to push and hold the power button. try it a couple times. my v180 from motorola did that and it seemed to work.
Sep 18, 2007 | LG VX8300 Cellular Phone
Correct procedure for charging battery
read da manual which cms wid da battery on hw lng 2 charge it wen newly purchased. charge wen battery is cmpltly drained.smtimz it may refuse 2 chrg so get a universal charger nd alwz use it 2 crg
Sep 06, 2007 | LG enV VX9900 Cellular Phone
Lg vx8100 error message on screen: use genuine battery. power off 10 sec cuts off
Not exactly a solution. I tried leaving it off overnight and tried it several times after removing and inserting the batteries. I also cleaned the contacts with contact cleaner and a Q tip. It did not fix it. But I just left it off for 2 days meaning to go to the Verizon store and get it fixed or replaced. But I turned it on now and it fixed itself! Model VX8300. Maybe the contact cleaning did it but it had to dry more. You can use a Q Tip dipped in a cup of water with a teaspoon of Mr.Clean. But then rinse it with a water wet Q tip and then dry it with a paper towel. I used contact cleaner.
Dec 06, 2006 | LG VX6000
LG U8150 Logo
34,993 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
George Etukudo
George Etukudo
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
