Question about HP Officejet 6310 All-In-One InkJet Printer
How I can recive fax
I got a problem with my printer HP Officejet 6310 All-in-one.
I can send a fax by I can't recive any. What I can do?
  • haskiewicz Nov 12, 2008
    I can send it but I can't recive.
    Novelist:
    Scholar:
  • 125 Answers
If you can receive you should be able to send. Is the setting on your printer on tone or pulse dialing? I have a 5610 and just plugged it in and started playing. Can you let me know if it dials and if it does what sounds do you hear? If it dials the problems might be related to the tone and pulse dialing. If it doesn't then let me know what and how you installed your software? Is it connected to a PC or stand alone?
Posted on Nov 12, 2008
  • Miles Nov 12, 2008
    Sorry I must crossed my eyes reading the send and receive. Here is what I think you should check
    1. Phone line from the wall socket dirctly to the printer should be in line 1 and not the ext.
    2. Did you do the set up on the printer? During the set up did you turn on the Auto answer mode
    3. If the Auto answer mode is set on, there is an option to answer after a certain number of rings
    4. If the Auto answer mode is off, try pressing the start button when you know you are receiving a fax
    If you are receiving a fax press the start button. I think that should pick up the fax. This is a sort of manual receing of the fax. If you want the printer to receive the fax automatically after a number of rings you need to go to the set up where you first set up the fax. You should set u the Auto Answer to yes and Rings To Answer to 1 or 2 rings. If you don't set up the Rings to Answer, the default is 5 rings. Hope this helps.
How to access the fax log on 6310 HP all in one
Hi ,
click on the hp director icon on the desk top or access it from start ?all programs?hp?hp director then in the hp director click on settings after which you will get the drop down menu ,select fax settings and setup and then click fax log.This is how you can access fax log and then you cal calso receive and send ..
hope this helped you call the best
May 11, 2010 | HP OfficeJet 6310 All-in-One Printer...
HP Officejet 6310 All-In-One InkJet Printer Changed home telephone system and now I can send faxes out but cannot receive?
Hi
Check the following link
CAN SEND but CANNOT Receive
  1. Make sure that the fax header contains the full 10-digit telephone number of your HP fax product, including the area code. To modify the fax header, use the following steps:
    1. Press the Setup button () on the product control panel.
    2. Press 4 for Basic Fax Setup, and then press 1 for Fax Header.
    3. Type personal or company information using the keypad, and then press OK.
    4. Type the phone number, including area code, for your HP fax product, and then press OK.
  2. Dial 1-888-HPFaxme and send a fax to the HP Fax Test Service.
Jan 04, 2010 | HP Officejet 6310 All-In-One InkJet...
Hp officejet 6310 all-in-one send fax configure
1. Press Setup on the front panel of the All-in-One.
2. Press 2 to enter in to Print Report.
3. Press 1 to enter in to Fax Confirmation.
4. Press 1 to turn on Fax confirmation
5. Press 2 to enter in to Image on Fax Send Report
6. Press 1 to turn on Image on Fax Send Report
Jun 03, 2009 | HP Officejet 6310 All-In-One InkJet...
When I copy, send a fax, or scan it turns out HP 6310 all in one
this is a hardware issue..connect the printer to the wall outlet..and then try to make a copy..if its still the same then machine should be replaced..reason is scanner blub is gone bad..
Mar 09, 2009 | HP Officejet 6310 All-In-One InkJet...
Hi unable to recive fax on 6310 AIO
Hi mamoonrashid,
Please click on following link and follow the document, its not for your product, how ever the trouble shooting is the same,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01555971&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Regards,  raj_p5983
Jan 17, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP Officejet 6310 wont copy or fax from top loader. To send a multipage fax I have to send each page separately
When you slide the pages into the top loader you reach a small plastic tab and probably stop there. Push pages in another 1/2 inch or so and you should hear a beep indicating the paper now is in far enough.
Dec 05, 2008 | HP Officejet 6310 All-In-One InkJet...
Faxing a word document
hi, i would like to know if you have an HP officejet 6300 fax icon???if you have try to print the document using the fax icon DO NOT used the normal HP officejet series icon.if you did used the fax icon it will display the FAX dialog box,input the necessary information needed.just follow the window..
i believe you can now send the fax..
send me feedback for further troubleshooting....
Aug 04, 2008 | HP Officejet 6310 All-In-One InkJet...
Fax machine will not fax
can you please mentione the setup of the fax you are using
Jul 05, 2008 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 6310 All-In-One InkJet Printer Logo
111 people viewed this question
Ben Johnson
