Question about RCA D52W23 52" HDTV CRT TV
RCA D52W17 ANTENNA/CABLE ANALOG INPUT
ANTENNA/CABLE ANALOG INPUT broke out of the back of the tv.
Can I replace this? I cannot locate a part number for it.......
Was there ever a Recall on this model TV. i have a RCA Scenium 52" widescreen tv,model #D52W136DB that also had the antenna/cable that came undone.I have the 1st back panel off and need to know, do I need to take off the next panel.
  • Anonymous Jan 12, 2009
    I have the same problem and same tv!! I am trying to fix it myself and get my stuff hooked up but I dont know exactly what part to get.
  • heather_l_by May 01, 2009
    I was just trying to hook up my tv after moving it from one side of the room to another and the antenna/cable input just broke in half! My husband took the back off and it looks like this little box would need replaced. Is there anyone who has any info on this?
Are you looking for this part?
http://www.partstore.com/Part/Thomson/RCA/264658/New.aspx?ModelMfgName=Thomson&ModelBrandName=RCA&ModelNumber=D52W17BYX1
if so, just make sure your model number is on the listed devices.
Posted on Nov 25, 2008
How do I fix the red color on my RCA D52W17 HDTV ? Everything is real clear on the TV but I only get blue and yellow colors, I don't seem to get red. How do I fix this????
if your supplying an RGB signal to this set from a cable or sat box and not using its built in digital tuner id check the connections of the "R" (red) cable input this might have come disconnected
Sep 23, 2015 | RCA Televison & Video
Mintek DTV-260
The Mintek DTV-260 only has a NTSC (analog) tuner. You will need to connect your RCA antenna to a digital to analog converter box to watch TV over the air. Then connect the output of the converter box to your TV.
The common converter boxes are limited to SD output. You might be able to find an HD converter box online. (With the standard converter box, the available outputs are coaxial and composite video.) The DTV-260 has a composite video port; alternatively set the TV to channel 3 or 4 and use the coaxial (RF) input on the TV.
There may be a low-power station that still broadcasts in analog. However these are rare. You will need to switch from CATV to OTA (Air) to check for one of these stations. Analog Cable has different parameters than scanning for over the air signals.
I hope this helps.
Mar 04, 2014 | Mintek Televison & Video
RCA HD52W59 HDTV Plug in digital antenna into air antenna input then run channel scan =0 channels What should I do next??? Mike
Make sure you are connecting the digital antenna to the digital antenna input on the back of the set, then rescan. Most over the air Tv signals migrated to digital transmission and therefore the analog input is mostly for older analog devices. If you still do not get any channels, then you need to make sure the antenna you are using is rated for reception in your area. You can check for proper antenna size and channels available here,http://www.antennaweb.org/aw/welcome.aspx
Feb 08, 2011 | RCA HD52W59 HDTV Projection Television
Hello, I am currently having a problem with my Audiosonic KM0767 Standard Definition Set Top Box. When we first bought it we wired up all the plugs and it worked great. We then moved onto Foxtel...
did you switch the TV's incoming signal to digital antenna? For the cable box it was probably set to cable antenna or analog inputs, not all TV's have automatic switching for antenna feeds. My Mitsubishi has 1 digital and 1 analog antenna input and the cable box will only work through the antenna input if it's the analog antenna input and it's tuned to channel 3 or 4, -(or through a seprate HDMI, PROSCAN, SVCR,or a yellow RCA plug input)- and when the analog antenna input is selected the TV will tune all analog cable channels that the cable service offers if a box is not used. likewise the TV will not tune any channels at all if it's set to digital antenna inputs. It will tune all local channels only when set to digital antenna inputs.
Dec 26, 2010 | Televison & Video
I have a 2 tuner tv. When Cablevision installed my digital cable box, I lost the 2 tuner capability. Is there a special way it needs to be hooked up to get back the 2 tuner capability?
Your cable system is probably QAM (digital cable). The tuners built into the TV are analog and digital OTA tuners (ATSC and NTSC). If you connect the Cablevision box to the component video input (and connect the audio out of the box to the appropriate audio in) on the TV and an appropriate antenna to the coax (antenna) input, you will be able to swap use the tuners in the TV. (See tvfool.com for antenna types and direction or antennaweb.org for directions of the most likely stations to be received at your location. antennaweb assumes an external antenna and is conservative in the list it provides.)
I hope this helps.
(please note, you probably need to get the component video cables. These have 3 RCA plugs on each end (red, green and blue). To carry the audio you need a cable with 2 RCA plugs on each end (red and white). Match the colors as you connect them.)
Nov 05, 2010 | Proview PA-32JK1A 32 in. LCD Television
Which hole do I plug the cable into antenna digital input or ante
Hello ruthharris,
I think the antenna is built in :S dunno exactly may be .. btw there is [Antenna] button on the remote control
You can download the Manual of this TV by Clicking Here
Thank you for using FixYa.
Apr 12, 2009 | RCA D52W23 52" HDTV CRT TV
Toshiba 36" analog TV Tivax converter box RCA Digital Flat Amplified Antenna How do I get signals without cable?
I understand you have;
Toshiba 36" analog tv,
Tivax converter box,
RCA Digital Flat amplified antenna.
You want to get signal over the air;
Connect the antenna to the Tivax converter box.
Connect the Tivax Converter box to the input for the TV.
Turn on the antenna, Converter box and TV. You should get a menu on the tv screen. Follow the instructions and SCAN in the channels in your area by using the converter box remote.
You can see your channels by going to www.tvfool.com and entering your information.
Mar 01, 2009 | Vizio L32 32 in. LCD HDTV
That is an ITC222 chassis and one of the more dependable RCA units built. The "F" connector is the part you're referring to and it's not something that carries a specific part number for that unit. In the shop here we simply buy them by the box and the tuner will have to be removed to install a new connector. The new one will be soldered to the chassis of the tuner and less likely to break in the future. Not something you probably want to do yourself, but at least you'll know what to ask the shop when you're calling around for estimates.
Nov 05, 2007 | RCA D52W19 52" Rear Projection Television
RCA D52W23 52" HDTV CRT TV Logo
1,024 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
