Question about SanDisk Sansa e250 MP3 Player
Sansa e250 cracked screen
I recently bought a sansa e250 player and a few days ago i sat on it and cracked the screen the mp3 seems to work fine, (i can even read the bottom part of my screen). i have called sandisk, and the place i got it from, i have searched in the web for days but i cant find any replacement screen or someone that can fix the problem. i have read similar problems in this place but no one says WHERE to find a replacement screen or someone that can fix it. can someone please help me???
  • 5 more comments
  • KiiNG Nov 05, 2007
    my screen is seriously cracked. cant see anything except some light through the cracks. the sansa works fine though, i can hear the radio and what not..but i never know what im doing because i cant see the screen!...where or how do i fix the screen?
  • teen boy Dec 26, 2007
    I was sleeping with the sansa in my ear and when i woke up it was in the floor with a big crack in it. I dont know what to do to get a new screen. plz help me figure it out.
  • Anonymous May 28, 2008
    same ****, it sucks there is nowhere the screen is connected and irreplaceable the only solution that worked for me was to get a new one with a warranty
  • junemc Jun 03, 2008
    I cracked the internal screen. Is the screen replacable?
  • Anonymous Sep 25, 2008
    me to i was charging mine to my 360 one night then i wake up and found it on the floor with a small Y shaped crack then i turn it on to see that the LCD screen is f**k*d up
  • Anonymous Nov 30, 2008
    my screen is craked 2
  • Anonymous Jan 05, 2009
    I have the same problem.... this is very frustrating. i can play all my music but i cant see anything on the screen.
I've tried to get a replacement LCD for my SANSA, impossible so far.
There are some PARTS/REPAIR SANSA's on ebay, but must of them with the same problem. There was also a working LCD, I just fail on bidding.
If you can get a working LCD, the replacement is possible with a blower, directing heat to the specifyc connectors area, you can remove the broken one while the glue (some kind of silicon) is warm and flexible, you have to be careful when putting the new one, pins must be aligned, also you should do that whith both (broken and wkring) at the same time, so then you can use the glue still on the pins (golden connectors) area.
I got to remove the broken one and noticed (with my fingers) that the silicon can be used again, but since I didn't use a blower some of the pins (connectors) where damaged. Only halve of the process is confirmed.
Good luck, we'll wait 4 your results if you get a working LCD somewhere..
Posted on Dec 26, 2007
  • 3 Answers
You guys are insane of course you can replace the screen thats not the problem the problem is getting the OEM to sell you one screen which of course they won't so you find a really cheap one on ebay or some other aution site that the screen works but some other part is broken and you use that one. this stuff is not Rocket Science guys!!!1
Posted on Nov 10, 2007
Oh yeah solution 1 is genius, if i could i would do it
Posted on Oct 18, 2007
Solution 1 is your best solution!
Posted on Oct 06, 2007
Buy the same player. Unscrew the back cover.there should be more but yet smaller screws at the edge after you remove the cover, remove them as well.now pop off front cover.lcd screen should be exposed pop off screen as well.repeat steps on the new player switch screens. return new player with broken screen.
Posted on Mar 06, 2007
My screen is cracked too. I notice that this is just a cheap plastic layer above the actual LCD. So I am just going to carefully cut it away and get a good snap-on cover from amazon. Here is an example:
http://www.amazon.com/SanDisk-Sansa-Crystal-Plastic-Carrying/dp/B0012N21NI/ref=pd_sim_e_title_8
Posted on Apr 02, 2008
Don't bother trying to replace the screen. I just opened up my Sansa E270R and the screen is not removable. It is attached permanently via flexible cable. If anyone knows differently please let me know.
Posted on Dec 14, 2007
It is nearly impossible to remove one from one sansa and be able to use it on another. I agree, the only way would be to get new screen from sansa but they most likely will not sell any. Also, the sync connector, if damaged, might be able to be transferred from one sansa to another but micro soldering would be the technique necessary. I have been soldering for over 30 years, can remove dip components from boards and reuse them else where. the computer stuff is way too fine to do by hand.
just my 2 cents
Posted on Jun 27, 2008
  • Larry Sobelman Jun 27, 2008
    it is nearly impossible to remove one from one sansa and be able to use it on another. I agree, the only way would be to get new screen from sansa but they most likely will not sell any. Also, the sync connector, if damaged, might be able to be transferred from one sansa to another but micro soldering would be the technique necessary. I have been soldering for over 30 years, can remove dip components from boards and reuse them else where. the computer stuff is way too fine to do by hand.
    just my 2 cents
    Problem Solver:
  • 15 Answers
Well, if it still works then just go by that protective screen stuff for digital camera screens and you should be fine. I doubt you can actually replace the LCD screen on the player...might as well buyer a new player then.
Posted on Dec 13, 2006
It's not rocket science that these things aren't built like tanks. "I dropped mine while skateboarding", "I was rock climbing and the harness bent and twisted the player and broke the screen", "I sat on mine and broke the screen", "I stepped on mine", etc, etc, etc. No Kidding. The larger the screen - the larger the flex area. You can push in on these with your thumb quite easily. Not much protection. Of course, Sansa won't want you to replace a component easily and cheaply. I took my son's apart after he broke his (Parkour). You will have to have a very steady hand at micro-soldiering to replace the screen. Easier to pay attention to what you're doing and not break it to begin with. Rocket science? No - just common sense and another (expensive) lesson learned on his part.
Posted on May 27, 2008
Connection issue where snsa dies and restarts
I had this problem a few months ago, what is wrong is, you have a bad driver, something that you can do is switch the USB mode, this should work. If you have tried to the driver and switch the USB mode and it still doesn't work, then let me know.
Good Luck,
Fixer Guy
Feb 04, 2009 | SanDisk Sansa e250 MP3 Player
Sansa MP3 player has frozen screen
With the Sandisk you can just open up the battery compartment and pop the battery out for a second, then if you put it back in and turn the mp3 player on, it should work just fine. This is easier to do with the older ones that take AAA's, but unfortunately with the e250 you need a little screwdriver to remove the battery. (But the other day I used the flat part of a piece of jewelry; you can use whatever you have :D )
Sep 27, 2008 | SanDisk Sansa e250 MP3 Player
Cracked screen LCD
Hello shaffycat,
Sorry to hear about the screen on your Sansa E250 MP3 player. It sounds like the Liquid Crystal Display screen has broken. It's possible that the damage is repairable but to be honest due to the high cost of electronic repair it may not actually be cost effective to do so.
You can contact SanDisk to get service information. They can give you a basic idea of what it would cost to get an estimate on repairs and the average cost. Their webite is http://www.sandisk.com.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 23, 2008 | SanDisk Sansa e250 MP3 Player
Cracked screen
if you have a warranty in the store that you bought your sansa from you can change it or replace it. but if you don't have the warranty you just have to take it to a small store that fix the screens.
Feb 20, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 mp3 player
Yes I have How do I fix it
Dec 18, 2007 | SanDisk Sansa e250 MP3 Player
Is my player messed up or is it napster
Need to keep your msuic svc subscription updated, and resync eveyr 30 days or more
Sep 20, 2007 | SanDisk Sansa e250 MP3 Player
WMP won't detect my MP3
See if this helps: -Close all programmes on your computer. -Turn off your Sansa e250. -Attach the cable into the USB port of your computer before attaching it into the actual e250. -The scroll wheel on the Sansa should have turned on by now. -Then it's just a matter of waiting for a few seconds. -Try opening Windows Media Player to see if it detects your device. Otherwise, be patient. Goodluck.
Mar 15, 2007 | SanDisk Sansa e250 MP3 Player
Sandisk Sansa e250
u should return it wit your warranty
Mar 21, 2007 | SanDisk Sansa e250 MP3 Player
Problem when starting
Hello Devildeiss, Try to format the unit. Follow the steps 6 and 7 of the solution i presented here: http://www.fixya.com/support/t119082-sansa_e270_refresh_database Note that all data on your unit will be erased! But maybe that exterminate with your current problems. Good luck!!! Eduardo.
Oct 03, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
2,746 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
