For some reason I can't print a web page on one sheet of paper (that is if it should fit on one sheet). This happened all of a sudden. Mike
You can check print preview on you browser menu under file , you can adjust setting there before you print the page
Posted on Nov 12, 2008
How do I reduce a page being copied?
scan a copy to pc documents , save to word , use photo shop and reduce in size
print page and then re-scan
Sep 17, 2017 | Office Equipment & Supplies
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
HP PRINTER 5P/5MP REMOVED PAPER JAM. STATUS IS "OUT OF PAPER" PAPER TRA IS FULL.
There is a small switch inside whee the paper is that needs to be set (pressed) against by the paper.
Check to see if the switch was damaged or maybe there is a peice of paper in there yet at the paper tray preventing the switch frombeing pressed by the paper.
Apr 08, 2008 | Office Equipment & Supplies
I have a laser printer 8150n. when i gives 20 print on it. on sheet print after another sheet vacant and third print fourth sheet vacant.. what is the reason
Might be page size mis match> Check paper size in system as well as in printer.> Remove tray &check for paper size.> Clean paper path sensors.
Dec 18, 2011 | HP LaserJet 8150n Printer
The printer only prints half a page then moves to next page and a
Before printing, the printer checks the paper size. If the paper edge guide is positioned incorrectly, the paper may be fed at an angle. If this happens, the bottom of the paper is therefore at an angle and not perpendicular with the paper feed rollers. This can result in the paper sensor not recognising the real page width as it can only detect a certain amount of the bottom of the paper sheet which is nearest to it.
If only part of the width of the paper is detected, the printer considers that the paper width is less than it actually is. To avoid printing on internal parts of the printer such as paper feed rollers, the printer automatically cuts the image to fit the detected paper width As this phenomenon depends on the paper feeding condition, it can be random.
Reload the paper and make sure it is loaded correctly. All the way to the right and the paper guide correctly adjusted.
Feb 04, 2010 | Epson Stylus Multifunction Inkjet Printer/...
HP Deskjet 5150 print is too small
Printers try to fit web pages on a single sheet of paper. If you configure the printer, in the print dialog, not to shrink images and text to fit the paper, it will print on multiple sheets of paper, but the correct size for the images and text.
In a Word document, it depends on what font size you have selected. Most people would rather have the web page print on a single sheet, with smaller images and text than were on the monitor; than tape together multiple sheets for 100% size printout.
Jan 31, 2009 | HP DeskJet 5150 InkJet Printer
HP Photosmart 7550 - Full Page Photo Printing Jams at end
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 17, 2009 | HP PhotoSmart 7550 InkJet Printer
Printer printing very small
You are using Internet Explorer 7 and it automatically tries to fit the whole page in a sheet of paper.
Go to Page Setup and DISABLE Shrink To Fit
You might want to ENABLE the Background to print the lovely images
Nov 25, 2008 | Office Equipment & Supplies
Feeds multiple sheets of paper at once
This usually happens when "paper dust" builds up on the take in rollers. Clean the rollers with cotton and alcohol.
Sep 26, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
