Question about Baumatic B187 Stainless Steel Electric Single Oven
No manual I recently moved into a new house and have a baumatic oven (unsure of model but looks like the B187) yet no manual... I have no idea what the pictures on the left hand dial mean, so therefore have no idea what to put it on to cook, also half of the pictures have started to wear away... I just need a manual, can anyone help me?? or my kids are eating charcoal for the forseeable future... Many Thanks..
  • 3 Answers
The light bulb is the oven light.
The snowflake with 3 raindrops is Defrost Mode (fan runs with no heat to reduce defrost time)
The 2 lines up top & down bottom is Traditional Cooking (heat from top & bottom elements)
The big circle with a fan is the Fan forced Oven
The small line at top only is the Grill Mode
The larger line at top only is the Double Grill Mode
The line up top with the fan underneath is Double Grill with Fan mode
The line on the bottom with fan on top uses the lower element with the fan for delicate dishes
The manual can be found on the Baumatic website - www.baumatic.com.au - select your product which takes you into another page & you will see on the left hand side a link to "View User Manual"
Posted on Jan 27, 2009
When i turn electric oven on the house fuses blow no fan no heat
If this is a new oven, look at the plate on the oven or in the user manuel. It should show the input amperage. Then check the amperage number on the fuse. If the fuse number is lower, that is the problem. To fix it will not be easy. The oven circut needs to be rewired with heavyer gage wire and a larger capicity fuse. This could get expensive.
If this problem is on an existing oven, chances are there is a wiring or switch problem. If you are not familier with electricity here is my recommendation.STOP! and call an electrition. the chances are high that if you try to fix this on your own you may be electrocuted or you may burn your house down.
Nov 16, 2012 | Baumatic B187 Stainless Steel Electric...
My Baumatic B180W-B oven does not heat up. The
If the oven is electrically heated, then more than likely, the oven element has failed.
This is located behind a removeable cover at the rear of the oven.
Feb 21, 2010 | Baumatic B187 Electric Single Oven
My Baumatic oven now displays F4E0 after a power surge, the fan still works but there is no heat.
more than likely the heating element blow but check to see if theres a fuse in line with that element
Jan 23, 2010 | Baumatic B187 Electric Single Oven
Oven does not heat up.
You will probably find that it is the oven element that has failed.
This is to be found at the rear of the oven compartment behind a removeable cover.
Hope this helps.
Jan 01, 2010 | Baumatic B187 Stainless Steel Electric...
Baumatic Oven - Setting the Clock/timer after power has been off.
Hi, You press the second and third button in together, hold them in and use the + or - buttons to set the time.
Oct 11, 2009 | Baumatic B187 Stainless Steel Electric...
Manual
Hey there, You can find a manual on Baumatic's website, at this direct address: http://82.208.58.112/cmd/files/usermanuals-uk/b187.pdf Good luck!
Sep 03, 2007 | Baumatic B187 Electric Single Oven
Baumatic 1870ss steel electric oven
sounds like your element is not wired in properly or its faulty get someone to look at it
Aug 28, 2007 | Baumatic B187 Stainless Steel Electric...
Baumatic B187 Stainless Steel Electric Single Oven Logo
921 people viewed this question
Top Baumatic Ovens Experts
ashburton
Starnley Johnwells
Starnley Johnwells
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
