Question about Bernina Activa 130
Thread bunching underneath fabric on Bicor VX1005 mahine.
HELP!
  • Anonymous Nov 15, 2008
    my bobbin tension seems off but I am installing the bobbin as I always do.
  • Dalkatz52 Mar 02, 2009
    I have the same issue with my machine, I'm about ready to toss this peice of **** out the window. I have had the same problem for years. Thread keeps bunching up, winding around the bobbin. Ruining my garmets. Something must be defective in this machine because we are all having the same issue. NOW, what do i do to fix this problem ???
    Sometimes it works other times like now.... it doesn't.......
The impulse is to blame the bobbin, because that's where the thread bunches. But the problem is probably with the top thread tension. The tension is too loose, allowing the bobbin to help itself to all the thread it wants. Retrace the path of the thread from spool to needle and see if you missed anything. The instructions in my VX1005 manual are not clear. I had to try a couple of paths before I got it right. Make sure the spring in the tension disk setup is moving freely. You should feel a fair amount of resistance when you pull on the needle thread. Hope this helps.
Terry
Posted on Jan 31, 2009
Not fixed and not paying for advice
Posted on Nov 12, 2008
When I sew I have thread bunching up underneath the fabric, I've changed needle size, thread, bobbins and cleaned out around the bobbin holder. I'm frustrated and out of ideas.
Susan--
Easy peasy, once you know the problem and how to fix it. It's called "bird nesting" or "thread nesting" or what I refer to as thread "barfs."
Install a brand new needle.
Remove all the thread from the machine.
**ALWAYS RAISE** the presser foot and rethread the top thread.
Verify the top thread path is correct.
Install and thread the bobbin case, make sure it is correct.
Set the top tension to the midway point.
Now retest your machine. Birds nests gone? You may need to tweak the top tension because the factory standard changes due to age and use.
FWIW, problems appearing under the fabric are an issue of the top thread. Thread problems appearing on top of the fabric is a bobbin issue.
What causes Bird Nests Superior Threads
Birds nest under the fabric big loops of thread top side looks good...
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
Mar 25, 2017 | Sewing Machines
Why is sewing machine thread gathering under fabric?
adjust the tension to a appropriate setting,
See the video here.
Sewing Help Sewing Machine Problem Thread Bunching Under Fabric
The knob and its location can differ based on the model of your sewing machine.
Oct 29, 2016 | Sewing Machines
Thread on my consew 225 keeps balling the thread on the bottbottom
Sounds like bird nesting. The upper thread accumulates under the fabric creating a series of loops and knots.
First: Install a brand new needle and make sure it is installed facing the correct direction. (A new needle is the least expensive fix for most sewing machine issues.)
Second: Remove the thread. RAISE the presser foot and rethread from the beginning. Make sure it is threaded correctly (consult the owner's manual).
Third: Pull up the bobbin thread through the fabric and gently hold the thread tails in your left hand while slowly taking the first couple of stitches.
How and Why to Bring up the Bobbin Thread
Sewing Machine Thread Bunching Up Here Why
https://answers.yahoo.com/question/index?qid=20100303212248AAnRUQA
Why Do Get Bunched Up Thread Under My Fabric
Feb 06, 2016 | Consew Sewing Machines
Thread is getting bunched up in machine
First thing: install a brand new needle.
Second: remove upper thread. RAISE the presser foot and rethread from the beginning. Set upper tension to the midway point between high & low numbers.
These links may be helpful:
5 Common Causes of Birdnests
Feb 04, 2016 | Sewing Machines
Top thread is bunching underneath
bunching underneath is an indication that the top tension is incorrect
switching projects and materials also that attention has to be given to tension adjustment both bottom and top
the catching sometimes indicates that a tension is too tight and is pulling the needle out of line
Jul 25, 2015 | Sewing Machines
Need a manual for the Bicor vx1005 sewing machine
I ordered the manual through http://www.mastersewusa.com but still do not have the download link. It has been almost a week now. The site said it would be in my e-mail in 3 hrs. Well today is day 5.
Feb 07, 2014 | Sewing Machines
Difficulty threading bobbin- thread bunches under fabric. vx1005
I would suggest to check the needle to see if it's damaged
also check to make sure the machine is threaded correctly,,that the thread is in every thread guide
also some sewing machine have a problem with the top thread coming off the thread take up lever
also I would check the bobbin area for lint or any loose threads
also check the top thread tension to see if it's set correctly
also the hook race cover & hook need to be taken out & cleaned & then put back in
some machine have had problems with the hook getting grooves worn into them & need to be fixed or replaced
Oct 08, 2010 | Brother LS-1520 Mechanical Sewing Machine
The tension is off ?? bottom thread bunches
Sounds like it could be! Probably worth trying to readjust it. Are you using a fine fabric too? That can cause bunching.
Apr 05, 2010 | Kenmore 15516 Mechanical Sewing Machine
How do you thread bobbin for Bicor VX1005?
Look through these threading guides for a Brother that has the same features. http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
The above site has a manual, but I not a threading guide. Unless it is the same as another model.
Mar 07, 2010 | Brother LS-1520 Mechanical Sewing Machine
Bicor vx1005 ...thread keeps bunching
Try a different bobbin. Look for one that is a little narrower. I had the same problem and changing to a narrower bobbin fixed it.
Jun 14, 2008 | Brother LS-1520 Mechanical Sewing Machine
Sewing Machines Logo
892 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
