Question about Kenmore Dishwashers
I want to change the color panels on my dish washer door
The dish washer is a Kenmore Model 1107537393
4 Suggested Answers
  • 56 Answers
SOURCE: Kenmore dish washer leaks thru the door, need replacement seal.
I dont know what models but several models leaked thru the soap dispensor in the door.They were recalled. Check the manufacture for your model.
Posted on Jan 26, 2009
  • 246 Answers
SOURCE: changing my door panel for another colors
Well you can get a stainless steel panel cusot-made at www.applianceart.com. They have a lot of options. One of them is stainless. The options are a vinyl sticker, a magnet, static cling or the actual stainless panel. Most are $39 and the metal is $99 I think. Good luck.
Posted on Sep 09, 2009
Daniel S
  • 4323 Answers
SOURCE: I have a Kenmore dish
Hi
The issue is with the door switch that is bad and should be replaced, or the relay for the door on the control is bad and should be replaced. Hope this helps...please post back with the model no. for further assistance.
Daniel
Posted on Jun 10, 2011
I have a loose door handle .what tools do I need and how do I repair it?
Hello;
My name is Peter. I am a retired field service appliance technician.
This is a difficult question to answer because you did not provide a model number. When you open the dish washer door you will see a metal label. Your model number is on this label.
Generally, manufactures use a special screw called a torque screw. The head of the screw looks like a star. It may be a different head screw.
Dish washer door handles are made of plastic. It is not uncommon for the handle housing, the handle or the retention spring to break.
On some dish washers you have to remove the inside door panel to access the handle assembly and on others there is a cover plate for the dishwasher control panel at the top of the inside of the door.
Before you attempt this task - do not go blind. Give me your model number.
Apr 03, 2015 | Dishwashers
Why do no panel lights turn on when my Kenmore Model 587.1625 is latched and ready
The door latch in Kenmore and Kitchenaid isn't of the best design.The spring steel latching tab is needs to push down the black plastic slide mechanism when the door in closed. That slide pushes down on a micro switch which interrupts the cycle when you open the door when the dish washer is running. Take the latch assembly back out. You can insert two compression springs inside the slide on each side of the latch. They are approx 3/16 Dia x 3/4 to 1 inch long. In the hardware dept at Home Depot or Lowe's..The springs will push the slide down hard enough to activate the switch. Right now your dish washer thinks the door is open.
May 17, 2014 | Dishwashers
Kenmore elite quiet guard deluxe
The model number is normally on the side of the door or frame. Otherwise if you unplug your dish washer I would suggest taking the front face off the door and see if you can find a service manual. Those blinks may be an error code
Jul 31, 2013 | Dishwashers
Kenmore model #16761691 leaking at the bottom of the door. Where is the gasket located? Or is it another problem?
does it leak all the time or did it just start?try running it with nothing in it and see if it leaks,if the dishes were racked wrong the water can get deflected and leak out through the door,also,remove the bottom rack,look at the screws going around the bottom part under the wash arm,if any of those are loose it causes a wave in the dish washer and the water leaks from under the door.if it's leaking from one of the corners the gasket could be bad
Apr 17, 2011 | Kenmore Dishwashers
Kenmore 17033 dishwasher will not clen dishes
USE JET DRY and clean the system every once in awhile by running it through a cycle with no dishes and use washer cleaner for that model.
Jan 07, 2010 | Kenmore 24 in. 17033 Built-in Dishwasher
Kenmore dish washer lights up but will not start wash cycle.
turn off your dishwasher then try it again ok
Feb 27, 2009 | Kenmore Dishwashers
Jan 26, 2009 | Dishwashers
Kenmore ultrawash dishwasher
little nip Most likely the problem with your dish washer is one or more pads on the control panel are shorted. To fix it the control panel has to be replaced. If you are going to do it yourself, I need the complete model number (on the door frame) and the color for the panel. Then I can find the best deal for you. Gendos...post back
Feb 01, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
