I have a Acer Aspire 6920 laptop with the Cine Dash Media Console. It is no longer responding to touch. It is showing the volume is at its highest setting and the light indicator is on mute when actually the laptop is not like that at all.
  • 1 more comment
  • Anonymous Nov 20, 2008
    yes i have same problem but what to do?
  • hmnow Dec 10, 2008
    Same problem with Acer Aspire 8930!
  • Anonymous Dec 17, 2008
    I'm having the same problem with my acer 8930 and i only had it for 3 weeks now. when i run my finger along the console the vol doesnt go up. i have to go into the system under sound to adjust the vol.
I had the same problem with my acer 8920 but I needed to keep the battery out for about an hour and then everything was good!
Posted on Apr 05, 2009
Wilsonalbany (and all others with this problem),
There is a trick to resetting the CineDash. Remove all power (turn it off and remove the battery) for more than 10 seconds.
That gives it a sort of manual reboot.
*Should* get you back gliding in no time…
Posted on Dec 10, 2008
Hey there! Can anybody help me about my acer aspire 8920g media console is does not work, it will response by touch, showing lights on etc. Play button, volume, nothing does not work. I have try reboot...
I think I have managed to solve this problem
POWER ON THE LAPTOP
whilst its booting up, you can use the FOLLOWING KEYS TO see picture on the screen:
FN + F6
Whilst its booting, also HIT F2, once your in the bios
Go to:
EXIT > LOAD SETUP DEFAULTS
EXIT SAVING CHANGES > SELECT YES
It should then reboot and ... now its working...SO FAR.
After doing this, the screen stays on, operating system loads up fine.
And I have done approx 10 restarts and also approx 5 power downs and then power on.
Hope this helps
Sep 24, 2010 | Acer Aspire 6920 Notebook PC
Hey Sum1 can help me , My Cine dash wnt work :S
The information on the previous posing can be misleading please ignore that. Here is how you can really fix your problem. what you need to do is click on start then right click on computer and select manage once the window opens select device manager and a list will come up on the main screen. Go down the list and expand the keyboards selection and there should be a listing called launch manager. Double click on it and on the properties window click on drivers and it will give you several options, click on uninstall and go through the list if it asks you if you want to uninstall click yes. now that its uninstalled go to support.acer.com click on driver downloads, select notebook, then aspire, and finally 6920. then under the list you can select your operating system, be sure to pick your operating system e.g. windows vista home premium x32. then click on application scroll down and download launch manager. Restart your computer install launch manager and restart again. Congrats your media center counsel should work!
Dec 23, 2009 | Acer Aspire 6920 Notebook PC
Touch pad/multimedia console
I have the same problem. The onliest thing is that I can't adjust the leds with the volume control center either...
Oct 02, 2009 | Acer Aspire 6920 Notebook PC
Acer Aspire 6920 touch volume not working
aright what you gotta do is open up the "launch manager" which enables all the buttons found on the multimedia area plus else where to work perfectly. this even lets you program which applications you want to have when you press the other buttons
Jul 23, 2009 | Acer Aspire 6920 Notebook PC
Unlock volume console
Hi, Try doing the following:
1. Turn of your laptop 2. Remove the battery and the power cable for about 15 seconds 3. Reinsert the battery and the power cable 4. Turn on your laptop.
Your Cinedash Console should be fully functional again
Good luck. Cheryl
May 28, 2009 | Acer Aspire 6920 Notebook PC
My cinedash media console is not working the mute and volume controls are both lit up but no response from either I have Acer aspire 6920 frist my cinedash used to work, but now it stop out of the...
Hmmm just found solution to the cine dash volume control problem.
You need to shut your laptop down. Remove the battery for 10 secs. Replace battery. Boot up and all should be okay.
I have tried this on mine and it worked fine. If this does not work straight away someone else said something about LaunchManager but I didn't have to do that so can't give any info on that.
Jan 05, 2009 | Acer Aspire 6920 Notebook PC
ACER Aspire 6920 Touch Media console is frozen !!
I found this solution on another support blog, its works....
i had the same problem but the answer is so freaking stupid. k tried installing all the software again and again but no cure. Then I read on a forum that i just needed to get the battery out for several second and it worked!!
Summary:
shut pc down,
remove battery (and if plugged in the power cord)
Replace battery, boot it up and all should be fine.
if i does not respond then open launch manager
Dec 13, 2008 | Acer Aspire 6920 Notebook PC
I have an acer aspire 6920 laptop.the cinedash media console isnt responding
Functions are activated by simply tapping
the function with your finger, while you can adjust volume by sliding your
finger around the volume meter.
CineDash reacts on commands with a little “lag”, if you use it carefully you can expect no problems, but for nonchalant usage CineDash will not react on every touch. You also have to make sure that it's turned on for it to work.
Jul 21, 2008 | Computers & Internet
Computers & Internet Logo
278 people viewed this question
David Payne
David Payne
