Question about Canon imageRUNNER C3220 Color Copier
How to print and staple landscape using Canon 3220
Tray 3 has paper installed landscape.
  • 318 Answers
HI
You go to you printer properties(you will find it if you right click on the printer driver under printers and faxes in the controll panel),select printing prefrences,page setup,there is a option for landscape printing.Next to page setup is the finnisher settings,select the stapler option.
Posted on Nov 11, 2008
Landscape copying
check the adjuster in paper tray then close the paper tray.
at pc go to properties select the landscape & print.
Jan 25, 2011 | Canon iR 2016i Black and White Copier
I've had the printer for about 18 months with no problems. I need to print envelopes for the first time, and can't figure out how to do it. Any help out there?
Load the envelope against the right side of the back paper tray.
Load with the address side facing UP and the rear flaps DOWN on the left.
Pinch the Paper Guide and slide it against the left side of the envelope.
Set the Paper Thickness Lever to the right, return to the left after finishing printing.
The Paper Thickness Lever is located inside where the paper come out of printing.
Specify the settingin the printer driver.
Select Envelope in Media Type
Select DL Env. or #10 Env.
Select Landscape in Orientation.
Jan 18, 2011 | Canon PIXMA MP470 All-in-One Printer
We used to have canon imagerunnerr 3100 and recently swapped out for 3220. Everything works basically the same except stapling. On the 3100 if I was photo copying and stapling a landscape document it...
Its only because I care about folksthat I answer questions like this since the chances of have my score diminishing is so great when the feedback rolls in.Ok,gut check tells me you have a different(less capable) stapler(finisher).The old standard has been upper left corner. then came the "zoom" stapler that could move to most anywhere to provide stapling on LTRR and legal.I bet you have a NEW and improved copier, but the finisher has less capabillities.Ask for the old finisher back if thats an option.The old finisher SHOULD interface with your new copier. I hope I helped.... ! :-)
Jan 04, 2011 | Canon imageRUNNER C3220 Color Copier
My canon ir 2018 is asking me to load correct paper in the tray even when the paper size is correct and all the settings are correct. It would print one copy then ask to load paper, i pull out the tray and...
Check the proper orientation of the paper. For example, if you are loading A4 size. In your tray you can find 2 A4 size. Select A4R in you want to position your paper Landscape or A4 if portrait.
To verify also the correct paper size, put your paper on the platen glass. Markings on the two sides of the platen glass shows the correct paper size.
Sep 16, 2010 | Canon imageRUNNER 2000 Copier
How to print document in landscape
This can be set in the properties of the printer mentioned. you can also request the landscape format in the software you are using. for most printers it is found in the TABS: finishing, paper setup.
Jan 27, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Paper goes through tray 1 the image prints landscape on portait
Try placing the business card sheet in the main paper bin instead of the manual feed or adjusting the print orientation from Portrait to Landscape or vice versa.
Sep 25, 2009 | Computers & Internet
Canon iR 3570
Open your top paper tray drawer and there should be a dial on the on the tray drawer (light blue). On there is different paper sizes. Turn it until you get "Ltr" and the paper is going up & down. This should fix the problem. We just had that same problem today and that's what the tech person told us. (Also, this dial only turns in one direction to the left). MMc
Oct 18, 2007 | Canon ImageRUNNER 3570 Copier/Printer
Copier Orientation
clean the three paper selection sensors on the feeder.better you select the paper tray according to the paper orientation instead of using auto paper slect function
Nov 21, 2006 | Ricoh Aficio 2027 All-In-One Laser Printer
Canon imageRUNNER C3220 Color Copier Logo
313 people viewed this question
old marine
old marine
Corne Viljoen
