Question about MSI KT3 Ultra Motherboard
Recognition of 3gb memory
I have a msi kt3 ultra mb and have 2.5 gb of memory, I install 3 gig in and it gives a crazy screen, and won't boot. I take one of the 1gig sticks out and put in 512 then it works just great. The manual says it will take 3 gig. Do you know what my problem might be besides owning an out of date puter.
thanks in advance
  • 1 more comment
  • rsworsham Nov 11, 2008
    they are all the same voltage, same speed, and same type. kvr33x64C25/1g, kingston
    I have amd athlon 2000 cpu, had xp as os and then upgraded to vist 32bit home premium. I think that maybe I will have to resinstall the os.
    thanks
    roy
  • rsworsham Nov 13, 2008
    I have flashed to the latest bios after vista and increased the memory after. I changed the slots and even exchanged one of the memory sticks to no avail. I have always used the 2700 memory with no problems. I was sort of figuring that I might have to reinstall windows period. I have had some other problems before installing the upgrade of vista. I did not clean install so that could be a problem. I have all of the latest updates to my knowledge and they all installed successfully. Thanks for your advice, will try and let you all know what takes place. This weekend, I was sort of planning to reformat and reinstall windows xp and then try the memory and then if that works, try in stalling vista.
    again, thanks for all of the suggestions.
  • Hynek Dec 12, 2008
    I have same problem. 3x1GB Kingston modules not working. Every other combinations (single and double combinations) working fine. If i change bios settings in "Advanced Bios Features" item Quick Boot to Disabled then Memory test is activated. During selftest when checked memory is more 3.14GB then Monitor is black. When Quick Boot is active then 3.4GB of memory is detected. Probably wrong memory size is detected. It is not OS problem WinXP and Fedora not booting with this memory. It must be some Low level MB problem.
    Scholar:
  • 112 Answers
Make sure all the sticks are the same type and speed. If they arn't, that could be your problem. Post the information about each stick of ram and I will try to get back to you. I may forget because of my busy schedule, but a rating and comment will result in me getting an e-mail wich will remind me. Thanks and I hope I can be of help.
Posted on Nov 11, 2008
  • Curzan Alexain
    Curzan Alexain Nov 19, 2010
    yeah i am having that exact same problem soon as i configure for 3gigs of PC2700 it locks when trying to boot if i do 2gig boots fine and will use a lower size stick 256Mb for 2.256gigs an will boot so i know the socket is working so what is causing the hang at 3gig?
    cofigured with AMD Athlon 3000 xp
    3 Kingston 1gig sticks of ram
    Nvidia 6800gt agp
    any suggestions?
    Scholar:
  • 126 Answers
Are you installing the correct memory type? I have the same motherboard, make sure you are using PC2100 DDR memory. I assume you are using 3 1 gig sticks of mem is this correct?
  • Slick54 Nov 13, 2008
    Hello rsworsham,
    Did you have the problem before you upgraded to Vista? If not you have been plaqued by the wonderful vista bug! If this is the case, try doing all the updates for Vista, do them a couple times, not just once. Let me know how it works out.
MSI 760Gm-p23 version 3 Fx Desktop athlon II 640 cpu ,deskstar 500 gig 7200 3.5" sata II 16 MB cache hdd, mushkin 8 gig pc3-10600 essential ram, LG L49-8020 oem sata dvd rom post no issue but wont boo
make sure that the cables are right and are good make sure that the power cables are in the dvd and hard drive two cables to each one for board and one to power supply each
Mar 06, 2013 | MSI 760Gm-p23 Fx Desktop Motherboard Amd...
Tip
Mamimum RAM for User @ 3GB using boot.ini switch on 4GB Physical RAM
The DOS will always take a percentage of the physical RAM on the motherboard leaving the rest for the User. By default the Windows Operating System will use 50% of the physical RAM installed on the motherboard leaving the user the remaining 50% this can be changed using a switch in the boot.ini file
The /3GB was originally meant to be used in systems that have 3GB or more of RAM something that is no longer quite as rare as it used to be Windows XP SP3 will support upto 4GB although on a 32bit (x86) version of Windows will acually see 3.25gb that is the limitation.
However, even if you don't have 3 GB or more of memory, you can still use the /3GB switch. the switch can have any value between 2048 (2 GB) and 3072 (3 GB) megabytes. It needs to be expressed in decimal notation.
The /3GB switch applies to 32-bit systems only (x86).
Example with Windows XP SP3 Home Edition with the recovery console installed this gives you the option of default 50-50% split or the 3GB switch 75-25% split.
The /noexecute parameter enables, disables, and configures Data Execution Prevention (DEP), a set of hardware and software technologies designed to prevent harmful code from running in protected memory locations using the optin switch enables DEP only for operating system components, including the Windows kernel and drivers. Administrators can enable DEP on selected executable files by using the Application Compatibility Toolkit (ACT).
The /burnmemory parameter specifies the amount of memory, in megabytes, that Windows cannot use in this example, /burnmemory=128 will reduce the physical RAM memory that is available to Windows by 128 MB.
[boot loader]
timeout=10
default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition 3GB Switch" /noexecute=optin /3GB /fastdetect
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition " /noexecute=optin /burnmemory=128 /fastdetect
C:CMDCONSBOOTSECT.DAT="Microsoft Windows Recovery Console" /cmdcons
Check out the noexecute and the 3GB switch plus all available boot.ini switches HERE
I suggest that you use AnalogX MaxMem it is a realtime physical memory management program that automatically ensures that you always have as much physical memory available as possible used with the 3GB switch you should never have memory issues ever again.
on Mar 14, 2010 | Microsoft Windows XP Home Edition for PC
I am working on a KT3 Ultra CE MS-6380E ver.1 mother board. The original problem was that nothing run after I pushed the power switch. I thought the Power Supply went out so I replaced the power supply but...
Sounds like the board or processor has failed. You will have checked all the power connectors to the board? Usual fix is a new board, rather than trying to find which component on the board has failed.
manual
MSI MS 6380LE User Manual
specs
MSI KT3 Ultra2 Specs
MSI website details on the board
KT3 Ultra Ultra ARU Motherboard The world leader in motherboard design MSI...
Seems to be a problem board
Questions Answers for kt3 ultra ce ms 6380e
Jul 12, 2017 | AMD MicroStar KT3 Ultra Socket A ATX...
Audio problem
http://drivers.softpedia.com/get/SOUND-CARD/OTHER-SOUNDCARDS/Msi-KT3-Ultra-Ultra-ARU-VIA-AC97-PCI-Sound-Driver-614-01-4150D.shtml
follow this link and download ur driver and check it
Mar 07, 2010 | MSI KT3 Ultra Motherboard
I upgrade the memory of a Dell Dimension Desktop 9150 from 512 MB to 2 GB,The machine accept up to 4 GB..In the BIOS appear the 2 GB but on system in Control Panel only shows 512 MB..Can anybody give me a...
No you don't have to install a 64 bit OS. Only if you install over 3 gigs you MUST install a 64 bit operating system. 800MHZ is fine it will just back down to 667MHZ. your 32bit windows OS will see up to 3 gigs (minus graphics card memory). SO 2 gigs will work fine. Install one stick at a time and check in the OS and bios to make sure each stick works. I would say you possibly have a dead ram stick.
Jun 03, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
I NEED MSI KT3 Ultra CE Motherboard MANUAL OF INSTALLATION
the manual is available for download here. http://www.msi.com/index.php?func=searchresult&keywords=MS-6380E&table=download
make sure you have adobe free reader installed so you can view it..
Regards..
Apr 27, 2009 | MSI MS-6380E (MS-6380E-010) Motherboard
Case wiring
Here is the manual, it will have everything you need to know about your mobo:
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=273
Feb 02, 2009 | MSI KT3 Ultra Motherboard
Unable to get 3GB of memory to work on the motherboard
Hi enj1956, according to the manual the MB supports only,
"one" DIMM of DDR400MHz.
See page 2-7 in your manual.
You can use 3, PC2700/DDR333 / 3, PC2100/DDR266 or
3, PC1600/DDR200 to reach the 3GB.
All DIMMs must be the same memory type & speed.
MSI KT4V (MS-6712) link;
http://global.msi.com.tw/index.php?func=proddesc&maincat_no=1&cat2_no=&cat3_no=&prod_no=505
Good luck enj1956!
Any more questions?
Happy holidays!
Mike
Dec 23, 2008 | MSI KT4V (MS-6712) Motherboard
Ga-k8ns memory problems
did you go into bios and check set up of ram speed etc
Jul 14, 2008 | Gigabyte GA-K8NS Motherboard
MSI KT3 Ultra Motherboard Logo
204 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
