Paper error printer shows paper error or paper size wrong
  • 4 more comments
  • pcombes Dec 02, 2008
    when doing the self test, the paper does not feed and the error light starts flashing. Same thing with page feeder.
  • Anonymous Jan 15, 2009
    I am getting a paper size error when just using the printer as a copier.
    I do have the right size in the tray (8.5 x 11)
  • Anonymous Mar 10, 2009
    try to print anything that is not standard on printer paper size menu but w/in range of papersizes printer should be able to print and get a message from the printer (not on the computer) that paper in tray is wrong size. Only option is to cancel...
  • lathor1 Apr 22, 2009
    The paper does not seem to be feeding correctly, but the error message says "The paper size selected in the printer driver software does not match the paper" when...it's the same exact paper and the same exact application and the same exact printer as when I was using it all day without a problem.
  • ZIMMERMANMIC May 12, 2009
    INCORRECT PAPER SIZE
  • AnnaLq May 15, 2009
    Hi iservice,
    I have the exact same problem as Guest and I have tried your tips but to problem does not go away. And it is onlz when I use the printer as copy machine
    Cheers
    Anna
I hope that this can help someone else as it has taken me all day to fix this issue on a C6180 all-in-one machine. I will ignore the normal solutions to a "paper mismatch" error such as your settings not matching your printing media. Obviously, check these first:
http://h10025.www1.hp.com
If your problem is not solved with the above steps, you have an issue with your "spot sensor" and it needs to be calibrated. Instructions:
1. Press * and # at the same time, and then release both keys.
The display reads "Enter Special Key Combo".
2. Press 3, 2, and then 9, releasing each key before pressing the next.
The display window should read "Service: R0622M" with a revision number.
3. Press the right arrow button once.
The display should read "System Configuration".
4. Press Enter or OK.
5. You will be prompted to enter serial number. Do not enter any information
on the unit.
Press the right arrow button until "media sense calibration" appears in the
display.
6. Load Paper into the unit and then press Enter or OK.
7. Media Sense Calibration process will take place.
It is one of the rare times that HP chat has fixed my printer at no cost and instantly. Here is a full transcript describing my issue and the HP chat solution:
Posted on May 04, 2009
  • 318 Answers
Hi David.
Check the program you printing from.Change the paper size settings in your page setup to the correct paper size.Like in Word go to file and then to page setup.
If you printing from your network system program that is running with a print server ,you have to ask your network adminatrator to change that settings in the system program for you.
Make sure the paper tray settings on the printer menu are also set for the correct paper sizes.
I hope this may solve your problem ,if not let me know.
Posted on Nov 11, 2008
I too have spent many hours trying to get around the problem of paper size wrong ONLY when copying. Printing from a computer doc is OK.
While the problem is with the "media sense calibration" or "automatic paper sensing" function, this may be harder to fix.
I found a simple way around it and can now use my printer for copying. YAHOO.
The easy way to fix is simply to not use the "automatic" option under copy. If you copy primarily letter size, simply go through the copy options and set LETTER as the default. Anytime you wish another type of paper, you may still use those options, but the default remains for future copies.
To override the automatic sensor and set default as LETTER, do the following,
Press copy on the printer
Choose Option 6, PAPER SIZE
Choose Option 2, LETTER'
Then use the down button to scroll all the way down to
"SET NEW DEFAULTS"
Hit OK
This overrides the automatic sensing option and you may still choose other than letter options anytime you wish. Printer will copy with LETTER option if you simply hit copy and you do not have to go through the above routine each time.
HOPE THIS HELPS.
Posted on Mar 13, 2011
5 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: wedding invitations
go here
Posted on Feb 08, 2008
n25an
  • 622 Answers
SOURCE: wrong size paper error Dell 1320C
if you are printing letter size then setting the tray to a4 will produce an error... if you really need to print a4 then go into the driver and set it to print a4 and in print options set it for a4...and set the tray for a4
Posted on Dec 20, 2009
SOURCE: trouble printing envelopes on kodak esp3 printer
Put a few small pieces of tape on the back on the envelope and tape it to the paper, print a test run of the adress and tape the envelope over the adress in the correct spot.
Posted on Feb 22, 2010
seeker5211
  • 1089 Answers
SOURCE: "Paper Size Error: The paper size selected in the
Problem may be the paper tray. You don't say what kind of printer you have and my psychic abilities are nil.
The paper tray has sensors that tell the printer what size paper is in the tray. Make sure that the tray guides are set correctly.
By the way all paper trays are "in" trays.
Print out a config sheet to see what size paper the printer is set up for for each tray.
Posted on Jan 11, 2011
In printer it showing Tray 1 ADD PAPER but [paper is added to the tray still it is showing that error so what to do ? give me the solution.
1.May be because of paper sensor.try to change it
2.may be you have given wrong paper size.u might have give wrong paper size.for ex for A4 paper u might have given some other size like a3. check this it will work for u
Jan 31, 2011 | Panasonic WORKiO DP-1520P All-In-One Laser...
Error message 41.3 paper error How do I fix?
Error 41.1 41.2 41.3
  • Defective connections. Reseat J205,206,207 and laser scanner connectors.
  • Paper multifeed or wrong size paper being used.
  • Paper size selection doesn't match the paper being used.
  • Cassette is overfull or improperly adjusted
Dec 16, 2010 | HP LaserJet 4 plus Printer
Our bizhub 180 is showing prn err
First of all check the error.what error is appearing on the display.if it is about the paper size error then check the paper size in the tray. then adjust the paper size from your computer where you installed the driver, adjust the paper size from printing preferences by right clicking on the printer icon.then in paper size tab you can adjust the paper size. paper size must be the same as in the tray.
Sep 16, 2010 | Konica Minolta bizhub 180 All-In-One...
Keeps giving me the error "Wrong paper Size"
The paper setting is either set to a differant paper size. In which case you can adjust this in the settings menu of the printer on the computer.
Or. You have the wrong paper tray inserted.
Aug 24, 2010 | Dell 924 All-in-One InkJet Printer
Unexpected Paper Size error while printing a3 size paper on HP 9300 deskjet printer
Although you have selected the paper size A3 your printer HP Deskjet show unexpected paper size.....
1. clean the carriage area ...........
2. change the carriage sensor....... If not solved
3. you need to replace carriage unit.
Thanks
Oct 26, 2009 | HP Deskjet 9300 C8136A Printer
Printer is saying the wrong size paper , wont print... Is that a setting in printer or is it software
depends on the printer. check the printer menus. check the printer trays. if they are not set correctly, they will show as wrong paper size.
Aug 06, 2009 | Office Equipment & Supplies
Wrong paper size message
Choose the correct paper size from the setup and change the paper type to 'plain paper'.
Hope this help.
Apr 17, 2008 | HP OfficeJet 7310 All-In-One InkJet...
1,799 people viewed this question
jasbo
jasbo
