Question about IBM Wheelwriter 30 Typewriter
A Rtn Light
What causes this light to light up? I don't have a manual for this typewriter but I just noticed that it has started being lit.
    Scholar:
  • 183 Answers
Hold down the code key and press the "R" key (the key that has A RTN on it) this will turn the light on or off. when it is on, it means the machine is in "automatic return" mode, which means when you get within about 10 spaces of the right margin and hit the spacebar the printhead will automatically return without hitting the "return" key. those lights turn on when the mode, it indicates, has been turned on.
Posted on Nov 12, 2008
What is the code for blinking lights
5 secound till self destruct! ?? While machine is on unplug it an wait 15 seconds for power supply to drain down, this wil cause a hard reboot. Also check and see if ribbon feed is stuck? Get back with me with smallest detail, any thing noise motor movemet, could be caused by loose NUT behind the keyboard??, good luck Bret, just thought of one more could be cemos batt, check manual.
Mar 07, 2015 | IBM Wheelwriter 3 Electric Typewriter Type...
How do i use the memory function on my ibm wheelwriter 6?
Before we start turn it on after it completes is power on just the #1 light should be lit this says the batteries are OK. If they flash replace the batteries and clean the holder.
To store hold the store key while entering an address 1 - 99, type info then press store again.
To play press play with the address.
DickyO
Oct 07, 2014 | IBM Wheelwriter 6 Typewriter
My Nakajima typewriter prints too light - like the keys don't hit the ribbon hard enough to be solid.
Go to nadist.com you will find a manual there with impression control instructions.
DickyO
Feb 26, 2013 | Nakajima WPT-150 Electronic Typewriter
KsMy IBM 1000 power on however it dosen't C Rtn & 1 2 3 keeps blinking, any subgestions
You probably need a keyboard a rebuilt one is 100.00 CONTACT ME @ 216-269-3918
DickyO
Nov 07, 2012 | Lexmark Wheelwriter 1000 Typewriter
2005 Dodge Truck 2500 / Brake lights flashing while truck turned off / dead battery
i don't know why but dodge trucks back feed threw the trailer lights and leave light on
Aug 31, 2012 | 2005 Dodge Ram 2500 Truck
My car has been running fine. Starts each morning once to drive kids to school. An hour later for me to drive to work. But for the last two mornings won't start back up after working 4 hours. I noticed...
Sounds like the alternator is going out the slow way.
Youre kinda lucky because almoat all alternators go out without warning.
Most Autozone shops or places like it will run a test for free.
Good luck,Gary
Sep 23, 2011 | 1992 Honda Accord
Lost our manual for our IBM Wheelwriter 6 Series II. We don't remember how to store information. Can you help us?
Press and hold down "Store" while you type the number you would like to store the information in ( 1 through 99).
The "Store" light will blink and then the printwheel will spin.
When the "Store" light comes on solid you may start typing.
To end the store operation simply press and release the Store key. The Store light will turn off and the printwheel will spin again.
To print the saved job press "Play" and the number you used.
(Note: there are batteries inside the ribbon area of the typewriter that should be replaced every year (AA batteries) If they are missing or dead, the stored jobs will dissappear when the typewriter is turned off.
A copy of the operator's guide can be found here:
http://www.lexmark.com/publications/pdfs/2007/typewriters/Wheelwriter-6-II.pdf
Aug 08, 2011 | Office Equipment & Supplies
Z types a y y types a z -types a / and a few more
Hi:
Make sure the typewriter is not in Lang mode. If the Lang light is lit up then press and hold the code key to the left of the spacebar while pressing the x key. This will cause the Lang light to go out.
Andrew
Sep 02, 2010 | Lexmark Wheelwriter 5 Series II Typewriter
Lights stay lit.
Do all the lights stay on? if so it's not completing the power on reset. Try this remove the batteries turn the T/W off for 30 sec., Restart.
THE MEMORY WILL BE CLEARED!!
DickyO
Apr 12, 2010 | Lexmark Wheelwriter 1500 Typewriter
Typewriter problem
It could be a bad carrier return motor or the carrier is stuck . Turn it off and try to move the carrier left and right it should move with light pressure if it don't try wiping the round rail it slides on with a light oil then work it back and forth a few times repeat until it moves when turned on.
Jul 24, 2008 | Lexmark Wheelwriter 1000 Typewriter
IBM Wheelwriter 30 Typewriter Logo
95 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
