Question about Maytag Atlantis MAV6000 Top Load Washer
MAV6200AWW WASHER DEAD.
I used my machine and its worked fine for several years today it just dead will not start filling and willnot spin or anything. I checked the fuse pannel and made sure it was plugged in and everything still while searching through faq here I learned there was a fuse in the washer and this is sometimes the problem I can not locate this fuse if you could please tell me where I can find it. thankyou
  • 1 more comment
  • confetti May 29, 2008
    washer will not run. have checked lid switch, It's ok
  • taniad Jun 04, 2008
    hi i have a fisher and paykel washer machine gw603 the solinoid needed to be replaced which i did myself but i forgot to put the seal in and the water overflowed in side the control panel i then put the seal in and put it bac together and it worked for 10 seconds and then blew the trip switch in the house
    I then dryed out the control panel and turned the power bac on but the machine wont turn on, no lights nothing the power point is workin as i tested it with a lamp, i am guessin it is a blown fuse in the machine if so where do i locate this thanks tan
  • Magic469 Jun 17, 2008
    I have replaced the fuse on my Maytag washer 3 times and I get one load washed each time before it blows again. Now I'm afraid to replace the fuse because something is causing it to blow. Any ideas/suggestions?
    Novelist:
    Champion:
  • 244 Answers
Its not a fuse its a mains capacitor/filter it is located next to your motor if this is faulty machine wont work it will either be a plastic cyclinder/a metal 1 about 4inches long with writing and numbers on it
Posted on Aug 12, 2007
SOURCE:
Our washer doesn't do a proper spin anymore. I kept getting a nF message on the digital read out. Despite several repetitions, I only got a humming from the machine with seemingly no spin. When the...
Hello, Thank You for using FixYa. I will be helping you today.NF means its not filling. If its the cold valve that's bad the unit will not spin.Check to make sure the water is turned on. If it is the humming you hear is most likely from the valve that is not opening to allow in water. depending on the series this could have two separate valve Assembly's
Thank You and please rate my answer if it was helpful..
Jun 19, 2011 | Maytag Neptune MAH5500B Front Load Washer
Not spinning or rinsing?
After the machine fills the next step is to agitate. By agitate I mean the wash portion. The plastic fin in the middle of the tub rotates back and forth. So, after the washer fills, if the machine does not agitate, but stops dead, you have a broken lid switch. When I say stops dead, I mean no noise whatsoever. If the machine makes noise you have other problems.
If the machine fills, agitates, and then stops dead, the problem is still the lid switch. The next step would be describing the noise so I can more accurately give a suggestion. Problems include but are not limited to: broken couplers, malfunctioning water pumps, and/or defective motors or transmissions. These are the vast majority of the problems, and the others need no mention.
With a model number I can give a part number of the lid switch, and or other problematic parts. Also, I can give you an average price of the parts. With this information you could order it yourself and save money :) The model numbers are located under the lid of the washer. Not physically on the lid, but right under it. Get eye level with the top of the washer and you will see it ;)
May 28, 2010 | Roper RAX4233PQ Top Load Washer
Washer wont spin or drain
did you check to see if there was anything stuck in the pump? sometimes socks and other small articles get dow there and wont allow the washer to spin or drain
Feb 07, 2009 | Frigidaire Washing Machines
Off balance spin/poor wringing
CHECK TO MAKE SURE ALL THE SUSPENSION SPRINGS ARE CONNECTED INSIDE THE WASHER. IF SO, THERE IS A SNUBBER UNDER THE WASHER MILKSTOOL THAT IS MADE OUT OF PLASTIC THAT CAN WEAR AND NOT ALLOW THE SUSPENSION TO GLIDE LIKE IT IS SUPPOSED TO. NOT THE EASIEST FIX DUE TO THE BRAKE BEING UNDER HEAVY SPRING PRESSURE. USE CAUTION
Jan 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
390 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
