Burnham ledv boiler, honeywell primary control will lockout after 1 or 2 cycles. reset, get the same results. works fine during the summer
  • gnome56 Jan 12, 2009
    SOMEONE PLEASE HELP ME!
    My Burnham Led V boiler with a Honeywell control locks out about every three to four hours. If I reset it, it again will go about 3-4 hours before it locks out again. I have had the local technician work on it numerous times. He has replaced every component 2-3 times, with not good results. The furnace is only 4 years old. The problem seems much worse when the temperture gets below zero, but now is happening even with above zero temperatures. It is driving me crazy. I have to get up 2-3 time per night to reset, and can not travel out of town without some checking the house day and night every 3-4 hours. SOMEONE PLEASE HELP ME!
I'm sorry to hear! On mine, another model of Burnham , there's a grey box (approx 4" high by 5" wide) on the front of the boiler. This cover slides off and the control settings are underneath. My manual says low limit must be 20 degrees below high limit else they will lock out each other. I find this to be the case when a maintenance man's "tuned" the settings. My manual also says to set the differential knob to 25 degrees. There are some manuals on the burnham.com site along with their phone number.
Posted on Jan 15, 2009
I have a riello burner 40 it will fire and come to temp but wont refire, goes into lockout
My first guess would be that it sounds like a clogged oil filter, air in your fuel line, is piping overhead, or leak in a fitting or connection causing it to loose it's prime when running.
I have also seen primary controls that are faulty do this, watching the complete cycle of the run time will give you more clues as to when the control actually locks out. Does it lock out during the run cycle as the boiler reaches temp.? If so,check for oil line and suction issues as stated above.
If it locks out on start up after reaching boiler set temperature, if hitting reset right away burner doesn't start and lock out occurs with no motor engaging, check motor (Note: Some motors when HOT will not kick in when powered, but after they cool down naturally they start, motor shaft may also be bound up tight, replacement is necessary) if burner motor spins but does not fire, check for fuel flow to the nozzle, be sure oil is pumping to the nozzle, if it is, clean cad cell eye, and check transformer for spark, if all is good.. replace primary control.
Disclaimer:
Of course all this information is technical troubleshooting information and should be performed by a Licensed Technician, not knowing how to properly test for flame failure can cause injury, fire or worse! Consult a technician in your area if you are not proficient at oil burner repair!
Nov 21, 2014 | Honeywell Biasi B10-3 Boiler ,riello...
How do i reset the lockout
Push and hold the button for 60 seconds. It is in customer lockout because it was pressed more then 3 times.
Apr 25, 2014 | Honeywell R7184A1026 Electric Oil Primary...
Lighting instructions for oil furnace
Air in line. Prime and shut off power to unit at least 1 minute
Apr 24, 2014 | Honeywell R7184A1026 Electric Oil Primary...
I just moved into a house that has a Burnham furnace with a Honeywell R8184G1286 attached to it. The water temp is set @ 190 which is way to hot for us. Is there any way that I can turn the thermostat...
That is the burner primary control, it is controlled by a thermostat somewhere else, could be on the boiler or water heater it will be sensing water temp, and have a probe sensing the water. It may need to be turned back up in the winter, if its heating the house as well.
Jul 04, 2011 | Heating & Cooling
Honeywell T403A1174 suddenly doesn't appear to call for heat
some times inside the boiler on the internal pipework you will see little sensors, on the central heating piping there sometimes is a thermastic sensor on side of flow pipe with a little reset button on ? i guess with the problem you said the poiler locked out and the pipe work overheated ? this is a safety feature on some boilers not, all and easerly reset via this button ?
Jan 31, 2009 | Honeywell Water Heaters
Heating & Cooling Logo
369 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
