My display window on my Onkyo 876 amp flickers when using my Oppo 983 dvd player which is joined by Hdmi.
It's not faulty i n the end.
Posted on Nov 12, 2008
Onkyo TX-SR875 HDMI output not syncing with display
You need more than to be 'good with a soldering iron' on this type of fault. It will be a basic fault but unless you understand the self test modes and video path, suggestion is if no use.
May 21, 2017 | Onkyo Audio Players & Recorders
Component Audio Not working
Hello, where is the issue, audio or video? Your question has mixed messages. Thank you, Onkyo USA
Jun 02, 2017 | Onkyo TX-SR505 Receiver
How do u plug in a dvd player
the onkyo receiver should have hdmi jacks on it labeled cbl/sat,dvd, and so forth. plug the hdmi wire into the dvd and from the dvd to the hdmi jack on the onkyo that says dvd. then run another hdmi cable from the hdmi out jack on the onkyo receiver to the tv
Oct 21, 2009 | Onkyo HT-SR800 System
Onkyo 876 with hdmi from blu-ray sound is fantastic video poor
Get a THX video set up disk (some movies have them on) and read the Onkyo manual for video setup between source and target. I have the BD35 Blu ray and a Panasonc 37" plasma, the pic via the amp was a bit off before the 4 hours of tweaking but now looks fab, after the process tweaks the sound sync needed a bit of work to get it all synched up but it is really worth the effort.
May 19, 2009 | Onkyo TX-SR875 Receiver
Onkyo HT-S6100 to OPPO Dv 980H to Sony Bravia KDL 40W4100
Make sure none of the Digital or Component Input Assignments are programmed, if you're not using them. Set them to "----". This may help. Some of the Component input assignments may over-ride your other input assignments (perhaps even the HDMI input assignments).
Jan 25, 2009 | Onkyo DV-S353 DVD Player
I like the look and price of the Marantz SR 6003 receiver, my only question being whether it suppports DSD data output from a SACD player like the ONKYO like the OPPO DV-980h. In other words can it receive...
Downloaded the user manual for the Marantz SR 6003 A/V Receiver. In this it stated that if a SACD player was connected to the SR 6003 with an HDMI interface earlier than 1.2 then the digital data from the SACD could not be transferred over the HDMI cable to the SR 6003. This implies, but does not confirm, that if a SACD player does provide a digital output on an HDMI 1.3 interface, then SACD audio data can be transmitted to the SR 6003 and, presumably, decoded and converted to 6 analogue streams which are then amplified and deleivered to the (6) analogue output terminals.
I'm fairly sure that the native DSD data from the SACD has to be converted to PCM before transmission over the HDMI interface which is better than nothing. What I was hoping for though was for the data to be transferred in DSD and converted in the SR 6003 directly to analogue, avoiding two intermediate conversions. This ideal solution can be done by only a few SACD/ A/V Receiver combinations, which is silly considering that it is also the simplest. One example, which has made a big impression amongst high fi enthusiasts, is the OPPO DV-980H Universal DVD player (plays any audio or video disc and costs almost nothing) and the Integra DTC 9.8 home theatre processor.
Jan 14, 2009 | Televison & Video
HDMI SOUND
True HD can only work with HDMI interface and is only available on some newer HD DVDs. Check the DVD to see if the True HD encoding is available.
Feb 11, 2008 | Onkyo TX-SR605 Receiver
DVD Connection and Surroundsound 7.1 Onkyo
gotta use rca audio cables in addition to the hdmi on this tv
Feb 09, 2008 | Philips 51PW9303 51" Rear Projection...
No HDMI Output
My configuration:
ZONE 1 (living room)
DishNetwork Dual Tuner DVR Tuner 1 [S-Video out] -> [S-Video in] ONKYO TX-SR875 [HDMI out] -> [HDMI in] Sony KDS-60A3000 rear projection TV
ZONE 2 (living room)
DishNetwork Dual Tuner DVR Tuner 2 [Composite Video out] -> [Composite Video in] ONKYO TX-SR875 [Composite Video out] -> [Composite Video in] Samsung AQUOS LCD TV
Problem:
ONKYO receiver stops sending video signal to my ZONE 1 Sony TV through the HDMI connection. ZONE 2 may still receive video. (NOTE: the issue might be related to the upconverter circuitry?)
Symptom:
I couldn't see any video, but I could hear the Tuner 1 audio through my ONKYO. An important clue is that I couldn't see ONKYO's on-screen display menu on my TV when hitting the [Setup] button on my remote. But, I could see my TV's Sony-based menus and display options.
Solution:
1. Put all ZONES in Standby mode using the remote. Hit these buttons on remote: [Receiver], then [Standby]. [Receiver], [ZONE2], then [Standby], [Receiver], [ZONE3], then [Standby]. You should NOT see any lights on the ONKYO except maybe one red led near the power button.
2. Pull the power plug out of the back of the ONKYO, and leave unplugged for 20-30 seconds. Turning off any power center it is connected to isn't enough. You MUST unplug the power from the back of the ONKYO for 20-30 seconds.
3. Reconnect the power cord to the ONKYO.
4. Using the remote, set ZONE1 to a video source known to be working. If you don't see video, try leaving the power cord off for a longer period.
I know it sounds too simple to work, but that's what brought the video back for me the few times the video stopped displaying. Hope it works for you.
Jan 06, 2008 | Onkyo TX-SR875 Receiver
Change Change Oppo DV-980H DVD player to play DVD's from all regions.
1. Press Setup.
2. Press "9210" in quick succession. A new window should appear.
3. Press "0" to set the Region to R0.
4. Press Setup to exit.
Dec 12, 2007 | Oppo Digital DV-980H DVD Player
 Grubhead
Grubhead
