I have actually got a HF7 150M model but don't know how to use the site!!! Sorry I have checked the filter and the filter connections for blockage - they are OK. The door locked light is on when power button is pressed but washing machine will not start the chosen cycle. I have opened the machine and looked at all the connections - they all seem to be attached. There are a few that appear slightly corroded but none that are unattached. Please help - I've got 4 kids!!!!
SOURCE: Door on the Hoover washing machine, model H130E
make sure the tap is not broken off ,if the tap is good that means you switch is bad, replace it. hope this information could help you.
SOURCE: My front-loading Hoover washer/drier (Softwave
Door will not open if it has water in it.
Lay hose down to get rid of water, then you can open door.
Try the spin with no water in, if it spins, then you have a draining problem
SOURCE: Hoover washing machine front loader, has power,
Hi brennanjodi
I think your door interlock needs replacing. Turn off the power undo the front of the door gasket and that will get you to the lock mechanism. They're about £20 to replace.
Adrian
SOURCE: Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged
drain hose or the water pump. You’ll need to drain the water out of the
base and also check to see if there's something
stuck inside the pump or the drain hose connected to the pump (pump is usually
located at the bottom and towards the back of the washing machine). If the
drain line isn't clogged, you may have a problem with the water pump such as a
frozen pulley or a broken impeller. If that's the case replace the water pump. Please
do accept the solution if the issue is resolved or else revert for further
assistance.
Thanks
Rylee
