Ibm t30 lost sound says driver working - Audio Players & Recorders
  • 6 more comments
  • captbrianhub Nov 12, 2008
    how do I uninstall a sound card and what iam I looking for in a new one THANKS
    how do I uninstall a sound card and what do I look for in a new one THANKS
  • captbrianhub Nov 13, 2008
    Benimur good call the remote speaker works !!!So iam thinking the speakers in the laptop are bad ??? can I get new ones and instrutions for repair THANKS
    Do I need to fool with software if the external speaker works ??? I think it the inturnal speakers ???
    I unintalled Sound max Integrated didital audio In device manger restarted Found new hardware ran that says its working still no sound ???
    So you think it is the speakers ??? I found speakers on ebay also and manules from levono its not easy you need take out 6 or so parts to get to the speakers is that the final descion THANKS
  • captbrianhub Nov 14, 2008
    Hi ACDR I downloaded the driver it said My computer alredy has that driver still no sound??
    Genius:
  • 1,252 Answers
Try one thing restore your laptop some previous date where the sound is working fine, if this also not solved you problem then take it to the technician some due to fault in the speakers , there is no sound
Posted on Nov 14, 2008
    Genius:
  • 1,913 Answers
Http://www.driversdown.com/drivers/8969.shtml
download this driver and install
Posted on Nov 13, 2008
  • 19,396 Answers
Check first that you did not mute the thinkpad by pressing the mute button on the top bar.
Just click the following link: 1ga239ww.exe
say I agree in the webpage that will open, and start downloading files.
Run the installer file after downloading is ended.
  • Ginko
    Ginko Nov 13, 2008
    On an IBM T30 the speakers are aprt of the top cover, along with the touchpad, you need to replace the top cover usually, and this is not a job for absolute beginners, as you have to take apart the laptop.
  • 1,879 Answers
Just to be sure :
speakers / headset work on another computer or audio device
the green jack is where the speaker must be connected
windows volume control is not muted / the level is not set to 0
since the driver is working fine as windows reports, go to device manager and locate Sound Device then right-click on it and select Uninstall and restart your computer.
Posted on Nov 12, 2008
    Genius:
  • 1,550 Answers
You download Thinkpad software installer from the link below
Thinkpad software
This software updates driver and it can be used to uninstall the driver .
    Brigadier General:
  • 6,966 Answers
May I offer an alternative possibility. If the software/drivers checkouts and there are no yellow or red marks on the audio/sound devices inside the Device Manager, then it could possibly be a hardware fault. As a test, pls try using external speakers or a headset.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 11, 2008
  • 2 more comments
  • Louie  Role
    Louie Role Nov 13, 2008
    Hi again,
    Hope you get to read this postback.
    The speakers would be the size of your thumb or smaller. So it would be a matter of lifting the keyboard and/or the top half of the laptop casing. The speakers are readily accessible. Once exposed / removed, the speakers could be checked with a continuity tester (DVM or VOM) to confirm if open. Replacement are available here or better here.
    Cheers.
  • Louie  Role
    guess its go for broke. the only way to verify speaker issue is to gain access/expose them and perform continuity test. though opening the laptop may look daunting, it is actually only the first set of screws that would be challenging. once you get the ball rolling, it would just be a bit time consuming but not really that hard.
  • Louie  Role
    Louie Role Nov 15, 2008
    Hi again,
    Any development(s) so far?
  • Louie  Role
    Louie Role Dec 01, 2008
    Since the sound is present, then the drivers and speakers are working.
    However,as you posted the level is rather low which could point to a
    couple of additional ideas:
    • the new speakers are not an exact match as to the old
      one, the impedance are high. Pls may I ask, were you able to check the
      impedance of the new speakers with an ohmmeter/continuity tester?
      Additionally, does the ratings/specs match the old defective ones?
    • the built-in amp of the laptop is not producing
      sufficient power to drive the new speakers. Pls try again the
      headphones and check if the level is uncomfortably loud if all the
      settings are at max; If yes, then amp is good, if not then amp is weak;
    • it is possible that the headphone jack needs cleaning
      or replacement also. It has a built-in switch that disengages the
      built-in speakers when a headphone is inserted. When the headphones are
      removed, they may not be switching back properly.
  • 13,433 Answers
  1. check sound is not muted
  2. uninstall sound card and update with newest available
Drivers available at
http://www-307.ibm.com/pc/support/site.wss/MIGR-42358.html
  • Ekse Nov 12, 2008
    To uninstall the current sound card drivers
    First open computer management by right clicking my computer and selecting manage.
    On the left side of the window select Device manager.
    Now on the right side of the window click open the + Sound, video and game controllers.
    Right click on the sound card. In my case it looks like this
    Right click on it and select uninstall.
    Now I recommend you restart the computer one the device is uninstalled, ones the computer restarts it will notify you of a new device, in this case click cancel and run the setup file that you downloaded from the page I gave you earlyer.
I have ibm thinkpad T30 series, installed Sound drivers but still sound is not coming in speackers and headphones
Hi
Have you checked that it is not mutted or disabled
go to control panel sound and audio and have a look in there
Nov 13, 2010 | IBM ThinkPad T30 2366 Notebook
I need sound drivers of ibm thinkpad
Are you just looking for general sound drivers for the T30?
Here is IBM's main page for your laptops software and drivers
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-42358
Go down to audio OS/2 and download the driver.
Good Luck!
Nov 09, 2010 | IBM ThinkPad T30 2366 Notebook
I just picked up a IBM T30 laptop. I reformatted the hard drive and installed XPPRO. Everything works fine except the sound. I cannot get the sound to work. I have tried everything I could find. Any ideas?
Hello there:
when you reformatted your laptop any of the drivers that originally came with the computer were removed. if you have internet connection i would go to the website of the manufacture of the computer and download the drivers for the soundcard and also the (vinal ac 97 combo pac) works good for most of the computers.
Also if you have your upddates turned on the updates can also help recover the lost drivers. ok these are just a few ideas that may help get you going if you need more please let me know cause there is still more i can show you ok?
best regards michael
Sep 30, 2009 | IBM ThinkPad T30 2366 Notebook
I dont have sound in my laptop IBM Thinkpad T30...i lost it...i dont know to download it...please help me.....
hi don't tension dear friend
1. If u have a motherboard driver cd u can easily install it.
2. if u no have a motherboard driver cd u should go to google.com
3. please type ur IBM thinkpad model no. in google search option
4. you can easily download it.
if u not solve this problem mail me at mukesh_ibm@yahoo.com
with your ibm thinkpad model no. i will sent sound card driver
thanks mukesh kumar
May 13, 2009 | IBM (01K2154) Sound Card
Where to get vga controller driver and sound card driver.
If you have Vista the updfates will find it automatically.
If not there is universal multimedia controller and the realteck sound drivers are pretty universal so try them to resolve sound.
I assume you went intro device manager, right clicked on the unknown device and updated drivers automatically using the internet. If not try that 1st
Dec 17, 2008 | IBM ThinkPad T30 2366 Notebook
I dont have vga driver for IBM thinkpad T30 2366)
ya i know dis site but it is of lenovi t30 drivers and the problem is that i am not geting the IBM Thinkpad Drivers..Would any buddy give me the site of downloading drivers of IBM Thinkpad T30???
Nov 15, 2008 | IBM ThinkPad T30 2366 Notebook
T 30 sound problem
You should check in my computer and see if your audio or sound is showing.
If it is and there are is an ! OR ? then update driver.
If it shows and there are no markings beside it then I would uninstall and restart my computer if it does'nt automatically start the download then go into control panel add and remove try to install from there.
If that does'nt work I HAVE ANOTHER SOLUTION TO TRY.
Oct 24, 2008 | IBM ThinkPad T30 2366 Notebook
52 people viewed this question
 Grubhead
Grubhead
