Question about Altec Lansing ACS 54 Computer Speakers
My surround won't work.
I hooked up the two surround speakers, and thy pop when i plug them in. This usually lets me know they are working. However, when i plug in the cord from the woofer to the computer that is labeled "surround" nothing comes out of the two surround speakers. How can i get this to work? I also dont know if there is a special hole to plug this in to?
  • 34 Answers
SOURCE: speakers have are hooked up won't work???
goto adjust audio properites and u can sort out all the volume controls there
Posted on Feb 24, 2009
AV Nerd
  • 4 Answers
SOURCE: M602 Speaker Problem,.. Popping Sound
This worked for me on my M604: Try inserting/removing a headphone plug into the jack several times to see if that clears the problem.
The "popping" sound is very similar to the sound that the unit makes when inserting headphones into the 'headphone' jack on the back of the unit.
The jack has a contact switch that triggers a relay inside the unit. If that contact switch is 'on the verge' of making contact, slight temperature changes may cause deform closer to it's contact target. The subsequent capacitance build-up and discharge across the gap could explain the cycle of popping noises after the unit warms up.
Posted on Jul 21, 2009
BNUTZBCRAZY
  • 130 Answers
SOURCE: Short in subwoofer wire - Altec Lansing computer speakers & sub
yes, you can splice the cables and put on a new connector, goto radio shack with the old connector and im sure they will have one you can splice right onto it. ive done this many times with varios equipment "headphones speakers etc" it may take a couple of tries to get the wiring right but if its just one speaker there will most likely be just 2 wires, if you wire it up and it doesnt quite sound right, wire it the other way. speakers will work wired backwards but wont sound quit right so if it doesnt, rewire it and it should. good luck and i hope this helps!
Posted on Jan 15, 2010
  • 53 Answers
SOURCE: speakers are plugged in properly but won't work
Hi Rachelle,
First of all, make sure that the sound is not accidentally muted.
If the sounds seem to play, it means that your speaker cables are faulty or have some kind of break in them. Or, your speakers or the electronics inside them developed some kind of fault.
Unplug the speakers and the speaker cables and test them on another computer. If they work fine on another computer, the problem could be your sound drivers. You could also test the sounds, using a headphone in place of the speakers. If you can hear the sounds fine with the headphones, the problem is with the speakers or the cables.
This may be less likely since the sounds seem to play, but it's still possible that your sound driver is incorrect or not the one meant for your sound card.
Start the Device Manager (Right-click My Computer -> Properties -> Hardware -> Device Manager) and under the "Sound, video and game controllers", see that the sound driver is listed.
Double click the item in that list that contains the word "audio device" in its name. Does Device Manager say that the device is working properly? If Device Manager says that the audio device is not working properly, or if there is a yellow exclamation mark next to the device, or if it says that the drivers are not installed for this device, install the drivers from the CDs or from the laptop manufacturer's website. However, there's an easier way to do this, as given below.
Here's the easy way to get or update your sound drivers:
You could try to use this driver scanning tool, which scans the computer for needed drivers and has an option to automatically retrieve them for you.
You can download this free tool from here or directly from this link.
After you have downloaded the above file, double-click on it and follow the simple steps to install it. Then, when it asks if you want to run it, just answer yes. This is easier than manually searching, downloading and installing the drivers.
If, after trying with the above method, sound still can't be heard, you can try with the System Restore. To know more about System Restore, go to this link.
If none of the above methods worked, pull out your sound card and test it in another computer. You can also try re-installing Windows and lastly try another sound card, if it still fails to work.
Hope that helps,
Regards,
Raspal
Posted on Mar 24, 2010
19messiah65
  • 230 Answers
SOURCE: Computer won't recognize that there are speakers plugged in
The audio device that your system is referring to was the sound card that was installed to your computer. If this error occured after installing Windows Vista then, your sound card might need new drivers to be installed to make the audio work. You can try to download the drivers online for you audio and it will definitely fix this problem.
Posted on Apr 27, 2010
I'm trying to hook up a sharp aquos tv to an rca surround sound receiver and it won't work? any suggestions? I have tried turning off the speakers on the tv....
First thing to do is get the owner manual for each and start checking both settings and actual hookup---usually a surround system will work on all types of sets---when in doubt read the owner manuals.
If need either manual Google that model number with "manual" to try to locate it.
As far as the set goes it may require either a variable audio output source or in some cases the out to be a fixed level.
May 23, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No sound
Make sure the speaker are plugged into the "audio out" ports. Black negative, red positive.
If a dvd players or other system is hooked up, the speaker should hook into that unit, then the unit is hooked to the auxiliary port(s), or the proper ports for each unit: ex: cd/dvd should be plugged into vd/dvd; same for vcr, game system - auxiliary is for pretty much any unit not listed on the backing of the receive - however, some units will still work while plugged into the ports other than auxiliary.
Make sure the receive is selected to the desired device.
If you simply have the speakers plugged into the speaker ports, make sure the speaker themselves are still good - try hooking them up to another source such as a a dvd player equipped with surround sound or speaker adapters that will suffice your speaker wiring.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Jun 28, 2010 | Onkyo TX-SR606 Receiver
Surround Speakers will not work
Perhaps you have the live wire in the wrong connector from the speakers? They should be color coded. I would check that first. And if you have moved, they are most likely in different positions, you'll have to rerun the audio setup for the surround sound. You should have a separate microphone to use for that that plugs in to the system.
Aug 31, 2009 | Onkyo HTR500 Receiver
Center and rear speakers not working
In regard to the rear speakers, my system is an LG and the rear speakers will only work if the format that i'm watching (TV, DVD) is in Dolby surround sound 5.1. Normal tv will not give you surround sound unless it says otherwise, usually it will flash up on the screen at the start of the show. So test the unit with something that you know is in 5.1
Jun 26, 2009 | Audio Players & Recorders
Surround sound not working with PS3..
hook your front speaker wires up to the A side and on the front of it make sure only the A speakers are playing but leave the rear speakers plugged into the B side then hit the listen mode button and you should be rocking
Apr 24, 2009 | Kenwood VR-407 Receiver
Hooking up logitech surround sound to tv.
you need a "y" cable to bridge the output of the tv to the speakers.
Godd Luck
Jan 21, 2009 | Logitech X-540 Computer Speakers
My surrounds are not working right
This will sound stupid but I've made this mistake before (and I usually know what I'm doing...) so here goes.
Read the manual (check HK's website) - specifically the page where it has the diagram describing how to hook up all the speakers. I'd bet you miswired them due to some confusing labeling on the back.
Dec 29, 2008 | Harman Kardon Audio Players & Recorders
How to hook up additional speakers to the TV
If you have a surround sound system, (amplifier and speakers), run the DVD speakers out wires to the amplifier IN. Thi way, you don't even need the TV speakers.
Jul 26, 2008 | Sansui HDLCD3200 TV
Surround speakers don't work
Hello barstep,
Let's go through some steps that will help alleviate your problem. We'll start from the simple to the not so obvious:
1.- Perform a visual inspection on the back of the receiver and verify that all speaker connections (specially the surrounds) are not loose, shorting out another connection or are pushed too deep into the speaker connector so the wire insulation prevents proper contact. If this is not the problem then...
2.- Get into your receiver's "Manual Setup" and verify that your surround speakers are set either to "SML" or "LRG" but not "NONE".
3.- Verify the receiver is not in "Straight" mode, shown on the receiver's display. I f so, press the "Straight" front panel button until indication disappears.
Your owner's manual can give you detailed information to access the setup menus.
Hope this information helps. Let me know if we can further assist you.
cancerags
Dec 30, 2007 | Audio Players & Recorders
Altec Lansing ACS 54 Computer Speakers Logo
81 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Don Hart
Liev Aleman
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
