Question about Acer X221WSD Monitor
Monitor sizzled when turned on
I have an Acer LCD Monitor X221W. When I turned it on this morning, it made a sizzleing noise and will not work at all now. I purchased the monitor on November 20, 2007. Can I get a replacement? I purchased it from the Micro Center in Dallas Texas.
748608 Acerac 22" Wide LCD X221WSD
S/N ETL980B029720016893914
Thanks,
Dennis
    Champion:
  • 293 Answers
Hi...there,
It's seems you've got a busted backlight inverter. Sure you can...you've got a 3yrs warranty for parts.
Send it back for repaired...
Posted on Nov 13, 2008
L246WH Monotr makes a sizzling noise and flickers
Safety note: For best safety practice, unplug the unit immediately. If you want to try and diagnose and/or repair it yourself, at least move it to an open area free of anything that could flame up in case of sparks or a fire.
Mr. McLellen could be correct about the failing solder joints. Since the symptoms increase as the unit heats up, I suspect it is more likely an electronic component failure. The specific symptom you describe is common in transformers with electrical shorts or with a cracked frame. Insects may also be the cause. Some are specifically attracted to warmth and electromagnetic fields. To rule out insects, take sample whiffs around the vent holes on the back of the unit after it starts crackling and flickering. Electrical burns are distinct from most other types, especially roasting critters.
Oct 14, 2012 | LG L246WH-BN Monitor
Acer Monitor Lcd 22 in X221w LCD Monitor Dead.Won't come on when you turn on computer.
You need to check the power secton to see if you do have 5vdc (for logic) and 12~18vdc (for backlight inverter) in the power supply first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 11, 2010 | Acer 22" X223w LCD Monitor
My Acer x221w a monitor comes on for a couple of seconds and then goes blank.you can switch it off and on and it does the same,only lasts seconds. is it fixable
leanish, Yes, your lcd is a viable candidate for REFURBISHMENT! Only I left out the word "MAYBE". YOUR words "on for a couple seconds" is the clue that places you into the "viable" catagory! Your stated symptom is CLASSIC of many thousands of other lcd owners whose screens are now BLACK and lifeless. Now for the FIX it part. First thing to do is visit YOUTUBE! FYI to help you make a decision to do the repair yourself or contract out the work to get your x221w back ONLINE. Search and view the longer vid clips of "lcd monitor disassembly","lcd monitor repair". Learn what internal components on the "switch-mode-power-supply" and "inverter circuit" cause the CLASSIC symptom refered to as the BLACK SCREEN OF DEATH. Also research my other posts in my profile on how to do the "rude&crude" flashlight test that every lcd display owner should know how to perform and interpret when the BSOD strikes without warning. It's not hard to do and you would then have provided another 2 lines of useful information along with AGE and or approximate total "ON" hours of use the unit has seen since the purchase date. One more thing that OWNERS fail to state is if the unit "is" or "is not" under warranty by the manufacturer! Warranty work is the very first thing to check because it's FREE!!! Well, anyway, I wish you good luck in your quest to fix your unit. If you need additional info you can always do a repost to fixya, or lmistyrel@aim.com I'm 12fixlouie on fixya If this response was of some help then please rate it on fixya. Bye for now.
Nov 10, 2009 | Acer AL1706AB LCD Monitor
I have an Acer Travelmate 5520. Last night while working the screen started to flash and then went totally blank. I powered down and back up again and the same thing happened. The laptop is running but the...
Most likely the inverter module for the lcd screen has failed. If you can hook up your laptop to an external monitor, you will be able to make sure that the rest of the laptop sill functions.
An inverter is a inexpensive part, $10-15 dollars, but requires that the lid be disassembled somewhat to install it
Oct 21, 2009 | Acer TravelMate 5520 Notebook
HOW do I remove the keyboard on a Gateway Laptop Model T-6330U, I spilled juice on keypad and heard sizzling when I restarted, and monitor fadded out. An external monitor works fine, and computer boots up...
You could send the laptop in for repair but it could be quite pricey, it sounds like the LCD is toast. If your keypad still works using an external monitor then you won't have to replace that.
Sep 20, 2009 | Gateway T-6330U Notebook
I VE GOT ACER X221W HAD IT SINCE 1 YEAR .. MY
I have acer aspire the mouse will not work
Aug 19, 2009 | Acer X221WSD Monitor
Monitor stops showing desktop
probably needs new voltage regulator for backlight. it would probably be cheaper to just buy a new monitor
Aug 14, 2009 | Acer 22" X223w LCD Monitor
I have a toshiba 32av500u.when i turned it on today i heard a sizzle noise and had no picture,but had sound for a minute.then it went out too.i was wondering if any one knows how to fix .thanks
WHAT THAT MEANS IS UR TUBE IS DONE U CAN HAVE IT FIXEDWITH A REPAIR GUY BUT IT WII B ONLY A MATTER OF TIME TILL IT GOES OUT AGAIN BUY A NEW TUBE 4 IT OR JUST GET A NEW 1
Jul 14, 2009 | Samsung 32 in. LCD Monitor TV
Blank screen
Possible that the HV inverter or the CFL tubes are going bad / defective. I suggest to bring the unit to an authorized Acer service center for proper check-up / test & fix the problem. regards
May 16, 2009 | Acer X221WSD Monitor
Vertical lines on one half the screen
Sounds like Light engine sizzle noise makes me think color wheel.
Nov 18, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Acer X221WSD Monitor Logo
199 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
