Question about Philips Magnavox 27MS343S 27" TV
We have no picture, just rainbow pinkish effect, no sound either.
We have checked with cable and all is good there,what happens when tv is gone bad? our tv is 11 years old.
  • 734 Answers
I have a Philips Matchine television which does a similar thing, the problem is in the receiver part of the set, where I have traced the Video signal with an Oscilloscope to a particular Chip (Integrated Circuit). By increasing the Contrast to maximum the picture can be brought back again, but still lacks contrast. The fault is varies as the chip warms up. Therefore you can locate the chip by cooling or heating it from a special non inflammable spray can.Have you tried the scart input which may work OK, then you can use the television as a monitor, as I do. Cost of repair is not worth it.
Posted on Nov 11, 2008
Strange rainbow.reenish type effect
Did you notice any better picture when you play a movie on a DVD player or using a flashdrive on this TV? Is the picture quality better? Or is it the same? Try to check another cable connection or try to play TV channel thru internet. The last option in this case is to show a TV mechanic for he would better understand which part to order.
Jan 20, 2014 | LG 60PZ550 3D Plasma TV
My Vizio television has like a pinkish red screen on it with lines going down the middle. I have no sound no picture nothing.
i would need more information but it sounds like your panel has gone bad. the panel is not a part worth replacing due to its price. it will cost you the same if you purchase a new tv.
Jul 19, 2010 | Vizio VO47L 47 in. LCD TV
My son was bouncing a small ball against the screen and then it went to looking like a rainbow. Would this be the picture tube?
He may have caused some type of damage to the picture tube, but usually rainbow effects happen when magnets are present. Perhaps the ball became charged with a large amount of static, which then discharged across the tube, damaging the controlling circuits.
Jun 03, 2010 | Toshiba 36A43 36" TV
Has rainbow lines on tv screen
shadow mask is warped. tv might have been dropped. crt is bad(picture tube). try deguassing it. if you dont know what that is take it to your local service center. the rainbow effect is a magnetic field of some sort. try unplugging and move to a different location. could be a speaker too close to tv.
Nov 12, 2009 | RCA F36650 36" TV
Mitsubishi rear projection tv
you have a problem on the chassis. either the FMT, DM, or the terminal board have gone bad. the quickest most effective way to repair would be to repair the chassis. check out www.tv-techs.com
Dec 26, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Concave picture with rainbow effect at the edges
Hello, Check and replace IC1606 (P/N: 875292571) and IC1608 (P/N: 875982987). Best regards, Arpi http://www.partstore.com/sl/2/418644-ic-cxp86448635q-875292571.html
Apr 23, 2007 | Sony KP-57HW40 57" Rear Projection...
Philips 28PW6515-05 flat screen TV
You have a bad connection on the CRT board thats mounted on the end of the picture tube it sounds like, or the socket on that board that plugs into the TV set is intermittant or has a bad solder connection on it. Good Luck
Mar 27, 2007 | Philips 28PW6506 28" TV
RCA 25: television
Sounds to me like a bad picture tube with circle rainbow like colors.Good luck.
Sep 03, 2006 | RCA F25423 25" TV
Philips Magnavox 27MS343S 27" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
