I have a lexmark 83 printer/scanner but am unable to install on computer. Do not have CD or cabel for hook up connection. Ple tell me how to get this corrected.
  • 734 Answers
First of all you need a datacable to connect printer to the computer and then try to install driver
Posted on Nov 11, 2008
Computer does not recognise scanner
Try using the Lexmark Printer Home. To access that, on your computer, click on Start > All Programs > Lexmark > Lexmark Printer Home.
If you don't see that option in your computer, just insert the installation CD and install the Lexmark Printer Home software.
Jul 17, 2012 | Lexmark Pinnacle Pro901
Lexmark X4550 Scanner not working
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 05, 2012 | Lexmark X4550 Multifunction Wireless Color...
I have my lexmark al in one scan,printer,fax hooked up to my laptop. I dont know how to scan pictures onto my laptop?
Hi there
for the canner to work, you have to install the printer with the CD that came with the printer. The installation software will setup the scanner so that you can scan by pressing the scan button on the printeror from the Lexmark Productivity Suite on your computer.
If you do not have the original CD, you must download the software from www.lexmark.combut be sure to download the full printer install, else the scanner will be installed.
Aug 27, 2011 | Lexmark X5470 All-In-One InkJet Printer
I couldn't use my lexmark 3470 scanner,please help,
Some Lexmark printers have to download the Application List, before they can scan. It might take 3 or 4 times for the printer to get it downloaded, don't ask me why. I don't know what else to tell you, you didn't say much about the problem. Do you have your cord hooked up to the USB port? Did you install the CD that came with your printer? Is your printer showing up in the Control Panel, letting you know the drivers are installed?
Mar 19, 2010 | Lexmark MFP-X3470 All-In-One InkJet...
Unable to install in winxp sp3 on Dell Inspiron 1420 When I tried to install the dirver for Lexmark x8350 all-in-one, it failed and the next time onwards, it asks if i want to do an upgrade or fresh...
First you can dowload the driver for Windows Vista from here:
then uninstall the old drivers by going to control panal uninstall programs. Then reboot pc, make sure usb link is not connected. Start the install software for your x8350 it will let you know when to hook up the USB link and auto finsh the install.
Note: If you do not use the CD to install your Fax software will not be installed. If you call Lexmark they will send you a new CD for Vista 800-539-6275
Jan 30, 2010 | Lexmark X8350 Print, Scan, Copy and Fax...
Cant download cd once it comes to the part to hook up usb it freeze up
What OS are you using? After the CD install is finished (or error out), unplug the USB cable and plug it back in. If you get any Plug and Play prompts point to the correct Scanner driver under "Scan" folder and Print Driver under - "Win_XP2K" folder on the CD and let it finish install that way. See if this helps.
May 10, 2009 | Lexmark X5470 All-In-One InkJet Printer
Can't seem to install the lexmark 1200 series all in one cd
uninstall the old driver you installed
unplug printer connection to PC (USB Cable)
restart PC
Install the software using the new CD
Follow the instructionon CD.
before end of installation it will ask you to connect the printer
here is the user manual: copy and paste the link to your web browser
Mar 20, 2009 | Lexmark X1270 All-In-One InkJet Printer
I have an old Lexmark 5150 which takes 82/83 cartridges can you tell me which new Lexmark would take the same kind of cartridges? as I am thinking of buying a new All in one printer, scanner,...
You know what, while I was at the lexmark site it dawned on me the the ink you use is almost as much as a brand new lexmark z series printer, man dump the dinosaur and make the plunge. Besides I didn't find any newer printers that had compatibility with 82/83 ink cartridges. Sorry I couldn't be more help.
Oct 13, 2008 | Lexmark Office Equipment & Supplies
when you try to hook up your printer in your comuputer is the printer detected? where you able to install the driver for your printer? was the printer configuration setting specially type of connection set to usb if the printer is connected to usb.
Jun 20, 2008 | Lexmark Office Equipment & Supplies
NO scanning
How long is your USB cabel? Support recommends me to use cabel short than 3 meters, I bought 1,8 m cabel, what solved my similar problem (scanner freeze).
Mar 02, 2008 | Canon PIXMA MX310 All-In-One Printer
35 people viewed this question
