Question about Kenmore 22422 Top Load Washer
Washing machine won't spin - Kenmore 22422 Top Load Washer
  • kjbeloved1 Apr 06, 2009
    won't drain or spin out
  • avbecerrils May 01, 2009
    washer won't spin or drain, the pulley does't move, the motor doesn't do anything, but there's noise coming from under the tub where the water is supposed to come out from. This is a Kenmore HE3t.
The washing machine won't spin or drain out
Posted on Nov 11, 2008
Posted on Apr 06, 2009
  • 132 Answers
SOURCE: whirlpool washing machine won`t spin or pump out
1-check the drain hose maybe cloged 2-check the drain filter maybe filed with materials 3- check no spin mode maybe you selected thank you
Posted on Jun 08, 2009
mumma_1
  • 903 Answers
SOURCE: washing machine won't drain and spin after rinse
It sounds like you have a blocked pump. I have read that the pump is connected directly to the motor. You will need some tools at hand before you try to disconnect the pump from the motor.
Make sure that you disconnect the machine from the power supply. Tilt the machine back to access the pump from the bottom of the machine. It will be connected to the motor with clips. Have some towels ready to mop up the water.
I hope this works for you.
Posted on Jul 27, 2011
  • 6277 Answers
SOURCE: my hotpoint wd 860 washing machine won't spin and
Indesit (Hotpoint, Ariston) 'F05' decodes as 'pump'blocked'.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 29, 2011
SOURCE: Kenmore 300 Series Top Loading
wont work at all in spin cycle the started switch stops working in spin cycle
Posted on Aug 01, 2011
  • 500 Answers
SOURCE: Roper washing machine fills and
Hi m3gamma1,
Before the Spin Cycle should start, all water must be drained out of the machine. If it does not start, it could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Posted on Sep 05, 2011
My washer won't spin
HI Rhonda.
If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. ... The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch.4 May 2012
SOLVED: Why won't my Washing Machine pump but not spin during ...
https://www.ifixit.com/.../Why+won%27t+my+Washing+Machine+pump+but+not+spin+...
What causes a washing machine not to spin?If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts.) ... 1Check the washing machine's spin cycle. If this works, the motor is operating and the belt is not broken.14 Aug 2014Washer Doesn't Agitate or Spin - HomeTipshttps://www.hometips.com/repair-fix/washing-machine-agitate-spin.htmlSearch for: What causes a washing machine not to spin?
Why is my washer not spinning the water out?If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.16 Mar 2014SOLVED: Why won't my washer spin or drain? - Kenmore 110 Series ...https://www.ifixit.com/Answers/View/.../Why+won%27t+my+washer+spin+or+drainSearch for: Why is my washer not spinning the water out?
What causes a washer not to spin?Over time, the repeated friction of the clutch pads rubbing against the housing can cause the clutch to wear and create a scraping sound. A worn clutch can prevent yourwashing machine from spinning, or may cause a slower spin speed which will leave your clothes wet after a cycle.How to Fix Washer That Won't Spin ' Washing Machine Repairhttps://www.partselect.com/Repair/Washer/Will-Not-Spin/Search for: What causes a washer not to spin?
if you need more help go to this link.
washer won spin Google Search
Nov 23, 2017 | Washing Machines
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Washer stays in wash cycle will not spin out i changed control board no help
Isyour washing machine displaying an error code? If so, try using the owner's manual to decipher the code and you may beable to easily diagnose the problem. The problem could be as simple as the doorbeing slightly ajar, the machine is in pause mode, or the spin selector isstuck. Checkthe handy chart in the article Washingmachine won't advance to washer spin cycle for more possible reasons why your washingmachine won't advance to washer spin cycle-and some tricks for getting itworking again.
Aug 01, 2012 | Electrolux Washing Machines
Washing machine won't rinse and the water won't drain out.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 04, 2011 | Washing Machines
I have a Matag Performa washing machine when it gets to the spin cycle it won't spin
heatman101
Aug 28, 2011 | Washing Machines
Won't spin out washing machine
heatman101
Aug 14, 2011 | General Electric WBSR3000G Top Load Washer
Why won't my washing machine spin?
heatman101
Aug 13, 2011 | Kenmore Washing Machines
Won't spin at all
heatman101
Jul 18, 2011 | Washing Machines
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
It won,t spin
heatman101
Sep 16, 2010 | LG Washing Machines
Kenmore 22422 Top Load Washer Logo
803 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
