Question about Sony KP-53V80 53" Rear Projection Television
Sound works no picture the red light in front flashes 5 times
I have a sony kp-53v80 and the picture stopped working but the sound works. when the tv is on or off the red light in front flashes 5 times. Does anyone know what the 5 flashes means? Thank you and have a nice day
SOURCE: troubleshoot-5 blinks red light front of TV
Hi, I have a similar problem with my KV25x5 it seems to be the CRT. I have just brought a new TV rather then fix it. Try as a starting point & google "sony 5 blinks" Jesh
Posted on Jun 02, 2007
SOURCE: sony tv red flashes
LED flashes of 8 times are indicative of a "High Voltage Error" which means something along the lines of "T8005 is faulty. (D board)" according to the service manual. Most likely it will need a professional to look at it. A link to the service manual is here:
Posted on Jul 02, 2007
my front panel sound is not working.......?
how i can do this.?
Posted on Jan 05, 2008
  • 8617 Answers
SOURCE: sony kp-53v80
Heres how you get into the service menu. BUT be very careful write down anything that you change as this can screw your set up and if you write down everything you will be able to change it back if it affects your set. You may want to consider getting the service manual which will explain all the details on the convergence adjustments. If so let me know and I will post a link where you can get one along with free tech support to help you out with it.
Put the TV in Standby Mode.
  • Then press the following buttons on the remote:
    {DISPLAY} {5} {VOL+} {POWER}
    {DISPLAY} {5} {POWER}
  • The TV will turn on with the Service Menu displayed.
  • Use numbers {1} and {4} to select the item to adjust.
  • Use numbers {3} and {6} to adjust the value of the data.
  • Press {MUTE} then {ENTER} to save new settings.
  • The words "WRITE" in red will show up in the upper right corner if saved.
  • Turn the TV off to exit the service menu.
  • Posted on Mar 31, 2008
    • 15 Answers
    TURN TIMER OFF. GO TO SONY.COM, TROUBLESHOOTING, OR The STANDBY light is flashing on the television and there is no picture or sound. Solution
    sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
    1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
    2. Unplug the television power cord from the electrical outlet.
    3. Let the television remain without power for 60 seconds.
    4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
    5. Turn on the television.
    If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
    Posted on Jan 16, 2009
    SOURCE: Sony KP-53V80 is not turning on.
    A 6 flash shutdown can indicate power supply problems or an open thermal fuse. To be sure, you should have a technician verify your problem.
    Posted on Jan 18, 2009
    0 characters
    1 Points
    I have a Sony KP-53V90 53 with no display and red light flashing
    This is a good one. Your TV "looks" at the feedback coming from each picture tube in your TV. When it doesn't see what it expects, it kicks out a 5 flash. Most commonly, the correct signals never got to the picture tube(s) and that's why the feedback was abnormal. Which brings us to the most common solution: C boards, they attach directly to the bottom of the picture tubes. Figuring out which one has a problem... that's another matter. Due to the age of the TV, parts costs are rising. Each C board (3 in the TV) runs about $100 so guess work can be expensive. I hope this was helpful.
    Mar 28, 2010 | Sony KP-53V90 53" Rear Projection...
    Sony model KP-53V80 wont show picture or sound
    Dec 25, 2009 | Sony KP-53V80 53" Rear Projection...
    Sony 5 projection tv kp-51ws510 no pic, light flashs 8 times
    I have the same model TV and have had that same problem (*8 flashes) The FLYBACK TRANSFORMER on the D circut board is the most likely cause and will need replaced) the part is around $70.00 USD!
    Please rate my response
    Jan 22, 2009 | Sony KP-51WS510 51" Rear Projection...
    I have a Sony Projection TV KP-53v80. I tried to turn it on today bu there is no picture no sound. The Timer/Standby indicator flashes 4 times. What does this mean?
    No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
    Check IC1509, Q1505
    Please rate this solution
    Jan 18, 2009 | Sony KP-53V80 53" Rear Projection...
    4 LED flashes indicated a faulty IC board
    Standby/timer light stays on red. no picture or sound on tv.
    my sony red light flash.but it will not turn on just clicks
    Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
    Green flashes then tv turns off
    or a new lamp. you could first replace the lamp.
    the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
    Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
    Sony kp-65xbr10w led light blinks 5 times
    i have a sony tv model kv36fs17. led flashes 5 times. tv works but no red color. would could be the problem? thanks
    Jan 23, 2008 | Sony KP-65XBR10W 65" Rear Projection...
    Working fine next day red light on solid
    Shorted hori output transistor and bad 1200pf 2k volt capacitor.
    Sep 15, 2007 | Sony KP-53V80 53" Rear Projection...
    Sony tv that flashes red
    (1) you have a bad capacitor next to hori output transistor and stopit you have both your hori output shorted and bad capacitor 1200pf 2k volts.
    Dec 13, 2006 | Sony KP-53V80 53" Rear Projection...
    Sony KP-53V80 53" Rear Projection Television Logo
    15 people viewed this question
    Top Sony Projection Televisions Experts
    Steve Sweetleaf
    Steve Sweetleaf
    Jason Harris
    Jason Harris
    Are you a Sony Projection Television Expert? Answer questions, earn points and help others
