Question about Electronics - Others
Nakamichi Soundspace 12 DVD player not playing DVD's.
The Nakamichi Soundspace 12 display LCD screen indicates the DVD drive to be locked out with a KEY I-con. System menu displays the DVD drive to be unlocked. When a DVD is loaded in the drive, it will not play at all. I performed a lock reset as mentioned in the manual, and the problem still continues. What can be done to fix this problem?
  • 10 more comments
  • jbole Nov 13, 2008
    It isn't a region code issue. The Key symbol shows that the drive has been locked in the menu, but the menu shows differently. It is as if the system needs to be reset, but that doesn't seem to help either. this seems exactly like a similar post earlier this week, but I could not download the solution.
    The reset proceedure does not work. The drive does not even spin, so the region code isn't even being read.
    I have had three responses, but I can only see the last response. Is there a trick to seeing all three?
  • jbole Nov 18, 2008
    Tried mmechanics solution and still no luck
    Nothing suggested so far has worked!!!!
    There is a parental lock which can be set to several levels. It shows on the SETUP menu to be "OFF", but the password field is active and an icon showing a lock (on the MENU tab) is depressed. There is no way to change the lock level from "OFF", the cursor just skips over it.
    The owners manual says that you can clear the lock and the password by pressing "CLEAR" for five seconds while in that menu tab.
    When you press "CLEAR" and hold it for 5 seconds, it performs a "button lock" which is what it is supposed to do in any other mode. Holding again unlocks the buttons. Normally that is o.k. but in this mode it is supposed to clear that menu.
    I would be happy to send it in for repair if anyone could recommend a repair shop that specializes in the SoundSpace series. Most Nak. shops wont touch a SoundSpace unit.
    I would be happy if someone could find the solution to the post which was exactly the same as mine, just earlier.
    Please no guessing here. Some of you guys are just guessing.
    again...u r just guessing.
    Tried these and no change.
    A guest has pressed alot of buttons trying to make it work.
    I am located in Houston, but will ship to anywhere.
  • jbole Nov 20, 2008
    Nakamichi finally responded through thier canadian distributor and singapore office. These proceedures worked. The fix is as follows:
    Update ?
    The SoundSpace?12 has two unique software features that should be shared with our field team. The features
    are described in detail below. Also, there is a correction to the owners manual.
    Feature #1 ?
    Safety lock setting (Demo Mode Lock)
    When the safety lock has been activated, no functions except power on/off can be carried out. This can be used
    when the SoundSpace?12 is on a sales floor. It will prevent customers from tampering with the volume or from
    removing discs from the disc drives.
    1) Press and hold the ?clear? button for at least 5 seconds. The indication ?Lock On? appears on the display of the
    main unit, and no functions except power on/off can be carried out.
    - If a button is pressed in this condition, the indication ?Lock? is shown on the display.
    2) To disable the lock, press and hold the ?clear? button for at least 5 seconds. The lock is released and the
    indication ?Lock Off? appears on the display of the main unit.
    Note ? The ?clear? button is located under the flip-down door between the ?0/10? button and the ?Light on/off? switch.
    Note ? This feature is listed on page 63 of the owner?s manual.
    Feature #2 ?
    RAM Clear 1
    There are occasions when it is necessary to reset all features back to factory default. Perhaps the customer has
    accidentally engaged the ?Viewing control level setting? feature (indicated by a ?key? icon on the display) and
    forgotten the password. Or, perhaps a retailer has a SoundSpace?12 on display and all of the settings are
    improper. RAM Clear 1 will accomplish the task of resetting the memory.
    1. CONFIRM NO DISC IS INSIDE
    2. TURN POWER OFF
    3. PRESS AND HOLD ?SELECT? AND ?DISC DOWN? KEYS SIMULTANEOUSLY
    FOR MORE THAN 7 SECONDS.
    4. ?RAM CLEAR 1? IS DISPLAYED, AND THE INITIALIZATION STARTS
    5. ?POWER OFF? IS DISPLAYED
    6. POWER IS TURNED OFF AUTOMATICALLY
    OPERATION
    7. RAM CLEAR 1 IS COMPLETE
    Owners Manual Correction -
    Canceling viewing control (page 54)
    Incorrect: If you have forgotten the password, press and hold the Clear button for at least 5 seconds at the
    PASSWORD screen. The parental lock is released and the key icon disappears from the display of the main unit.
    Correct: If you have forgotten the password, press and hold the Enter button for at least 5 seconds at the
    Note ? The remote has two Enter buttons. Press the ENTER button next to the number 1 key.
    The address and phone number for DBI worked. I had called earlier, and got re-directed to a US service depot that did not work. On my second call, they sent an email to Singapore and I received a response overnight. The text of that response is attached in my comments.
    Sergeant:
    Champion:
  • 435 Answers
Hi, Just found their service contact in US.
Main support number 310-392-1155
Support FAX             310-392-1030
supporttechnicalsupport@nakusa.com
Hope it helps.
Posted on Nov 18, 2008
  • 4,806 Answers
If you have exausted all other posibilities as mentioned, then you have to reset back to factory settings, instructions on how to do this should be in the user/service manual
kind regards
    Genius:
  • 1,011 Answers
Sir,
Open the dvd player and check them it there any wire is cut off or soldering will be losed. Check the board transformer with multimeter, if power supply is coming out or not.
thanks
good luck
    Sergeant:
  • 207 Answers
You mentioned that it appears locked and you can not play the DVD, But also that it is NOT a region lock.
Some players have a feature that is marketed towards parents, which is called a parental lock.
Is it possible that this feature is on your player, and either accidentally or purposefully set?
If unsure get a DVD with a LOW rating (Something G rated, a kids movie perhaps) and try to play that in your player, If this does the trick for you then somehow the parental lock was set and will block anything rated above the locked level.
Hope you find this useful
Dave
  • 1 more comment
  • David Preston
    David Preston Nov 18, 2008
    I Don't know where you are located. So it is difficult to suggest a local repair facility. The companies corporate headquarters are in Singapor, Japan I am giving you that contact information. If you would like me to try to find something local for you, just give me a general idea of you location and I will try to find out for you.
    Nakamichi Corp
    8 Commonwelth Lane
    The Grande Building
    Singapore 149555
    (65)6476 6686
    Hope this is helpful
    Dave
  • David Preston
    nearest distributer is
    DBI international
    39 Main street South
    Kenora, Ontario P9N 1S8
    (807) 468-8494 phone
    (807) 468-9147 fax
    dan@dbiint.com
    you can contact them and they should be able to inform you of repair/return procedures
    Good Luck and thank you for choosing FixYa
    Dave
  • David Preston
    David Preston Nov 20, 2008
    Jbole,
    Glad to hear that the Contact info I found, put you into contact with someone who could get you the PROPER procedure to fix things.
    Thank you for choosing FixYa!
    Take care.
    Dave
    Genius:
  • 1,913 Answers
Try to unplug it.
also clean your lense may be this is your lense issue.
Posted on Nov 13, 2008
    Brigadier General:
  • 6,966 Answers
Initially, pls try:
  • unplug from the mains for an extended period of time, say an hour plus;
  • press the ON/OFF or standby button while plugging in the AC plug to the wall outlet.
Additionally, was there anything out of the ordinary prior to the issue? Power outages/interruptions, thunder storm, near lightning strike, anything noteworthy?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa
  • Louie  Role
    Louie Role Nov 15, 2008
    Hi again,
    Any development(s) so far?
    President:
  • 1,952 Answers
Then u have to check the lens ..
  • mohammed marika thambi
    mohammed marika thambi Nov 14, 2008
    then the problem in spindle ...just check tat
    Sergeant:
    Novelist:
  • 196 Answers
Switch on the player making sure no disc is present  Press Pause on the remote  Press: 3, 1, 4, 1, 5 and 9 on the remote  Press the region number, 0 for multiregion  Press Pause  Turn the unit off then back on and you're good to go
  • mmechanics Nov 13, 2008
    other Alternative option
     Switch on the DVD player
     Press 'stop' on the remote
     Press '1', '9', '9', '9' then 'Enter'
     The region menu appears
     Select 'All' to make the player multi-region
    speacially the option for nakamichi SoundSpace 10, 11, 12, and 21
    Multi-Region:
     Press and hold the Track Down button on the player
     Press the Power On button to turn on your player
     Wait until the machine shows "----" on the display
     Release the Track Down button on the player
     Using the main remote keypad, enter the digits 1, 0, 1 and 1, then
    press Enter
    The machine should now display "D-00" and be region free
  • 1,879 Answers
Check your manual again if there's an entry about playing DVD's from other regions.
  • 6,487 Answers
YOu may need to unlock your player so it can be a Multi region DVD player so you can play all type of DVD regardless what region they are made for....
When I tried to play a DVD movie, because the picture on tv is B&W I tried to change the video output mode to something like 'entrelaced'. Then the tv screen turns to black and display the...
On the DVD player most of the time you have two outputs. One in cinch and one in scart output.
If one doesnot work try the other output to be able to reset what you have done. Or try to disconnect from the power for a few minutes it might work as well.
May 31, 2011 | Electronics - Others
Hi trying to clear regional code on dvd player panasonic s58 please advise Cheers
Hi there, the problem with this type of dvd player is that the remote has a pause/play combined button. You need to get yourself a generic remote and program it to use the dvd player, make sure it has a seperate play/pause button. When you have this remote use the following code :
Audio, 1, 9, 8, 2, Subtitle, Pause and then 0
Make sure you have the disc tray open at the time. The screen should display "On" if the code worked correctly.
I hope this helps and thank you for using FixYa
Aug 29, 2010 | Panasonic Electronics - Others
What does it mean when my dvd player says wrong region??
DVD's are coded to play in different parts of the world. Each DVD player is set up to recognise these codes. Most are set up to recognise only the region code of the area it was made for. For example Region 1 is for the USA and Region 2 is UK and parts of Europe. A DVD player made for the USA market would not be able to play any other discs with a Region code other than 1. And so on... This was done for the film industry benefit so that films can be released at later dates in different parts of the world without everybody seeing it on DVD issued in the USA.
However most DVD players can be "hacked" by a combination of keys allowing the user of say a Region 2 player to change it to another region. Some can also be changed to Region 0 which means it should play any disc.
How to change the Region code can be found by putting the model number of the DVD into a search engine and the words 'region code'. Some can be found on this site too.
Dec 04, 2009 | Electronics - Others
I have a sanyo 3 disc dvd changer. says no play
first of all you need to check your manuel for dvd's that can be played as in burnt. as of right no cd/dvd changers can play dvd that are burnt. cd's can be played if it states on player. only normal cd's and dvd's can be played. also check your disc for marks on them like fingerprints etc. if you want invest in a great player like sony, pioneer, i have no problem with these players.
Jul 26, 2009 | Electronics - Others
Player won't play legally imported DVD's
Hi, guessing you are from the UK? Different countries operate different regions for dvd's for instance the UK dvd players are set up to play region 2 discs, and US dvd players are set up to play region 1 discs.
This is because dvd release dates are different around the world and this stops people buying a dvd in the US and bringing it back to the UK and selling it before its official UK release date for example.
Your choices are either to play the dvds on a PC where often the dvd software will allow you to change region a number of times (be careful though as some players will let you change region say 5 times and then be locked to that region)
Or to get hold of or buy a multi region dvd player which plkays dvd'd regardless of their original region
Hope that makes sense, good luck
Jul 20, 2009 | Electronics - Others
Disc Read Error Sony DVD Handycam
Does your camera have other outputs, i.e., composite-video and L/R audio ?
If the disk "plays" inside your video-camera, then use a "video-capture" USB device, to "play" the movie into the USB device, and "record" from the USB device into your computer.
May 31, 2009 | JVC VDW14DU Single Unit 2x DVD-RW Storage...
Memorex MVD2015 DVD Player issues
This sounds like the LCD screen on the player has gone or is going out! I would return for a different brand! ( will cost more to fix then for a better player!)
Please rate response!
THANK
YOU!
Jan 11, 2009 | Electronics - Others
All region code for Medion DVD recorder MD84100
Found on another board, tried and it worked on my Medion
P70002 / MD84100 DVD recorder:
Turn on DVD recorder
Press HOME on remote
Go to SETUP in Easy Menu
Move down to padlock icon
Press 0 seven times
Message appears:
Congratulations!
Region Change Free!
YES (press ENTER)
It now plays US and UK as well as Australian (in my case).
Dec 31, 2008 | Electronics - Others
WRONG REGION error
For me the problem was with a Philips DVD player. I Googled the make, model and "wrong region code" and got some solutions. Try this approach. Some websites offer to sell you a solution; hopefully, you should be able to avoid this!
Dec 29, 2008 | Electronics - Others
LG dvd player DP281B shows disc error
if you have USB PORT. JUST remove the disc from dvd unit and plug in a usb pen drive with usb port.
if you haven"t.USB PORT JUST BUY IT FROM LOCAL ELECTRONICS SHOPS AND FIT WITH YOUR DVD player.
Oct 22, 2008 | Electronics - Others
Electronics - Others Logo
210 people viewed this question
Top Electronics - Others Experts
Brian Sullivan
Brian Sullivan
Are you an Electronics - Other Expert? Answer questions, earn points and help others
