Question about Estate TAWX700JQ Top Load Washer
My washer will fill up and drain, but it wont agitate or spin
The type of washing machine I have is Estate, and the model number is TAWX700JQ3
  • 734 Answers
Hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
hoses
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Dec 12, 2008
Estate washer fills with water and stops. It wont agitate spin or drain
Try replacing the lid switch.
These are cheaply mad of plastic, and fail often on all washers.
God bless your efforts.
Jul 03, 2017 | Estate Washing Machines
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Nov 02, 2015 | Washing Machines
My washing machine will not spin or drain,only fill up with water
Couple things could be happening;
Scenario 1: Your motor is dead, or the electrical connections leading to it are chewed up and no longer send electricity to the motor. If you have a voltage tester, you should see if you are getting power to it.
Scenario 2: The safety switch that stops the motor from spinning when the lid is open is compromised.. This is possible, but less likely, as the motor would still spin in agitate mode..
Jul 12, 2010 | Estate ETW4100SQ Top Load Washer
ESTATE TOPLOAD WASHER MODEL#TAWX700JQ3, DOES NOT SPIN FAST ENOUGH TO EXTRACT SUFFICIENT WATER FROM CLOTHE
Check if the belt is good and tight enough. If that washer uses a spring tensioner on the belt, make sure it travels freely and applies sufficient tension.
Jan 01, 2010 | Estate TAWS800JQ Top Load Washer
Makes a clicking noise when its time to agitate or spin
This advice applies to MOST Kenmore, Roper, Estate or any other Whirpool manufactured top loading washing machines.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
NOTE: I recognize these common symptoms, but you didn't post a brand name or model number. If your washer is not one of these brands, please post back and let me know.
Aug 10, 2009 | Washing Machines
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
GE commercial washer wont spin or drain
If your washing machine is 20+ appliance years old, it's probably due for replacement.
Jul 15, 2017 | GE WNRD2050DWC 3.5 Cu. Ft. Commercial...
My Estate by Whirlpool Corp. TAWX700JQ3 will fill up no drain,spi
Dear Customer
Please perform the following checks
Pease rate this,Thank u
Dec 18, 2008 | Estate TAWX700JQ Top Load Washer
Washer will fill up but wont agitate, spin or drain
This is a typical symptom of a defective lid switch. As you open and close the washer lid, you should hear a "clicking" sound. If you do not, the lid switch is probably loose or broken. The lid switch is located on the right hand side under the washer casing rim. It is activated through a small hole by a plastic piece on the lid called a lid strike. If this piece is broken off, the lid switch will also not activate. Inspect the switch mounting screws (two of them on along the wash tub rim) and make sure they are tight, and make sure the lid strike is in place. If you need to replace the switch, click on the following link for step-by-step instructions:
http://www.fixya.com/support/r397101-replacing_lid_switch
If you require replacement parts, you can find them at searspartsdirect.com. Just type in your model number and the you can find the lid switch listed under the "Top and Cabinet/Literature" heading as item number 9 (part #3949247). The lid strike is item number 20 (part #358684). This is a simple repair that you can accomplish yourself and the cost is minimal. If you need further assistance, please post back and let me know. I hope this is helpful to you.
Jun 16, 2008 | Estate TAWX700JQ Top Load Washer
Estate TAWX700JQ Top Load Washer Logo
291 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
