Question about Refrigerators
Kenmore ice maker not making ice
We have a Kenmore model #106.56664500
There is no water going into the tray to the ice maker
We can hear water running, but don't know where it is going
  • scottbh69 Apr 13, 2009
    The ice maker in my top freezer Kenmore fridge no longer makes ice and it seems that no water is getting sucked into the ice maker. The ice maker is moving continuously trying to work but there is no water. No problem with the water line after checking it out. Trying to figure out if there is some sort of separate pump that is malfunctioning before trying to repair.
We didn't really do anything, whatever was wrong seems to have fixed itself
Got up this morning and was making ice again.
Strange; maybe Casper fixed it??!
Posted on Nov 12, 2008
After changing water filter in refrig, there is a sporatic knocking sound...not associated with using the water dispenser.
The noise you are hearing is usually the ice maker heating up to activate the ice dump process.. It is normal for refrigerators to do. Also could be from the water temp is @ room temperature going into a freezing tray causing the metal to shift.. All normal sounds..
Dec 02, 2016 | Kenmore Washing Machines
My Kenmore bottom freezer refrigerator model 79570329311 wont make ice
Ice maker has issue.. Is there ice in bottom of ice maker tray? Is it empty? Is the arm in the down position? Is the solenoid working?
Without specifics you get no help.
Jun 25, 2016 | Kenmore Refrigerators
The ice maker overflows the ice tray, so water runs down the side of my freezer.
if it has worked for 3 years then I would guess just a new tray
Feb 18, 2015 | Kenmore Refrigerators
I have a Kenmore refrigerator model 106.56542400. The ice-maker does not work though the cold water works fine. How much it will cost me? Trying to see if buying a new one is cheaper. Thanks.
The cost depends on where the problem is. For example: If the ice maker is NOT getting water to make ice then it is probably the 2 line water valve solenoid or the sensor on the ice maker that would tell the 2 line water valve solenoid to send water up to the ice maker tray. Both of those replacements will cost you in the neighborhood of $25.00 - $40.00 plus a service call if you aren't able to do the work yourself.
If water is getting to your ice tray, but not kicking out the ice into the bin - that is usually a motor problem. And cost you as much as what a replacement ice maker would cost you.
To give you an idea of the cost of parts here is the layout for your unit:
Jun 24, 2011 | Kenmore Refrigerators
Ice maker not working on Kenmore Model # 106.54563300 Water comes through water dispenser fine Water came pouring out through ice dispenser door so I flipped bar up to turn it off Removed front box held in...
First the arm has to be in the down position. It sounds like you said theres water in the ice maker. If thats the case then it should have frozed. The ice cannot drop unless the ice maker heater comes on. Then the ice maker scoops the ice and drops into the resoviour thingy. If you have ice in the ice maker tray but no ice in the bucket then the ice maker is defective.
Mar 25, 2010 | Kenmore Freezers
Kenmore 56541 side by side icemaker nor making ice The in door water dispencer works Arm on tray is on no water getting to tray
1.Bad water valve located in the back bottom of refrigerator.
2. Frozen fill tube going into back of ice maker. (common problem)
3. Ice maker not cycling. Pour water into ice maker cavity until near filled.
Wait a few hours and see if it dumps.
4.In rare cases, the switch in the ice maker body fails. Ice maker will cycle but not tell water valve to refill.
Oct 24, 2009 | Kenmore Refrigerators
Ice maker not working, water not going in tray.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Water doesnt stop after ice tray is filled
there is a micro switch in the ice maker motor module that shuts power off to the ice-maker water valve when the ice maker is full but i rarely see them go bad this is the easy way to deal with it pull the unit out unplug both the valves and turn the water on a sec if its running in the ice maker with the valves are unplugged then replace the valves if its not replace the ice-maker motor module
Kenmore Side by Side Refrigerator Ice Maker Not Working
A couple things to check here. First see if there is ice in the tray. If so chances are the ice maker will need to be replaced however these are very reliable ice makers. If no ice in the tray pull up on the ejector blade (don't worry you won't break it) turn clockwise to start the ice maker thru a cycle. The ejector blade is the long white bar with fingers on it that run the length of the tray. Once it completes a cycle it should fill with water. If no water then either the fill tube is frozen over and will need to be defrosted or the water valve is bad.
Sep 30, 2007 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Refrigerators Logo
122 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
