Question about Hitachi 60SX13B 60" Rear Projection Television
Darkening screen (or of programs?)
Hitachi 60SX3B V4HAug 94 My wife and I have noticed, over the past couple of months, that many received programs have become much darker than before....for instance, in low light situations (as with the characters being in rooms as opposed to outdoors) any character or item in shadowed areas are almost totally blacked out. Does it corelate to a differing signal now be broadcast for HD? Really puzzling and irritating as some shows are almost non-viewable at times. Wondering if there is a way to brighten the projection. there is no halowing, converging problems, etc. When not too dark the picture is crisp and enjoyable. Dennis
    President:
  • 4,402 Answers
Use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Posted on Dec 05, 2007
The Pacifica will not shift past 4th gear. It shifts normally through 1st, 2nd, 3rd, and 4th gear. Their is no high reeving RPS, no clunking, no lurching. It will just not shift past 4th gear.
is there an OD button that might have been pressed .if it has lots of miles on it it could be needing a flush job . last one I got done was around 100.00 at jiffy lube.
Nov 12, 2015 | 2005 Chrysler Pacifica
Tip
I have a Viewsonic Q2201WB monitor. I am not sure if this problem is related to...
Many people have problems determining if their monitor is bad or their video card is bad. One good way to test this is by swapping out your monitor with a friend, co-worker, or family member with a known good monitor. You can do this with either your computer tower or your monitor. Follow the two steps below:
1. Take your computer tower and plug it up to a known good monitor. If the computer boots up with no problems and you are able to see everything on the known good monitor, then your monitor is bad.
2. Take a known good monitor and plug in to your computer system. If the computer boots up and you are still having problems and getting a black screen or some message saying "no signal" then your are having problems with your video card.
Some common symptoms of a monitor going bad are as follows:
1. A humming or buzzing noise coming from your monitor.
2. Picture fades in and out.
3. Colors appear in various places on your monitor screen that normally would not be there. Most common colors presented are red, green, or a mixture of the two.
4. Picture presenting either light or dark and will not change no matter how much you change the color or tint setting.
5. Lines appearing on the monitor screen. These will look like the lines on a bad television.
6. Monitor takes longer than normal to present picture. This time can vary depending on how old your monitor is and how far into the malfunction phase it is.
Since your monitor works off the same principles as your television set, most the time it will present with the same symptoms as a television going bad. I hope this helps in your troubleshooting process to determine if your video card or your monitor is the one causing the problems. These symptoms apply to the regular monitor only and not necessarily an LCD monitor.
on Jan 07, 2009 | Acer AL1912 19" LCD Monitor
Why does ch. 94 display "Ch unauthorized'
call your cable company. They may have changed the channel line-up and moved the station to another number.
Feb 28, 2015 | Hyundai 2012 Sonata Limited
The color is going. Could it be the lamp?
if it is darkening then yes. if it is giving you colors on the screen like a blob or star pattern it is the optical block.
Mar 08, 2011 | Hitachi 60V500 60" Rear Projection...
Hitachi 50" tv bought in feb 07-Approx 6 months ago tube was repl
YOU NEED A LIGHT ENGINE COST ANY WHERE FROM 800 TO 1500 TRY TO GET ONE BY COMPLAINING LOUDLY TO HITACHI FIRST
Jun 10, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Picture goes bad (fuzzy&scrolls&lines) on Hitachi projection tv
Sounds like your convergence modules have gone bad. They have 21 close spaced pins to unsolder and resolder. You'll need a soldering iron with a fine point tip and thin gauge solder to do the repairs yourself. Solder bridges between pins are common when soldering these module pins, so have some unsoldering wick handy if you're going to fix it yourself. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jun 14, 2017 | Hitachi 50UX57B 50" Rear Projection...
Pelco monitor display is darkening
There is another brightness adjust on the back of the monitor.
Feb 19, 2009 | Pelco Pel Monitor 12" B/W
Bluish hazy texture on my screen
It sound like the light engine is going out or already out. I would take it to a certified Hitachi dealer have them check it out then I would call Hitachi to have them fix it for free.
Nov 14, 2008 | Hitachi 50VS69 50" Projection HDTV
Blue Haze in middle of screen vertical
There is no solution with Hitachi products.
If you have read many of the posts, you would have known not to buy Hitachi Telivisions or like me avoid all Hitachi products. There help line is not very useful, they just blow you off. I have never had a worse experience with other manufacturers. Take Onkyo for instance, they had a problem with a chip in their THX receiver and it was a year later ... I called their help line they located a repair store about 40 miles from where I live (in Texas that is not very long) and got my receiver fixed and this was 8 years ago.
Also use Consumer Reports to check the frequency of repair record for the product you are going to buy. In Plasma - Panasonic is a safe brand, in LCD's Sony or Samsung have good repair records.
Research the product before you buy it, avoid walking into a store have the salesperson direct you to a product. And then you save money if you order it online. Amazon online is very good.
Nov 10, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Monitor goes dark over and over
Well done! Maybe you should think of joining the Fixya team :)
Cheers,
IrishDruid
May 02, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Televison & Video Logo
59 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
