Question about Sylvania 6615LE LCD HDTV
TV turns off
The TV turns on fine but turns off by itself after a few seconds....if one uses the remote or the on/off swithc it'll turn on agin right away but turns itself off again
  • 3 more comments
  • Marc Jomini Jan 20, 2007
    I took the tv to three different shops and here is the result....the transformer for the screen illumination is bad...this requires replacing the whole board since components are not available separately...I was looking at over 200 dollars to fix the problem..so I went out and bought another tv (not a Sylvania) for just a little more money. I will never again buy one of their pieces of c**p! Good luck.
  • Catwatcher Dec 11, 2007
    Same problem, tv turned off automatically. It was in parts warranty but labor to replace board or whatever was $79 in addition the the $39 diagnostic. Have that piece of c**p gathering dust in the basement; bought a Sharp replacement. If there's an inexpensive solution I'd still like to get it fixed.
  • Andrea Vance Dec 28, 2008
    I had the same problem and followed the fix from "guest" used 2 new capacitors from radio shack and for $3.00 the tv is FIXED!!!! Thank you Guest!!
    Your the best...now my husband thinks I can fix anything!
  • FreshNips May 14, 2009
    what watt iron do i use? 15 seemed to not melt the solder...
  • Anonymous May 20, 2009
    The fix proposed by “Guest” worked perfectly!
    I followed the instructions in March of 2009 and my set has been running every since.
    I must admit, I was skeptical that it could be that easy, but it was…
    Thanks to “Guest” for the info!!!
    Thanks to “3dmama” for the motivation!
    kitchen-tv-works-now
La verdad yo no creia que cambiando dos capacitores de 0.1 Faradios a 250V. pudieran solucionar el problema, y mas sin embargo funciono, yo tengo con esta TV Sylvania 6 anos y mis hijos la tienen prendidad todo el dia, la reparacion solo me costo 10 pesos, y el tecnico en electronica me decia que ya era inservible porque no se conseguian las pezas (los transformadores que hacen prender el tubo de liliminacion) gracias por este aporte mi TV vuelve a funcionar al 100%, si tu TV SYLVANIA Mod. 6615LE Prende y despues de algunos segundos se apaga solo cambia estos capacitores y realmente se soluciona el problema.
Posted on Apr 05, 2011
Fixed it !!! Used the approach by Guest; replaced both of the capacitors with 0.1 microfared caps from Ratshack. It's been working for two days. Thanks Guest.
Posted on Dec 17, 2007
Guest, Your the bomb. I went straight to radioshack and bought two of the capacitors you recommended. Replaced them and now my tv works again. Thanks again
Posted on Jan 16, 2009
Could someone please show the location of these caps on the board. I have the same model TV doing the same exact thing.Also the part number for the caps you bought at Rat Shack.....
Thanks a Million !
Posted on Dec 18, 2007
  • ccox Dec 21, 2007
    Installed the 2 caps described by guest and catwatcher.TV is fixed, I watched it last night for 8 hours....before it would stay on for about 10 to 15 minutes sometimes and then shutoff.Thanks everyone !
The transformers for the illumination are not bad,that is an excuse to charge a high repair price. The solution is : there are two capacitors across the transformers, there value is 124 nanofarad aprox. .12uf/250V.Check them for an open state.if you can get a higher temperature rating it will last longer.
Posted on Jun 04, 2007
Just a note from one who didn't read "Guest"'s statement carefully enough. I tried the cap fix but used a soldering gun versus and iron. The gun would not melt the factory solder and I wound up damaging the printed circuit board. TV now scrap.
Use an iron not a gun and be very steady.
Posted on Mar 18, 2009
Television shuts off
Posted on Jan 01, 2008
The capacitors I used were Rat Shack:
0.1 uF Metallized Polyester Film Capacitor
Model: 272-1053
Catalog #: 272-1053
They were located adjacent to the two flat transformers, are light brown in color, and are marked "WES 124J 250V" plus some other markings. Remove the screws holding on the main board and daughter board. Remove all the connectors except the flat cable connecting the daughter board to the screen. Fold the board over to expose the solder side, then use solder wick to desolder the capacitor leads. Bend the leads on the new caps to fit, solder in, you're done.
  • shawn755 Dec 28, 2010
    I, too, had the same issue with the TV shutting off... after following the capacitor replacement method that "Guest" suggested, the TV works perfect once again. After getting the unit apart, replacing the capacitors took less than 10 minutes. I now have a great-working LCD TV ...and the best part is.... it was given to me! I also replaced a burnt switching diode. Total investment into the repair project was less than $6.
  • Nick Mar 01, 2013
    Opened the tv (sylvania LD320SS8a) I found 2 light brown capacitors but each was different, one was labeled FNR G31D R2.5-4 M AC125V, the other: PVR 10D471K. These were located maybe 2 inches away from each other, but both adjacent to the flat transformers.
Did you ever find the solution to this problem? Wifes tv just started doing the same thing about 20 minutes ago, tried unplugging the device, resetting the sleep timer etc. If you got a remedy I'm all ears! Jeff D
Posted on Jan 17, 2007
Tv no picture
It sounds like it's developed a serious fault, is it still under warranty or manufacturer return?
Jun 25, 2015 | Televison & Video
TV turns on then off no picture
this is very common. it is the power supply going bad. it should run at 130 volts dc. but it is now running much lower that this. just enought for the tv to come on. but not enough to power all the circuits right.
Nov 20, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
How to program this remote.
Hey mate is there a set button on your remote? or similar type of command, if so, turn the tv on by its main on/off button on the tv itself then stand back and point the remote at the tv, now press the SET button down for a few seconds, if you see a flashing light on your remote this means it is searching for a IR signal, cool now just keep pressing the on/off button on the remote say every 2 seconds, as soon as your TV turns OFF press the SET button on your remote and hopefully it should be tuned in and you can use the remote to turn your TV back on and play with menu and stuff. If this worked dude you can join my... getting a remote to work easy club .
May 23, 2013 | Televison & Video
Sony trinitron model kv 36hs420. t.v. will turn on for a few seconds, then turns off on it's own. (you can hear sound but turns off before picture comes up) Red light on front blinks. This happens if...
I have fixed this problem, on one of these.
It is a voltage regulator, and it probably died after a power outtage or surge,
am I right?
Get it to a fixer guy, Its a very affordable repair.
are you in VB? I'll do it!
Aug 30, 2011 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Hi my son got a 19inch emerson tv for his 2nd birthday and now anytime it gets plugged in it flashes different colors and the buttons does't work and the only way to turn it off is to unplug it!! can this...
Press the the cursor key up followed by down and power the TV off with the remote or the TV itself. Please use the original remote for this. Unplug the TV for a few seconds...replug and power the TV on. The second thing to try...press the cursor key left followed by the right key. Power the the TV off with the remote or the TV itself. Unplug for a few seconds...replug and power up the TV. Some of these TVs left the factory in the service mode. The fix is pretty simple. Thanks asking and show a few hands of support!
Feb 14, 2011 | Emerson LC195EM9 19 in. LCD TV
No power
your on off switch button need to replace or try to spray contact cleaner then press on and off a few time and pls unplug the power cable first ok
Mar 24, 2009 | Televison & Video
Tv turns off when I first turn it on
hi this s grizmofreak
solution to above problem
this s because of the secondary emissions of picture tube, and once the supply stops the emmissions from the picture tube wont stop for few seconds and horzontal scannin problem.
please do rete me on the above solution.
Feb 02, 2009 | Televison & Video
I have a Samsung LE26R72B. the digital tv has just stopped working. the digital screen has frozen with 'FILM 4' on it. i can't acces the digital menu and i cant change channel. all other features of the tv...
Solution that worked for me:
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Jul 07, 2008 | Televison & Video
Sylvania 6615LE LCD HDTV Logo
1,920 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
