Question about Akai LCT2715 27 in. LCD Television
Akai LCT2715 Twizted, I did have a problem, but no more, thanks to you. I replaced all 17 electrolytic caps on the power supply board and it cleared up all of the problems with this TV set! Thanks again friend! Righand
  • 30 Answers
Awesome... Great job on the fix!!
Posted on Nov 12, 2008
Yet another Akai power supply
Any luck getting this fixed?Please let me know.Thank You very much!
Tyler
Jun 21, 2010 | Akai LCT2715 27 in. LCD Television
My Akia 27" lcd tv wont come on, all I am getting is a flashing red light and a popping sound. What could be wrong with it?
Ur power supply board is dead.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 21, 2010 | Akai LCT2715 27 in. LCD Television
AKAI LCT2715 will not turn on gives blinking
This series of TVs has a famous issue with the power board (part number MLT166A or similar). Several capacitors and zener diodes burn out causing some resistors to burn as well. If you are capable of doing component level repairs check capacitors on the board and zeners Z2, Z3, Z4, Z5 and resistors around them. If you prefer to spend hundred bucks and simply buy the working power board for it - ebay is your answer.
Sep 06, 2009 | Akai LCT2715 27 in. LCD Television
Akai lct2715 power supply repair needed. Please respond. Failure appears to have occured over several days. First picture had distortion at edges. Then blue AKAI screen would light but picture was not in...
I very highly doubt that is merely a power supply problem,I would suspect that it is a small signal board (aka scaler board) or at the very least,have the inverter boards checked
Jul 16, 2009 | Akai LCT2715 27 in. LCD Television
Power supply
Hi
Please go to ebay and buy your power supply cheaper price:
AKAI LCT3201TD POWER SUUPLY MLT169A REFURBISHED CHAINA
Thanks
GEORGE
Mar 01, 2009 | Akai LCT3201TD 32 in. LCD Television
Need Power Supply for AKAI LCT2715 Repaired
I repair these power supplies.
If you require further assistance you can write to jah2mil@hotmail.com
Dec 27, 2008 | Akai LCT2715 27 in. LCD Television
Akai 27"
Hello, I can repair your power supply which is most likely the reason for this failure. I charge a flat rate of $100 + return shipping to recondition the power supply.
I have created an Instructable located here http://www.instructables.com/id/AKAI_LCT2715_Power_Supply_Removal/ which will guild you through the removal of the power supply from the TV. Once you have the power supply removed you can ship it to me for repair. E-Mail me at (twizted at dragonmodz dot net) for shipping address and to discuss any other questions you may have.
Dec 12, 2008 | Akai LCT2715 27 in. LCD Television
Akai LCT2716 Flat Panel TV
I bought one of these tv's at a thrift store and it had the same problem, orange light blinking and static sound coming out of the speakers, no video at all.
The problem was the power supply board, this power supply has multiple outputs that feed the circuitry, 12V, 24v, 5V.
There was nine electrolitic capacitors I had to replace to fix it, all of them were bulged they are easy to spot, I measure one of them that was supposed to measure 1000uF but measured only 65uF. you can buy these from digikey for about 50 cents each, they need to be rated at 105 deg c and the profile has to be below the heat sink otherwise they will hit the top of the heat sink, the spacing between the leads has to be 5mm so they fit in the pcb. I replaced 3 1000uF/25v, 3 470uF/16v and 3 1000uF/16v and that fixed the problem, I bought this tv broken for 100 bucks fixed it with 6 bucks.
Good luck, don't perform repair if you are not familiar with dangerous AC voltage inside the TV.
Mar 12, 2008 | Akai LCT2715 27 in. LCD Television
Akai LCT2715 Led blinking orange and set won't turn on
There are about 16 to 17 capacitors that are a common fail point on this TV. I can repair your power supply board with new high quality capacitors and recondition the board to work like new for $100 + S/H, you simply have to send me the power supply module and turn around is approx 2 days from the time I receive the package to the time its out the door. Approx 8 business days according to the delivery carrier you use.
Apr 09, 2007 | Akai LCT2716 27 in. LCD Television
Akai LCT2715 27 in. LCD Television Logo
73 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
