Question about Panasonic Televison & Video
My Panasonic TU-PT700U Digital media Receiver shuts the TV down after 10-30 minutes and the blue light flashes 5 times repeatedly. I have to unplug the unit and let it cool for several hours before it it run the TV. Again, only for 10-30 minutes and then shuts it down again.
Hi, I have a spare TU-PT700U that may be of use for you to solve your problem without having to replace your system.  My Panasonic onyx series monitor was stolen out of my house, but they left behind the TU-PT700U and cable.   If interested, respond to my craigslist post..
http://sfbay.craigslist.org/sby/ele/930283631.html
Posted on Nov 23, 2008
5 blinks on a TU-PT700U panasonic plasma tv means what?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Sep 18, 2016 | Panasonic TU-PT700U DTV Receiver
Panasonic TV Receiver problem
It will be best to contact the authorized service centre for Panasonic in this case.
Jun 26, 2013 | Televison & Video
Power Surge
charlie the proble has something to do with the tv guide here is a response from an older post Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was. Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
Aug 05, 2012 | Pioneer PDP-6010FD 60 in. Plasma HDTV
Panasonic 50 Onyx broken
Did you look here:
http://www.twoguysny.com/products/Panasonic/pan/tupt700u.html
Mar 13, 2012 | Panasonic Televison & Video
Where is the air filter on a Panasonic PT-52LCX65 Projection TV
THE AIR FILTERS ARE INSIDE THE ENGINE YOU MUST TAKE APART MANY PIECES LET A REPAIR CENTER DO THIS!!
Apr 25, 2010 | Panasonic PT-52LCX65 44" HDTV
How to connect Panasonic BD60 Blu-ray disc player to 2 components
If there are red and white RCA jacks on the back of the BR player and on the receiver you should be able to get sound. The same as your VHS.
Dec 29, 2009 | Panasonic DMP-BD60K Blu-ray/DVD Player
HITATCHI ULTRAVISION P50S601...POWER LIGHT BLINKING...WONT COME O
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Feb 25, 2009 | Hitachi Ultravision P50S601 50 in. Plasma...
I have a panasonic onyx 42 xvs30 plasma. Will not turn on. Moved from my sons home. Is there a card that is supposed to be in the media box? Blue light turns on for 2 seconds and then goes off quickly. It...
hello, make sure your ac power is correct as far as gounding and proper polarity.
some homes are wired incorrectly and the tv wont operate like this.
first step is to check your sockets with a (ground fault tester) its a small plug in unit with led lights that indicates if there any electrical fualt in your power lines.
if it isnt your wall sockets then it is inside your tv set. the media slot is for a media card it shouldnt have anything to do with your tv working or turning on.
if your not able to see a welcome screen menu when you turn it on, this indicates a shut down circut or power issue.
you may want to find a tv service center to check it for you
this is your best chioce.
hope this helps
Dec 22, 2008 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
My Panansonic TV shuts down every few minutes and the LED blinks three times
I still have that problem. I calle Mfr and also spoke to repair shops recommended by them and they said they estimate a cost of 300-400$ or so approx. I am waiting to buy a new LCD which could be few 100 more but at least dont have to live with the old one and keep spending money...
regards
Oct 07, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
Televison & Video Logo
457 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
