Question about RCA CC-432 Camcorder
Eo3 error on a rca video camera
The unit goes into safegaurd and gives a e03 error code.. model cc6364
  • pmr7 Dec 31, 2008
    I have a Model CC9370 RCA Digital Video Camera and it goes into safeguard mode, code E 04. Did you get your problem solved? Rsvp, yea or nay, to pmr7@verizon.net. Thank you
3 Suggested Answers
57 varieties
  • 1653 Answers
SOURCE: E03 safegaurd mode remove and replace battery? how
Make sure there is no tape jammed in the mechanism anywhere and carefully clean around the whole tape compartment with cotton buds and isopropyl alcohol to remove any dust and debris, particularly on the opto sensors for read/write and tape present. If this does not solve the problem, try a different tape and if it does not solve the problem then you will need to get it serviced. This is a real pain problem in JVC’s and Panasonics and servicing (which may be costly) or scrapping is the only resolution.
Posted on Oct 06, 2009
SOURCE: I have a RCA cc6364, had it for years. I bought a
Does your camera work of a Power Adapter? If it does, then the battery is most likely at fault. If however it will not, then it will be the camera.
Posted on Feb 22, 2010
Wa250 3-L Komatsu wheeler loader has a call EO3. What the sequence yo the code out?
Re: error code E03 on washing machine
Eo3 water not draining,check for kinked drain hose,check that drain filter is clean
Oct 01, 2015 | Washing Machines
EO3 COMES UP ON MY CDPLAYER CAUSE I HIT A BUMP IN THE RODE
Hi there:
Here are the listing as to what the error codes refer to:
- E01 - Focus Error - Disc is not loaded correctly, or condensation on disc
- E02 - Disc Error - Disc is dirty, scratched, or deformed; or excessive vehicle vibration
- E03 - Mechanism error - Loading or eject error. Pickup-up is out of position.
The E03 error typically occurs when the CD player mechanism is damaged. Try different types of CDs; a new music CD would be the best to try. If that also gives the same E03 error, your CD player probably needs to be replaced.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 18, 2012 | Cars & Trucks
I have an AXM17U camcorder that is showing EO3 and wants battery reattached. I have ussed two different batteries @ full charge with the same result..EO3. What's next?
E03 Take-up error
Most common in the Mini-DV models. This problem can be defective reel tables, or it can also be a defective rotary encoder. You can expect to pay intermediate to major labor for this type of repair. Parts are nominal.
The indication E-03 or E-04 is an Emergency Error Code. In the event of a malfunction the unit will shut down and display a code. This is to inform an independent JVC authorized service center which area of the camcorder to examine in order to ascertain the nature of the problem.
The E-03 or E-04 code relates to one of the tape spindles not turning. This could be the result of too much slack on the video tape. If E-03 or E-04 is displayed it may be possible to correct the problem by removing the tape slack. In order to do this follow these steps:
1) Remove power source for 1 minute.
2) Reattach power source.
3) Press "EJECT" (DO NOT PRESS POWER)
4) Repeat above steps until tape ejects.
5) Tighten and insert a new tape."
Keep us updated.
Apr 07, 2011 | JVC Video Cameras
My cam. goes into e03 safegaurd mode please remove bat. and rehookup.when i do it plays again for about 5sec. and does it again
The mechanical section which consists of the tape cartridge and VHS-C tape plain has a timing misalignment. Check the inside for possible obstructions of the tape guides not fully sending the tape to the heads - sometimes it gets stuck. It will likely need to be taken apart to resolve the issue.
Nov 13, 2010 | JVC GR-SXM37U SVHS-C Video Camcorder with...
I am looking for a charger to my CC6364 model but it has been discontinued. I need to know where to find a charger.
We will check our inventory ok, but we have also technology to replace your unit with a universal adaptor on your unit itself
Nov 23, 2009 | RCA Video Cameras
Error code E03 on washing machine
eo3 water not draining,check for kinked drain hose,check that drain filter is clean
Sep 28, 2009 | Washing Machines
E03 safegaurd mode remove and replace battery? how can you fix problem? I have removed battery several times and get the same error code. (RCA CC9370 digital camcorder.)
Mar 28, 2009 | RCA CC9370 Mini DV Digital Camcorder
E03
my jvc gr-DVX MINIDV PAL KEEPS GETTING ERROR CODE EO3 PLEASE HELP
Dec 04, 2007 | JVC GR-DVL20EG Mini DV Digital Camcorder
Weird error message
For Models: CC6254, CC6364, CC6374, CC6384, CC6394, CC9360, CC9370, CC9373 There may be a simple solution. Do the following: * Turn your camcorder's power off, then disconnect the power source (battery or AC adapter). * Remove the clock battery, if equipped with one. * Wait a few minutes, then reinstall the clock battery. Reconnect or install the power source — battery or AC. * Then try turning on the power again.
Sep 06, 2005 | RCA CC-432 Camcorder
RCA CC-432 Camcorder Logo
151 people viewed this question
Top RCA Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
