Question about Kenwood DPX-MP4030 CD / Cassette Player
Seakers shorting out... wiring or amplifyer?
My 1999 Honda CR-V has a Kenwood DPX_MP4030 unit in which the speakers are starting to short out. The power to the unit and the display lights seem constant but the sound from all the speakers has started to stop and start intermittently. This seems to not be related to road movement, banging on the dash, etc. For some months now one of my dash speakers has been intermittently coming on for a short time then going off again.
My question: Is the head unit or amplifyer failing or is it just a wiring problem? (or, is there any way to tell?).
I'm just doing research before I dig in there to look at the wiring. But I don't think I could tell if the head unit or amplifyer was failing.
Any thoughts based upon your experience would be greatly appreciated.
Thank you. Rich
  • gopherhockey Mar 08, 2009
    I have the exact same problem as the other guy, with the same kenwood stereo. I had the stereo out last night with every thing connected and was able to duplicate the problem just by tapping n the chassis. I'm taking mine to best buy to get it fixed.
    Problem Solver:
  • 15 Answers
Sounds like a wiring problem. check the connections on whatever is easier first (radio/speakers) if the connections are good you may have to trace the wires to see if there is a break or short somewhere.
Posted on Nov 28, 2008
I have Kenwood kdc- mp343 it displays protect then what happens?
Disconnect all speakers from unit. Turn on. If still in protect then unit is damaged and needs repair. If not then reconnect 1 speaker at a time until it goes into protect. That speaker is either shorted or wiring is shorted.
Oct 30, 2016 | Kenwood Car Audio & Video
Hi just bought a car radio with no indicator of which wire is which..
the wires are really easy but it you buy the aftermarket harness you wire it to that and the wires are color coded and then it literally plugs into your car, other than that the purple, green, white and gray are speakers those with the black strip are negative, the others being positive, the red and yellow are power one constant and the other ignition, and black is ground.
Sep 10, 2011 | Kenwood DPX-MP4030 CD / Cassette Player
When i power it on it shuts off i got a kenwood kdc-mp825
Disconnect all of your speaker leads at the head unit, make sure none are touching, then power it back on. If it still cuts out, check your ground, if it doesn't, re-connect speakers one by one and test power again. It will either cut out when you get to a speaker or wire that's shorted, or work just fine. it's protecting itself from damage by cutting off when speakers are either bad or have shorted wiring. Most common shorted wiring happens on door speakers at the hinge. If it continues to cut off without speakers connected and you have a good ground, the unit needs service. If it still plays and you find the speaker or wire that's causing the problem, disconnect the wire at the speaker and test again, if it works, replace the speaker, if it doesn't, replace the wire. Hope this helps
Jul 07, 2011 | Kenwood Sirius KDC-MP825 CD Player
Kdc-mp245 is in protect mode, how do i find what speaker is shorting out?
disconnect all the speakers , may still say protect , reset eeprom by holding preset 3 & 6 +reset , display may show dc error , hold preset 1 fpor a couple of secomds then hold preset 2 for a couple of seconds , then display should show dc1 - ok / dc 2 - 0 , then connect speakers one at a time , check wiring ,this may cure fault
Jul 25, 2010 | Kenwood DPX-501 CD Player
Kenwood kdc-138, NO SOUND, CD PLAYER NO RESPONDING
First thing you need to do is make sure you dont have a short in the speaker wires.. if any one of them touches ground it kills the system.. then you have to remove all the wires and start over... disconnect the battery... remove all the speaker wires only and then turn it on and reset it... then again remove the battery from the car and install them all make sure nothing is touching then turn it back on and see if that works.. you can also test to make sure you speaker wires are good by using a 9v battery and touching positive and negative of each speaker to the positive and neg of the battery... JUST FOR A SECOND it will pop.. that means your wires are good and no shorted to that speaker.
May 12, 2010 | Kenwood KDC-138 FM / AM Receiver
Kenwood KDC 241 SA car radio 'Protect'.
you could have a shorted speaker wire, a blown speaker; or the output ic in the deck itself could be bad.
Mar 03, 2010 | Car Audio & Video
Cd player is not working
The unit is telling you it's shut off output because of some problem. There night be something wrong with one of your speakers or the wiring. A speaker may have shorted or a wire may be contacting a sharp edge somewhere and shorting to the car frame. This could also be due to a problem in the amplifier itself. Try unplugging the speaker wiring from the unit and see if it clears up. If so you can start isolating which speaker or wire run is bad. If the unit is still in protect without the load, you'll need to have it serviced.
Jan 31, 2010 | Kenwood KDC-MP235 CD Player
Help
This is a safety feature to avoid damage to internal components, the wiring must be shorting out to earth. Disconnect the speaker cable connector at the rear of the unit and try it, if it is ok then you have a speaker wire shorting out to ground. if it is still saying protect then disconnect the other wires one by one.
Aug 29, 2009 | Kenwood KDC-MP2035 CD Player
Kenwood DPX-MP4030 CD / Cassette Player Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Pablo Gonzalez
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
