Question about Water Heaters
The code E 13 comes up on the panel and it cuts out
It is a vaillant boiler ECOmax 622E
  • 1 more comment
  • Anonymous Dec 17, 2008
  • Anonymous Jan 28, 2009
    ****!!!!! My ****'s doing this too.
  • Anonymous Mar 21, 2014
    got a vaillant 428 boiler with a fault code s53 dont know how to over come it pls help
Maximum temp exceeded on ntc1(thermistor),,,either clean out heat exchanger,power flush of my first option replace thermistor...
Posted on Feb 02, 2009
Can any one help can u tell me wot e 13 meens on a vailant ecomax 824e gc number 4704407 thank u
Posted on Jul 03, 2009
Hello. I have a vallient ecomax 828 which is displaying the F40 fault code after a power cut earlier today. The boiler sounds like its running, but nothing is happening.
F40 is a fan fault. this fault normally comes up when the fan doesn't turn, you need an engineer to fix this, i could tell you how to fix it but its best left to a gas engineer
Feb 05, 2018 | Water Heaters
Vaillant Gas boiler/furnace not firing up
There is a thermocouple heat detecter in the pilot flame clean it 240 sand paper is ok. replace if not working.
Oct 22, 2014 | Water Heaters
Vaillant boiler clock not working
your timer clock may need to be replaced.
Aug 12, 2017 | Water Heaters
New Vaillant 360 eco plus boiler, takes almost 3/4s an hour for rads to come up to a decent temp. Hot water is fine. Called out install Engineer who is an excellent tradesman but he says everything
We have just had our old system boiler replaced with a vaillant ecotec plus 837 and sounds like a similar working operation to ours. At first I was a little concerned,but I was told by our installer that he was told by vaillant that these very latest boilers size the system on start up for about 10 mins, then take temperature to target flow which you set boiler at. So even by setting target flow temperature very high you still get the initial sizing cycle, which ours was about 30-35c temp. These boilers seem to run biased for efficiency as after a while they modulate the boiler burner down and the radiators run more on the side of warm than really hot like the old type boilers. You also get better efficiency as at lower temperature the boiler condenses better. You will also find you get a more constant temperature in your home rather than over shoots. I was concerned at first, shame there was no info/explanation in user manual as people do need to know that this is normal operation. We are used to ours now, took a month and by the way these boilers can make a creaking noise but was told this normal expansion/ contraction but annoying when sited in bedroom cupboard. Best of luck!
Oct 27, 2012 | Water Heaters
Code f28 what isit?
According to the user's guide, the fault code means that the boiler failed to start after 5 attempts. Here is the manual where I got the information. I would confirm the codes with your particular model. I am presuming that the codes would be standard for all their models. Source(s): http://www.vaillant.co.uk/stepone2/data/…
Mar 10, 2010 | Water Heaters
Vaillant boiler no heating or hot water
refere to manual check for override switch loss of pressure no problem re-pressurise and check for leak top of rad valve good place to start
Oct 10, 2009 | Water Heaters
Vaillant ecoMAX 828/2boiler goes on & off when running hot water!
water must be set at 3lts a min ,check diaphragm valve move when hot tap is on, check microswitch ,best of luck
Aug 09, 2009 | Water Heaters
Vaillant combi boiler,dirty water comes out of hot and cold taps ,just been serviced by british gas,could you tell me the problem
Hi ,
Can you please tell me the model of the vaillant, and the approx age?
I can solve this problem
I await your reply
Thanks
Steve :)
Jul 16, 2009 | Water Heaters
Vaillant 831 combi boiler timer help
check to see the time clock is set with the clock symbol. there are three settings on analog clocks I , O and clock the I setting is constant running, the O setting is off and the clock setting is timer.
also try setting the thermostat up higher to see if the boiler fires.
Mar 25, 2009 | Water Heaters
Water Heaters Logo
433 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
