Question about Panasonic Office Equipment & Supplies
I am receiving an error code on my UF 8000 machine. The error code is E05-11. If you could please let me know what the code means it would be greatly appreciated. We have very recently had this machine serivced with a new heat drum and also a new board.
  • Anonymous May 26, 2009
    Panasonic UF-8000 is giving me an E05-11 code. We sent the engine board to Hi-Tech for repair. No problem was found with the board. Still have same error code. What can I do next?
  • 2,120 Answers
Engine Board Connector unplugged or bad engine board.
Posted on Nov 11, 2008
Panasonic UF-8000 has very loud sound when sending or receiving documents. Why?
This problem is mechanical,some of Gears were broken.Please check which gear was broken and replace it.
Dec 08, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Panafax UF-8000 not responding, energy saver light flashing.
It sounds like the operation panel is bad or has a loose plug.
Remove left and right top screws that hold the left and right panels on.
Wiggle the op panel towards you and up, check the white wire harness.
Good Luck!
Jul 07, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Fax can not be send and received
press the monitor should hear a dial-tone...if not try below.
Check the phone line with a regular phone plugged into the wall jack.
Mar 11, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Email problems on Panafax UF-8000
you need a IFAX/email key "small little electronic board" installed on the main board it does not come as default so you need to talk to your dealer about this option
Nov 20, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Panafax UF-7100 showing install developer
Unplug power / plug back in.... NoGo? try this:
press monitor key slowly 4 times
scroll down to CLEAR FLASH MEMORY
set (wait for reboot)
If that doesn't work, scroll down to ALL JOB CLEAR and set.
Last resort....
scroll down to SHIPMENT SET
2 for no
Did the developer problem go away?
Sep 08, 2008 | Panasonic PanaFax UF-8000 Laser Fax
PANASONIC UF-8000 ERROR CODE E03-20, copy function not working.
Error code E3-20 Main Motor Rotation.
Loud clicking sound fuser unit drive gears cracked not driving
Apr 01, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Error Message: "Contact Your Dealer Printer Error E04-01" - What does that mean?
you can try a LBP fuser reset and LBP error log clear . this might fix the problem your having.
Mar 14, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Scan to email
you need to check that you have properly programmed your parameters in the machine that should match the ones provided by your ISP.
Aug 14, 2007 | Panasonic PanaFax UF-8000 Laser Fax
91 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
